SDA 2.3 No bass
  • tragusa3
    tragusa3 Posts: 48
    edited July 2024
    HOLD THE PHONE: Please say that I stumbled into something!!! Hard to show it in this picture, but this is the right speaker, drivers in the array of two. The black wire on the driver to the left is on + as it should be. When I trace it to the driver on the right, it is black with a white marker, but is on negative? Those two drivers shouldn't be out of phase? Should they? OTHER cabinet is the same way...maybe it is supposed to be.
    SDASRS2.3, SDA1C, Monitor 10, Monitor 7b
    Klipschorns, LaScalas, Heresy
    JBL8330a
    Infinity Kappa6
    Danley DTS10
    Clipdat Posts: 13,104
    VR3 Posts: 29,750
    edited July 2024
    I have ran the big Polks with no passive resistor installed and they will shake the house with the worst bloated bass you will ever hear.
    If all of the drivers are working I think you have a phasing issue somewhere
  • tragusa3
    tragusa3 Posts: 48
    With both cabinets being this way, I don't think I found a problem. But does this mean the stereo array drivers are out of phase with each other? odd.
    JBL8330a
    Infinity Kappa6
    Danley DTS10
  • Gardenstater
    Gardenstater Posts: 4,944
    tragusa3 wrote: »
    According to the schematic they are supposed to be in series. So one driver would have its positive terminal connected to the appropriate terminal on the PCB and then there should be a wire going from the negative terminal to the positive on the second driver. Then there should be a wire going from that driver's negative back to the PCB at appropriate place.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • skipshot12
    skipshot12 Posts: 2,156
    Now you’re cooking big daddy.
    Could be something that simple. Tracing out everything will eliminate what’s not wrong.
  • tragusa3
    tragusa3 Posts: 48
    edited July 2024
    tragusa3 wrote: »
    So I got excited too soon. it's part of the design. Oh well...I'll keep trucking.
    Skepshot, I'm going to figure it out.
    JBL8330a
    Infinity Kappa6
    Danley DTS10
  • Gardenstater
    I can't really tell from your picture if it is correct. I "think" that the bottom stereo driver's positive should have a black wire going to it from the PCB. Then there should be a black wire with a white marker going from that driver's negative to the upper driver's positive. Then there should be a white wire going from that driver's negative back to the PCB.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • tragusa3
    tragusa3 Posts: 48
    That is how it is wired.
    JBL8330a
    Infinity Kappa6
    Danley DTS10
  • tragusa3
    tragusa3 Posts: 48
    edited July 2024
    Clipdat wrote: »
    My uneducated **** says it's something wrong with the crossover.
    Has a bad/old capacitor been known to completly choke out bass?
    JBL8330a
    Infinity Kappa6
    Danley DTS10
    VR3 Posts: 29,750
    If the capacitor is open or way out of spec it is in parallel to the driver and definitely would cause issues
  • gmcman
    gmcman Posts: 1,880
    How is your room setup? Pics? Any other floor standing speakers placed nearby that aren't in use?
    Trying to rule out a large bass suckout somewhere.
  • tragusa3
    tragusa3 Posts: 48
    gmcman wrote: »
    The room is not ideal, but I have done lots of moving of placement and even brought them into the neighboring room with no success. On top of that, 6 or so other speaker pairs have had prodigious bass in the same position. Thanks for your input.
    JBL8330a
    Infinity Kappa6
    Danley DTS10
  • tragusa3
    tragusa3 Posts: 48
    VR3 wrote: »
    Can I test the capacitors while on the crossover board? How would I?
    JBL8330a
    Infinity Kappa6
    Danley DTS10
  • Unknown
    edited July 2024
  • Gardenstater
    edited July 2024
    I don't like the fact that Polk didn't show the drivers and their wiring arrangement in the schematic. I don't think they failed to do that in later schematics I have seen. I think you need to try to do a sketch of how they are wired in your speakers.
    Going back to the first page of this thread where you posted the below wiring diagrams with your notes, I am troubled by the fact that the dimensional drivers pulled in and all the other drivers pushed out, I'm assuming when you put a battery across the binding posts?
    I also see that you show for the dimensional drivers Blue as negative and Green as positive and I think Polk convention was the opposite of that. It was in the 2.3tl wiring diagrams. Maybe your polarity of the dimensional drivers is incorrect.
