You’re doing it wrong…
mhardy6647 wrote: »looks like EuroDates
I look at the date. Are Euro dates that F'd up?
I mean, given time in the whole grand scheme of things.... BF and AC.
It kind of sets the whole date thing worldwide in to sync....don't you think?
NM, this is getting deep. I could care less....
Someone or some country is doing it wrong as I see it.
― Aleksandr Solzhenitsyn -
Jed Clampett was here.
Is that a buffet? If not, IT IS now!!1
nom nom nom ....appetizer....
whatever tickles your fancy, I guess.
I mean, I figured it all along.I disabled signatures. -
If you know, you know…;-)
To add to this….
Did you know we were building nuclear engines to power aircraft?
My brother standing between two….. -
You all should come over, we can hang out on the deck..
I'm sure that retaining wall built up against that brick wall was a real good idea as well..
Those deck supports aren't anywhere near as sad as that sidewalk to nowhere.
I think it will hold a hot tub- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
What's wrong? They used a couple of bolts.I disabled signatures.
And (surprisingly) footers.
Brian
One-owner Polk Audio RTA 15TL speakers refreshed w/ Sonicap, Vishay/Mills and Cardas components by "pitdogg2," "xschop" billet tweeter plates and BH5 | Stereo REL Acoustics T/5x subwoofers w/ Bassline Blue cables | Rogue Audio Cronus Magnum III integrated tube amp | Technics SL-1210G turntable w/ Ortofon 2M Black LVB 250 MM cart | Teac VRDS-701T CD transport | LampizatOr Baltic 4 tube DAC | Nordost & DH Labs cables/interconnects | APC H15 Power Conditioner | GIK Acoustics room treatments | Degritter RCM -
I can imagine someone walking out on that. I'm surprised a neighbor hasn't called code enforcement officer. I'm not one to dry rat on someone, but I sure would hate to see that come down with someone on it. Heck if there was a fire I'd jump out the window next to it, which is higher lmaoRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Would you truly hate to see it, Randy?boston1450 wrote: »I can imagine someone walking out on that. I'm surprised a neighbor hasn't called code enforcement officer. I'm not one to dry rat on someone, but I sure would hate to see that come down with someone on it. Heck if there was a fire I'd jump out the window next to it, which is higher lmao
I mean, I can think of some people I'd like to lure out there. You know, for the view. The brief view.
Yeah my ex wife & her new husband. Joking. He's a nice guyRandy-Maine
by David WMG
That one going over the driveshaft is probably for the coffee maker.
That's the sway bar.Political Correctness'.........defined
President of Club Polk -
It's awesome that an audio dude think that's a big, thick ol' power cable, though! 😂👍
Brian
I think that's a power cord he ran inside a rubber hose to go around the driveshaft. Usually swaybars are not curved like that and are forward of the front differential. But if you have personal knowledge of a vehicle with this configuration, I stand corrected.Gustard X26 Pro DAC
No idea what that vehicle is, but that is definitely a sway bar. That outlet box has 3 molded plug heads and 1 larger head plugged into it. The bar continues on past the box. Also, there is nowhere else to mount a sway bar that wouldn't get ripped off due to hanging down too far.Political Correctness'.........defined
I am thinking it may be some sort of conduit pipe running power to the box. It appears to enter the box between the two top outletsThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
https://www.youtube.com/watch?v=7fMNganQ-z0
