XS-Dreadnaught
TMIDon't take experimental gene therapies from known eugenicists.
Ok @msg, back on it today... 29/32" is perfect for a Neutrik slip-fit...
Took another .080" off lock-down spoke so the lid bottom clears without touching...
Went back and put a 1/64" chamfer on the lid. Next will grind off Neutrik square tabs and install with soldered fast-ons....
Post edited by xschop onDon't take experimental gene therapies from known eugenicists. -
Beautiful.
Are you thinking about making these? Definitely looks like a lot of time.I disabled signatures. -
Beautiful.
That is a pricey project.. -
Thanks. I have enough materials to build an identical one. May be awhile before I can do another. Very time consuming.Don't take experimental gene therapies from known eugenicists.
Working on the XS-Dreadnaught's companion boards. Will mount externally to the XS-8TL's when done....
Measuring the Neutriks depth, Ill have to machine 1" dia alloys that are 0.75" long so the wiring will clear....
Is that wooden metal? Never seen that stuff before.I disabled signatures.
Surprised you used an iron core? Just curious since an air core wouldn't cost that much more in the end?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
They're all air cores, just made acetal inserts for the 2.5mH inductors.
Thinking about machining cylindrical resistor heat radiators for them too.
Would it be ok to lower the small tweeter inductor to the opposite end of the board running same direction?Don't take experimental gene therapies from known eugenicists. -
I don't think you would experience any issues putting the tweeter inductor down lower.
I understand now, I like it, good stuff- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
This would be easier to wire everything up and have the Neutrik right next to the TeCu posts....
I would space the flat could farther apart... 6 inches if you can- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Like so? I can still get the Neutrik where I need it.
Yes that's what I would go with- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Thanks Trey.Don't take experimental gene therapies from known eugenicists.
What caps are those?
Speak inglish Trey! You're just saying any old words.
Wait you don't speak auto-correctian?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
That one was a little two advantzd four me.I disabled signatures.
You should have anodized them first..😅 -
All that electron delivered pigment would surely ruin their harmonics
Still thinking on what fastener to use on the rear of the board to attach the driver cables before I break out the Cardas-Quad....HmmmDon't take experimental gene therapies from known eugenicists. -
Does the factory IC actually make the connection between the Blades on the CRS+ crossovers?Don't take experimental gene therapies from known eugenicists.
I always connect the blade to ground- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I meant was the IC connecting L to R blades in a closed circuit.Don't take experimental gene therapies from known eugenicists.
Are you referring to a blade/Blade socket cable? -
The latter generations is not reversed between the left and right- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
No, I'm asking about the factory pin/blade IC cable itself. If the blades are actually used (closed) and transfer signal like the pins do.Don't take experimental gene therapies from known eugenicists. -
They do and they don't.
The way the speakers work the signal is connected thru the negative speaker terminals, hence the requirements for a common ground amplifier
Connecting the blade to ground is redundant but I still prefer to use it- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
