Monitor 10 tweeter replacement.
Hello Polk-folk everywhere, just got my 1:st pair of Polk speakers ever, had some posts here during autumn 23' regarding the Infinity RSIIIb I acquired at that time and still love.
Got me a pair of monitor 10 in black veneer the other week for a symbolic fee like 30 usd and they look mint just the one tweeter is blown (blewn?) so I wonder if the RDO 194-1 replacement might be any good and if so I suppose I'll need to replace both as opposed to the SL2000's different character?
I have just started to listen and compare them to the B&W Mythos 500 that stands underneath and those B&W's do sound more modern with a bit more resolution in the high-end/tweeters but it is very hard to say as they might just split different and so the question will I need and like to improve/recap the filters in the Monitor 10's?
(as of now the one tweeter that works sound a bit dull actually and comparedq73x1a5c79as.jpg
magictimbres.se
living room listening:
Thoréns TD318 MKII w. Sumiko Olympia
Arcam rPhono
Harmony Design pre 906
Cambridge Azur 651w
Infinity RS IIIb
control room listening:
Snell type JII
studio room listening:
Heco Mythos 500
Polk Monitor 10 B
    F1nut Posts: 51,870
    Buy two RD0194-1 tweeters. That is RDzero194-1.
  • Bleiz
    Bleiz Posts: 46
    Thanks F1nut and how about the TL mod whatever that is or no need for this with those tweeters?
    magictimbres.se
    Arcam rPhono
    Cambridge Azur 651w
    Infinity RS IIIb
    Snell type JII
    Heco Mythos 500
    Polk Monitor 10 B
    F1nut Posts: 51,870
    The RD0194-1 tweeters are a drop in replacement.
    The TL mod requires a lot more work and different tweeters. You can read more about it here, https://forum.polkaudio.com/discussion/149215/monitor-10-rebuild-with-tl-mod
  • Bleiz
    Bleiz Posts: 46
    Allright so I'll go for the RD0194-1's as direct replacement then and skip crossover tweaking as these speakers have been stored and unplayed for at least 15 years until now, guessing the x-overs will be just fine.
    magictimbres.se
    Arcam rPhono
    Cambridge Azur 651w
    Infinity RS IIIb
    Snell type JII
    Heco Mythos 500
    Polk Monitor 10 B
  • odcics2
    odcics2 Posts: 376
    Your ears will tell you if you need any new crossover parts.
    F1nut Posts: 51,870
    edited June 2024
    Bleiz wrote: »
    Even though the speakers have been unused for years the original electrolytic caps will have degraded not to mention they and the mylar were crap to start with. I highly recommend upgrading the crossover components regardless. With the RD0194-1 tweeters you would upgrade the component values like for like with film caps and non-inductive resistors such as Vishay-Mills.
  • Bleiz
    Bleiz Posts: 46
    Did you see the last photo in my original post showing the crossover in my case? Doesn't look at all like anyone I've seen in any thread or photo on this subject, maybe a later revision with not so crappy caps?
    magictimbres.se
    Arcam rPhono
    Cambridge Azur 651w
    Infinity RS IIIb
    Snell type JII
    Heco Mythos 500
    Polk Monitor 10 B
    F1nut Posts: 51,870
    You have two crappy electrolytic caps, one crappy mylar and two crappy ceramic resistors.
  • Bleiz
    Bleiz Posts: 46
    edited June 2024
    I can see 2 electro-caps + 1 mylar + 2 ceramic resistors + a blue "doublepack" in the middle looking like caps but seems to be a resistor 12.0k 250v ?! what about this one leave it be or is this the Mylar cap per se and what value if so, which brand to replace with...?dqsi0fmpem05.jpg
    Post edited by Bleiz on
    magictimbres.se
    Arcam rPhono
    Cambridge Azur 651w
    Infinity RS IIIb
    Snell type JII
    Heco Mythos 500
    Polk Monitor 10 B
  • Bleiz
    Bleiz Posts: 46
    edited June 2024
    Also this Mylar cap what does it say regarding values? don't understand anything of the symbols etc...did a picture seek and it says it is a thermic resistor or even fuse??? hc8jgd9ze8w8.png
    magictimbres.se
    Arcam rPhono
    Cambridge Azur 651w
    Infinity RS IIIb
    Snell type JII
    Heco Mythos 500
    Polk Monitor 10 B
    pitdogg2 Posts: 27,143
    edited June 2024
    Bleiz wrote: »
    That is a polyswitch, yes it is a type of fuse. Also called a thermister. Most of us replace them with a .5 ohm vishay-mills resistor. The problem with the polyswitch is as they age they tend to trip easier and easier. They cut power to the tweeter and "reset" once you turn the volume down. They're nasty little things!
    The blue "doublepack" as you call it is a 12uf 250v mylar capacitor.
  • Bleiz
    Bleiz Posts: 46
    [/quote]
    The blue "doublepack" as you call it is a 12uf 250v mylar capacitor. [/quote]
    Thanks for clearifying this to me ;-)
    magictimbres.se
    Arcam rPhono
    Cambridge Azur 651w
    Infinity RS IIIb
    Snell type JII
    Heco Mythos 500
    Polk Monitor 10 B
    F1nut Posts: 51,870
    I'm curious, right next to the screw head are the letters, Model 10 IIIT. Can you post a better pic of that lettering, please?
  • Bleiz
    Bleiz Posts: 46
    Good that you noticed this F1, I missed it due to the focus on caps etc, to me it looks like it says model 10 / II T so what is this model 5yrvjz9ix7cf.jpg
    then and are those still crap components in need of upgrades?
    magictimbres.se
    Arcam rPhono
    Cambridge Azur 651w
    Infinity RS IIIb
    Snell type JII
    Heco Mythos 500
    Polk Monitor 10 B
    F1nut Posts: 51,870
    Ok, you have the Monitor 10 Series 2, so the SL2000 tweeters in yours are the wrong ones. They should have been the SL2500. In which case means you want the RD0198-1 tweeters.
