The 1.2TL, Project Monolith
1234568»
    xschop Posts: 5,390
    VR3 wrote: »
    Yes there's a spray you apply to the metal which turns black.
    It is difficult to adhere though
    Like black paint?
    VR3 Posts: 29,543
    edited September 2024
    What larry showed above is it.
    You have to seriously clean/degrease the metal. You apply it like a paint and when the laser hits it the product turns black to whatever you are etching. You then clean the substrate and all that will remain will be your etched design.
    xschop Posts: 5,390
    Ah...Snaps, as the kids say.
    Toolfan66 Posts: 18,167
    I will try and do a short video next time we run the machine..
    xschop Posts: 5,390
    How dare you come in here dropping eye candy like that without a proper build thread.
    SCompRacer Posts: 9,121
    Toolfan66 wrote: »
    Outstanding! Do you have mirrors mounted behind speakers to show them off?