    PS: Not that I'm trying to give you more homework 🤣
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Unknown
    xschop Posts: 5,836
    Not only are they out of phase, but follow any other later SDA scheme where the stereo driver or drivers are wired for 6.5 ohms and the dimensional driver/s are wired for 3.5 ohms.
  • Gardenstater
    I'm inexperienced with SDA but I don't see where they are out of phase in either the 2.3 or 2.3tl schematics. Also as I said I don't think Polk would have changed wiring conventions of Blue being positive and Green being negative. Maybe I'm missing something. He needs to find everything that is wrong and fix it and the problem will hopefully get taken care of along the line. Somebody was monkeying around with these speakers and there isn't a clear schematic on how to wire the drivers up, really.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Unknown
    VR3 Posts: 29,750
    Very
    SCompRacer Posts: 9,399
    edited July 2024
    tragusa3 wrote: »
    You'd need an ESR tester like the Capacitor Wizard. ~$200. In circuit testing isn't always reliable though. If I get a questionable reading from the Wizard, I always disconnect one side of capacitor and retest the capacitor only, not the circuit it is connected to. Sometimes the Wizard reads "compare" and I have to test the cap with a Sencore capacitor analyzer.
    You have a multimeter that measures capacitance? Again, not always reliable unless you disconnect one end of the capacitor.
    Always disconnect power and drain a capacitor before any testing.
  • tragusa3
    tragusa3 Posts: 48
    edited July 2024
    Reseal the cabinets, rebuild the crossovers, replacing the inductors as well. Get some Armacell Armaflex TAP18230 Insulation Tape from Home Depot to replace the gaskets. Inspect all drivers and the passives for small tears in the surrounds. Replace the wiring harnesses and reassemble. This will eliminate every potential point of failure within the speakers for the problems you are having. At this point, you are chasing so many variables trying to solve an issue that would be corrected by just biting the bullet and doing what you already know needs to be done anyway.
    I didn't consider the crossover rebuild to be "biting the bullet". I've rebuilt several sets in the past, although vintage Klipsch crossovers are far simpler than these. Since it was obvious someone had been inside these cabinets, I'm doing my diligence to rule out as much as I can first. I'm satisfied I've done all I can outside of the crossover. So begins the next chapter. I have to own being all over the place. LOL :#
    JBL8330a
    Infinity Kappa6
    Danley DTS10
  • tragusa3
    tragusa3 Posts: 48
    George, I forget now where I saw it, but having the dimensional drivers out of phase was to be expected in the battery test (yes, battery to binding posts). In essence, that test alone proves wiring to be correct. It's got to be in these crossovers. I've been reluctant to believe they could be responsible for something as drastic as I measured, because I've rebuilt them in the past and haven't noticed much change in any case. But, we are all about to find out. :)
    JBL8330a
    Infinity Kappa6
    Danley DTS10
  • tragusa3
    tragusa3 Posts: 48
    SCompRacer wrote: »
    tragusa3 wrote: »
    Well...cheaper for me to take the chance on rebuilding (which I would have done either way) than to buy the equipment. :smile:
    If I use a DC device connected to the removed capacitor, will it drain it? Is that how it's done easiest?
    JBL8330a
    Infinity Kappa6
    Danley DTS10
  • Unknown
    edited July 2024
    edited July 2024
    A resistor can be used, an incandescent light bulb, shorting across leads if it is a low voltage. :D
    The light bulb gives you a visual and something to watch counting down. Doubtful you'd get a 60 watt bulb to light with a crossover cap. Check cap with voltmeter before testing.
  • Gardenstater
    I would check to make sure the + terminals of the dimensional drivers are connected to the end of the 1.23mH inductor (other side from binding post side) because the schematic clearly shows that. The 1.23mH inductor would be the 3rd largest one in size.
    I have never heard that Polk ever changed Blue is positive, Green is negative convention, or I should say that they ever had it the opposite of that.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    edited July 2024
    And you think those are different from the ones that OP and I have already posted? Or that your wiring conventions are different from what I said above?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • vulcan
    vulcan Posts: 99
    edited July 2024
    The DCR readings can be obtained more easily from the terminal cup.
    Use red and black speaker binding posts. The interconnect(IC) cable points are blade is pin#1 and the pin is pin#2
    Polk Audio SDA 1C, Klipsch Legend KLF 20, Klipsch Chorus II
