SDA 2.3 No bass
124
  • halo71
    halo71 Posts: 4,637
    Tony, aren't you glad I told you about those 2.3's in Dawsonville? lol
    --Gary--
  • tragusa3
    tragusa3 Posts: 48
    vulcan wrote: »
    The DCR readings can be obtained more easily from the terminal cup.
    Use red and black speaker binding posts. The interconnect(IC) cable points are blade is pin#1 and the pin is pin#2
    I did redo the reading from the terminal cup. They changed from my first readings and matched up to the handbook.
    SDASRS2.3, SDA1C, Monitor 10, Monitor 7b
    Klipschorns, LaScalas, Heresy
    JBL8330a
    Infinity Kappa6
    Danley DTS10
  • tragusa3
    tragusa3 Posts: 48
    halo71 wrote: »
    Gary, are you being sarcastic? I knew what I might be getting into, and I certainly stepped into a project. I'm thankful for you, but not glad yet. It's all part of the journey. :smile:
    JBL8330a
    Infinity Kappa6
    Danley DTS10
    xschop Posts: 5,224
    2.3tl and 2.3 are completely different critters.
    Until someone actually posts the true schematic for MW's between original 2.3 and 2.3TL, then it's all speculation why the drastic re-design. I speculate that the 6511's suck as stereo drivers and Polk re-designed the stereo and SDA circuits in the 2.3TL's for the tighter 6510's.
    VR3 Posts: 29,461
    The 2.3 has sub bass drivers and the 2.3tl does not
    2.3
    VR3 Posts: 29,461
    2.3tl
  • Gardenstater
    Gardenstater Posts: 4,785
    edited July 2024
    Not 2 *dedicated* sub-bass drivers in the 2.3tl like in the 2.3. They instead have the dimensional drivers trying to do double duty as SDA dimensionals and also sub-bass stereo drivers.
    And also they swapped sides so that there is a 4 driver stereo line array on the inside and 2 dimensional (plus sub bass stereo) drivers on the outside.
    2.3 has 4 driver array on outside (2 purely dimensionals and 2 purely stereo sub bass) and 2 stereo drivers are on the inside.
    If this is wrong feel free to correct (without unnecessary ridicule).
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,224
    Understand, but how are they SUPPOSED to be wired? A true schematic is in order here, not speculation.
  • tragusa3
    tragusa3 Posts: 48
    edited July 2024
    xschop wrote: »
    George, that is my understanding too. If we had a member with the same speaker that was performing correctly, they could verify wiring for us.
    JBL8330a
    Infinity Kappa6
    Danley DTS10
    VR3 Posts: 29,461
  • Gardenstater
    tragusa3 wrote: »
    xschop wrote: »
    Rob (xschop) 👍 That makes 3 of us in agreement 😁👀
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • tragusa3
    tragusa3 Posts: 48
    I may have just found the issue...stay tuned.
    JBL8330a
    Infinity Kappa6
    Danley DTS10
    xschop Posts: 5,224
    You mean you didn't just throw some more expensive caps in as a hail mary fix-all lol?
  • tragusa3
    tragusa3 Posts: 48
    When putting the drivers back in, I noticed a stray blue that had fallen out of its fast-on. Repaired it...no change. I probably knocked it loose in all my working? Dang it. I was happy for a moment.
    The donut drivers (6513) or sub bass drivers are not putting out the level of sound that the stereo drivers do. Got to be something bad in whatever is sending sound to those. Like I originally stated, they are playing, but roughly 50% of the excursion and volume of the others. I did test every driver with a 9v battery and they all moved with the same exact excursion. I wonder if I can find which frequencies are sent to the donuts? If it coincides with the sudden drop my SPL meter shows, then I'm sure I'm on to something.
    Per the handbook (and suggestion from George), I played noise through each the left and right speakers and when I move the balance all the way left, the stereo drivers play while only the dimensional drivers play on the right speaker. And vice versa.
    On to a parts list for the crossovers...would anyone make a suggestion of a shopping list? I am after best value. Not the cheapest, but nothing more than will satisfy most. At least the performance of stock.
    JBL8330a
    Infinity Kappa6
    Danley DTS10
    VR3 Posts: 29,461
    My guess is you have a bad cap and possibly an inductor which does happen
    F1nut Posts: 51,862
    That is how they are supposed to be. The donut restricts the cone movement and therefore the volume level.
    Viking64 Posts: 7,578
    edited July 2024
    VR3 wrote: »
    a bad cap
  • halo71
    halo71 Posts: 4,637
    tragusa3 wrote: »
    halo71 wrote: »
    Yes, just messing with you Tony.
    --Gary--
  • skipshot12
    skipshot12 Posts: 2,022
    If you want cheaper side go back with stock caps but, since you’re in there go with film caps and upgrade your resistors too.
    Sonicaps & vishays….
    Make sure your inductors are good.
    xschop Posts: 5,224
    edited July 2024
    Clarity caps and you'll have money left for beer. But you were still wired wrong as @Gardenstater pointed out, and Sonicaps won't help that.
  • skipshot12
    Great job.
    Now crack a frosty beverage & enjoy those speakers…..
  • skipshot12
    Any way you can share the sound with a video?
  • tragusa3
    tragusa3 Posts: 48
    skipshot12 wrote: »
    I tried to post a video and it seems to only allow pictures? I'll look again.
    JBL8330a
    Infinity Kappa6
    Danley DTS10
  • JCL
    JCL Posts: 169
    Glad you got it worked out! That makes sense if everything at the binding posts measured correctly.
    L600 (front), R200 (rear), R200 (rear surround), L400 (center), Sunfire HRS-10 (2)Marantz AV7706Sunfire Cinema Grand, Marantz M8077, Music Hall Stealth, Ortofon bronze cartridge, Parasound Zphono XRM, Sony UBP-X800
  • skipshot12
    edited July 2024
    Would like to hear your results please.
    I have trouble posting videos too.
    Someone told me to do it as a YouTube video then paste the link.
    That works well but is pain in the butt for me being digitally challenged.
    SCompRacer Posts: 9,116
    Glad you got it fixed! Nice work Trey!
    We have a clock similar to yours.
    edited July 2024
    skipshot12 wrote: »
    Yup, that's what you have to do. This applies to Trey. :)
    https://youtu.be/Ru-8Pfrosp4?si=NvWkzTjGMHuiSZj-
    SCompRacer wrote: »
    My mother had a picture of that same exact mill from almost exactly that same angle.
    edited July 2024
    Viking64 wrote: »
    I got it from a polk forum member, a photographer. He had it listed on facebook IIRC. My account is gone so can't recall his name or screen name. IIRC he was a fireman at one time?
