Anyone own a Krell 2250 or 3250?
If you are using a single ended preamp you have to have the shorting pins between pins 1and 3 on the XLR connectors. I found this out with my ksa 300s that didn't have the shorting pins when I bought it used.
Is a remote mandatory?
Yes for sure. Balanced in and outs would be nice but not required. -
I'm using RCA through the entire system. CD player to pre to amp. My pre amp has no XLR. But the disc player does. That's why I kind of want a XLR pre amp.
Anyways, so if I'm using all RCA connections I should have a jumper in the XLR on the amp?
I'll look over the owners manual again but I don't recall seeing that being addressed. 🤔
Thanks man -
So if I'm using all RCA connections I should have a jumper in the XLR on the amp?
Yes.The amplifier is shipped with shorting pins in the XLR inputs. These pins should remain
in the XLR inputs if the amplifier is operating in the single-ended mode. When the
shorting pin is inserted, pins 1 (lower left) and 3 (top) are shorted together. Remove the
shorting pins to connect the amplifier for balanced operation.
The XLR pin configuration is described below:
Pin 1 Shield (ground)
Pin 2 Non-inverting (hot) (0°)
Pin 3 Inverting (cold) (180°)
Follow these steps to connect the amplifier to your system.
Directly from the owners manual, page 11
https://www.krellhifi.com/wp-content/uploads/2020/04/Krell_KAV2250_3250_Owners_Reference.pdf -
The anemic sound you are hearing could be the amp design. It could also be the tubes being used in the pre. Others here would know more about which to try for better bass.Gustard X26 Pro DAC
It’s the amp… get that one to a tech and have it checked out. I firmly believe there is something damaged internally due to shipping. Krell and their mass do not hold up well with poor packaging.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »It’s the amp… get that one to a tech and have it checked out. I firmly believe there is something damaged internally due to shipping. Krell and their mass do not hold up well with poor packaging.
We don't even know if he has the shorting pins, which will definitely make it sound the way he is describing. -
There are no pins in place for sure. I'll order some today. Any reason I can make my own? Like a piece of solid core 18 awg copper wire? I mean just until the jumpers get here. -
Should work fine
Awesome catch man. Thank u very much! -
Anytime, glad I could help. You can buy the cardas shorting pins for about $4.00 each from moon audio or music direct. -
I ordered 4 of them from Music Direct an hour ago. Will be a few days.
In the mean time it looks like I'll need 10 awg wire. That I actually have some solid core I can shpe into a "U".
.116 is the thickness of the Cardas pins.
Funny that the first two reviews are about Krell amps.
I swapped in a new C19 20 amp power cord. Plugged directly into the same outlet as before. Still a hum. Then plugged it into the Belkin power conditioner from a separate plug (same circuit though) and still a hum. Like before the hum only happens when I attach the RCA. And only to the same channels the speakers are plugged into. I have a 3rd channel with no speaker hooked to it. If I only put an RCA on that channel (and that channel alone) there is no hum. So only when an rca is connected to a channel with a. Speaker on it does it hum.
Im just going to wait until the jumpers get here for the XLR inputs. I could not find my 10 awg solid wire to diy it. I'll just wait. I'm really hoping the jumpers solve both issues. The hum and the anemic sound. -
Try a cheater plug... not a permanent fix but might shed some light on your issue.
Hey Chris. I have the National tubes (believe I recommended when u bought the pre). Not my #1 pick in the BHK but a solid tube. FWIW, I've never found them to be anemic/thin. Did I send you the correspondence w/Jeff, owner of Sonicraft, re. the values I used on the upgraded Mundorf Silver Oil caps?
I'm skiing right now....actually having lunch in the bar...so, am going from memory. He discussed the Mundorf values(?) vs the Parasound 1500A and Sunfire 300x2 I paired w/the Anthem. Perhaps, there's something to this and the Krell's thin sound you describe....however, not the hum. LMK if you want the emails....also, just remembered, he looked over the Anthem schematics when he talked values.➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
Id definitely like to see the emails. The more info I can get the better. I appreciate it.
When I took a nap today I dreamt that I could hear the music through the volume pot. Like literally put my ear into the case and hear music in the pot. 😆. What's that about?.
Anyways. I'll get the jumper pins in the XLR next and go from there. I'll try a the RCA connected to other components and different outlets. Will try and extension cord on a separate breaker.
I'm betting the pins take care of the problem.
There’s gotta be a loop somewhereMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
Got it. Thanks so much. -
Krell is known for their deep bass. I am betting the amp has issues. IMHO, I'd get the amp sorted out before buying a new pre. You shouldn't need tone controls to listen to the combo you have. Tubes will also influence the bass to a degree, but not so much how you describe.
P.s the shorting PINS will most likely help in a big way. Hope it solves all issue including the lower output tube side."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
National is not a tube maker, they rebrand all kind of tubes from everywhere including Russian tubes. Maybe post some photo's or if there are any manufacturer codes we can help you determine what they are so you can look for another pair or a single.
I'll post some pics when I get home today. Thanks. The pins should be here Monday. I also ordered some IFI power supplies for my Blu Zen and Zen Phono. I'm hoping everything comes to get her after the pins get installed.
Bro!!!!!... You nailed it. I got the Caradas pins from Music Direct today. Turned on the amp again and the hum was still there. Even with the preamp off. Plugged in the pins and started it back up.
No hum at all. No hiss at all. Even with my ear UPTO the tweeter, there is zero noise. I'm very happy right now. Just played some quick YouTube music from my phone to the ifi Blue Zen and it sound very nice. The imaging is incredible. I know my center speaker is not hooked up. I know the sound is not coming through the TV. But I still had to get up and check the center channel. Johnny Cash's voice...I swear was dead center. Also, I noticed that I seem to be able to get more bass from the RTA-12Bs. Maybe a placebo effect? But they went louder and tighter than I've ever heard before. At least from them. I switched over to the Marantz 7007 player and put Maxwell Embrya on. Normal CD. Nothing special. And wow. I'll run some SACD and DVD-Audio later. Can't wait to get my record player up and running. Have a new stylus to install and calibrate. Something I've never done before.
I'll put the National tubes back in later and see if the earlier problem I had persists.
Great news! I don't think the better bass is placebo, that amp has a pretty robust power supply.
It just seems like it better control??? Can and amp have better control over the voice coil ? Like, not just push it out but the ability to pull it in??? Or am I crazy? -
Yes, I believe they call that dampening factor -
I felt like this set up is too bright. I thought maybe it was the caps I used in the 12Bs. So I put some infinity Primus 363s in place. They are even brighter. Like one song in with the infinity 363 and I'm done. Ready to listen to the TV.
