XS-Dreadnaught
    msg Posts: 9,522
    msg wrote: »
    Bomb parts...... they love that comment....
    How To Toughen Your Feet For Getting Midnight Run'd.
    I meant Midnight Express.
    xschop Posts: 4,730
    TMI
    xschop Posts: 4,730
    edited March 7
    Ok @msg, back on it today... 29/32" is perfect for a Neutrik slip-fit...
    Took another .080" off lock-down spoke so the lid bottom clears without touching...
    Went back and put a 1/64" chamfer on the lid. Next will grind off Neutrik square tabs and install with soldered fast-ons....
    Post edited by xschop on
    msg Posts: 9,522
    Beautiful.
    Are you thinking about making these? Definitely looks like a lot of time.
    Toolfan66 Posts: 16,958
    msg wrote: »
    Beautiful.
    That is a pricey project..
    xschop Posts: 4,730
    Thanks. I have enough materials to build an identical one. May be awhile before I can do another. Very time consuming.
    xschop Posts: 4,730
    edited March 14
    Working on the XS-Dreadnaught's companion boards. Will mount externally to the XS-8TL's when done....
    Measuring the Neutriks depth, Ill have to machine 1" dia alloys that are 0.75" long so the wiring will clear....
    msg Posts: 9,522
    Is that wooden metal? Never seen that stuff before.
    VR3 Posts: 28,122
    Surprised you used an iron core? Just curious since an air core wouldn't cost that much more in the end?
    xschop Posts: 4,730
    They're all air cores, just made acetal inserts for the 2.5mH inductors.
    Thinking about machining cylindrical resistor heat radiators for them too.
    Would it be ok to lower the small tweeter inductor to the opposite end of the board running same direction?
    VR3 Posts: 28,122
    I don't think you would experience any issues putting the tweeter inductor down lower.
    I understand now, I like it, good stuff
    xschop Posts: 4,730
    edited March 15
    VR3 wrote: »
    This would be easier to wire everything up and have the Neutrik right next to the TeCu posts....
    VR3 Posts: 28,122
    I would space the flat could farther apart... 6 inches if you can
    xschop Posts: 4,730
    Like so? I can still get the Neutrik where I need it.
    VR3 Posts: 28,122
    Yes that's what I would go with
    xschop Posts: 4,730
    Thanks Trey.
    What caps are those?
    msg Posts: 9,522
    VR3 wrote: »
    Speak inglish Trey! You're just saying any old words.
    VR3 Posts: 28,122
    Wait you don't speak auto-correctian?
    msg Posts: 9,522
    That one was a little two advantzd four me.
    xschop Posts: 4,730
    Toolfan66 wrote: »
    I owed @VSAT88 a Silver Dragon mod LMAO.
    xschop wrote: »
    Toolfan66 wrote: »
    You should have anodized them first..😅
    xschop Posts: 4,730
    edited March 16
    All that electron delivered pigment would surely ruin their harmonics :p
    Still thinking on what fastener to use on the rear of the board to attach the driver cables before I break out the Cardas-Quad....Hmmm
    xschop Posts: 4,730
    Does the factory IC actually make the connection between the Blades on the CRS+ crossovers?
    VR3 Posts: 28,122
    I always connect the blade to ground
    xschop Posts: 4,730
    I meant was the IC connecting L to R blades in a closed circuit.
    pitdogg2 Posts: 24,635
    xschop wrote: »
    Are you referring to a blade/Blade socket cable?
    VR3 Posts: 28,122
    The latter generations is not reversed between the left and right
    xschop Posts: 4,730
    xschop wrote: »
    No, I'm asking about the factory pin/blade IC cable itself. If the blades are actually used (closed) and transfer signal like the pins do.
    VR3 Posts: 28,122
    edited March 18
    They do and they don't.
    The way the speakers work the signal is connected thru the negative speaker terminals, hence the requirements for a common ground amplifier
    Connecting the blade to ground is redundant but I still prefer to use it
