Linlai E 6sn7 tubes
  • GlennDog
    GlennDog Posts: 3,158
    edited April 2024
    Toolfan66 wrote: »
    If I may ask, is there a reason for the Input Level controls (2 far right knobs) to be at the 12 o'clock position and not fully rotated clockwise . . . so that they are completely out of the signal path.
    Obviously, they serve a purpose. but, I think most would benefit from full CW rotation ... improved SQ
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    Toolfan66 Posts: 18,251
    GlennDog wrote: »
    Toolfan66 wrote: »
    12 o’clock is fully rotated..
  • TEAforONE
    TEAforONE Posts: 1,086
    treitz3 wrote: »
    TEAforONE wrote: »
    I just ordered a pair. Now for the long wait……
    Good afternoon to you. How long of a wait, if you don't mind me asking?
    Also, what is the height of the tube from the bottom of the base to the top of the tube (if you know)?
    Hi Tom,
    If my memory is functioning,I think under 2 weeks coming from China. I currently have 2 pair. Both ordered from the same EBay vendor,both are well broke in,both sound great with my Aric Audio Motherlode II pre.
    I see the dimensions have already been posted. They are on the large side.
    Ray
  • GlennDog
    Toolfan66 wrote: »
    GlennDog wrote: »
    Toolfan66 wrote: »
    Interesting… it’s definitely a cleaner look than the older style. It was a little confusing at first because I assumed 12 o’clock was the “proper/best” position ….
    then I tried fully rotated clockwise… Much better.
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    treitz3 Posts: 20,174
    Thanks for answering my queries, Ray and Larry.
  • Toolfan66 wrote: »
    I would be interested in hearing your impressions as well as you learn the strengths and weakness of the Linlai tubes.
    I also have the SLP-05 and after a significant DAC upgrade this winter I am now in the position of deciding whether to upgrade from the EH stock tubes that came with the Cary, or just run direct into the amp and sell the pre. Removing the pre from the signal path unveils the whole frequency range, not in a huge way but it is noticeable and I prefer the cleaner presentation. While there is some added warmth and increased size of presentation with the pre, I can't unhear the distortion now either. :#
    Where would you place the Linlai's in terms of tube warmth, clean and accurate presentation, and prat? Are they fairly neutral or do they have a noticeable character?
    Thanks for your time and the pic, they definitely are big globes! Very Splashy...
    /Waffle
    I have a friend who did just that and he regrets it. (Losing the Cary pre and going direct to amp) FWIW.
  • treitz3 wrote: »
    Appreciate the input Tom. I agree it isn't a decision to take lightly.
    /Waffle
    VR3 Posts: 29,598
    If you are only running one source I dont see the benefit of a preamp.
    Tubes bro'.
    VR3 Posts: 29,598
    edited May 2024
    tube dac bruh! :-D
    Still......