    Yes, the components are still crap.
  • Bleiz
    Bleiz Posts: 46
    edited June 2024
    Ok good to know, will shop for the RD094-1 anyway otherwise I'll have to do the TL mod you said was an extensive change...will just swap the caps etc for better parts Jantzen + vishay. The RD0198-1 are 6 ohms I have seen...
    magictimbres.se
    Arcam rPhono
    Cambridge Azur 651w
    Infinity RS IIIb
    Snell type JII
    Heco Mythos 500
    Polk Monitor 10 B
    F1nut Posts: 51,870
    edited June 2024
    NM
    Post edited by F1nut on
  • Bleiz
    Bleiz Posts: 46
    STOP! You want the RD0198-1 tweeters. There is no need to do the TL mod to use them in your model. Do NOT get the RD0194-1.
    Oki oki I promise to go for the RD098's if you insist ;-) Nice to hear there's just needing the ordinary component-swap then!
    magictimbres.se
    Arcam rPhono
    Cambridge Azur 651w
    Infinity RS IIIb
    Snell type JII
    Heco Mythos 500
    Polk Monitor 10 B
  • Gardenstater
    Gardenstater Posts: 4,785
    edited June 2024
    I checked and actually the M10 and RTA11t schematics were the same except for the midwoofers (thus the "M10 / 11t" on the board). This is pre Series II. The Series II schematic is different and only has one resistor, for one thing. Different inductor and capacitor values too (except for the contour network cap)
    Series II didn't come out until 1990.
    RD0198-1 wouldn't work without the tl mod. If it were me I'd do the tl mod but you might not want to bother.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Bleiz
    Bleiz Posts: 46
    edited June 2024
    Now there is some confusion here...so mine are not the series II you mean, you having seen all photos I suppose? if so we're back to replacing tweeters w the other RD0194's then...
    magictimbres.se
    Arcam rPhono
    Cambridge Azur 651w
    Infinity RS IIIb
    Snell type JII
    Heco Mythos 500
    Polk Monitor 10 B
  • Bleiz
    Bleiz Posts: 46
    edited June 2024
    Mine are signed AK 11/4/88NM...
    magictimbres.se
    Arcam rPhono
    Cambridge Azur 651w
    Infinity RS IIIb
    Snell type JII
    Heco Mythos 500
    Polk Monitor 10 B
  • Gardenstater
    edited June 2024
    Bleiz wrote: »
    Correct. Not series II. They are M10B. There was no 10C afaik.
    I carefully checked the relevant schematics: RTA 11t, M10, and M10 Series II.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 51,870
    Ya know, for once Boy George is right. Bleiz, my apologies for the confusion.
  • stevep
    stevep Posts: 360
    Those are 10B crossovers. And SL2000 tweeters in the pictures of the speakers. I don't think Series 2 crossovers had polyfuses in the tweeter circuit.
  • Bleiz
    Bleiz Posts: 46
    No worries, will order tweeters + parts like tomorrow etc ;-)
    magictimbres.se
    Arcam rPhono
    Cambridge Azur 651w
    Infinity RS IIIb
    Snell type JII
    Heco Mythos 500
    Polk Monitor 10 B
  • Bleiz
    Bleiz Posts: 46
    edited June 2024
    I've read several posts @ various forums that some people swear by the Peerless K010DT tweeters once used vs SL2000's etc and if so how would Monacor DT-100 do as a substitute in anyone's opinion, or the Response 115DT26/27 sold from hifi-kit here in Sweden?
    https://willys-hifi.com/products/monacor-dt-100-tweeter
    https://hifikit.se/115dt26-27.html#horizontalTab2
    magictimbres.se
    Arcam rPhono
    Cambridge Azur 651w
    Infinity RS IIIb
    Snell type JII
    Heco Mythos 500
    Polk Monitor 10 B
  • Gardenstater
    edited June 2024
    Peerless are great. I couldn't vouch for either of those copies because I haven't ever come across those, so it was interesting and thanks for the links!
    You would need to replace your crossover with the M10 or M10A crossover and the midwoofers would need to be MW6500 in order to use the Peerless. You might even need a different passive radiator because that is tuned to suit the enclosure volume and the woofer.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Bleiz
    Bleiz Posts: 46
    I will not use/order the Peerless variants then, too much hazzle with changing x-overs +passive radiators like you say, guess anything will be better anyway by upgrading the caps and either stick to the SL2000's or go for RD0194-1's if the original ones are to tired.
    The state of the speaker woofers + passives are mint as are the boxes, the guy I spoke to at hifikit Sweden told me Jantzen standard caps will do and even cheaper ones, otherwise it will be "like shooting a mosquito with a bazooka" as he put it...also to leave the original sand resitors in place no problem according to him.
    magictimbres.se
    Arcam rPhono
    Cambridge Azur 651w
    Infinity RS IIIb
    Snell type JII
    Heco Mythos 500
    Polk Monitor 10 B
  • Gardenstater
    Everyone has their own opinion, but most audiophiles disagree with the guy at hifikit. Sandcast resistors are particularly reviled and most go with higher wattage (10 or 12 watt) non inductive wirewound types like Vishay Mills. Those sandcast ones are said to even have steel end caps which are of course ferromagnetic.
    I don't have any personal experience with Jantzen caps. I went with Sonicaps which are pretty pricey these days, although there are much more expensive caps to be had than sonicaps. Many people here have saved money by using ClarityCap CSA and have been very happy with the results.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 51,870
    Bleiz wrote: »
    That guy is clueless.
