You’re doing it wrong…
1…2223252728…127
  • skipshot12
    skipshot12 Posts: 2,173
    daddyjt wrote: »
    If you know, you know…;-)
    To add to this….
    Did you know we were building nuclear engines to power aircraft?
    My brother standing between two…..
    Viking64 Posts: 7,834
    Those deck supports aren't anywhere near as sad as that sidewalk to nowhere. :'(
    VR3 Posts: 29,762
    I think it will hold a hot tub
    msg Posts: 10,650
    What's wrong? They used a couple of bolts.
  • boston1450
    boston1450 Posts: 7,759
    I can imagine someone walking out on that. I'm surprised a neighbor hasn't called code enforcement officer. I'm not one to dry rat on someone, but I sure would hate to see that come down with someone on it. Heck if there was a fire I'd jump out the window next to it, which is higher lmao
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    msg Posts: 10,650
    msg wrote: »
    Oh...
    msg Posts: 10,650
    boston1450 wrote: »
    Would you truly hate to see it, Randy?
    I mean, I can think of some people I'd like to lure out there. You know, for the view. The brief view.
  • boston1450
    Yeah my ex wife & her new husband. Joking. He's a nice guy
    Randy-Maine
    by David WMG
  • daddyjt
    daddyjt Posts: 3,268
    ― Aleksandr Solzhenitsyn
    audioluvr Posts: 6,079
    That one going over the driveshaft is probably for the coffee maker.
    pitdogg2 Posts: 27,917
    daddyjt wrote: »
    WTF???
    F1nut Posts: 52,406
    audioluvr wrote: »
    That's the sway bar.
  • ken brydson
    ken brydson Posts: 9,107
    Drive with cake = James Brown approved
    https://www.youtube.com/watch?v=7fMNganQ-z0
    edited January 2024
    audioluvr wrote: »
    I think that's a power cord he ran inside a rubber hose to go around the driveshaft. Usually swaybars are not curved like that and are forward of the front differential. But if you have personal knowledge of a vehicle with this configuration, I stand corrected.
    F1nut Posts: 52,406
    No idea what that vehicle is, but that is definitely a sway bar. That outlet box has 3 molded plug heads and 1 larger head plugged into it. The bar continues on past the box. Also, there is nowhere else to mount a sway bar that wouldn't get ripped off due to hanging down too far.
    nooshinjohn Posts: 26,181
    I am thinking it may be some sort of conduit pipe running power to the box. It appears to enter the box between the two top outlets
    F1nut Posts: 52,406
    msg Posts: 10,650
    You're all wrong. It's clearly a black licorice rope that the owner set down for a second to take the photo.
  • boston1450
    Looks like a stabilizer bar AKA sway bar. Can be on front or rear near both differentials.. The hack job has plug ends in it. No idea wtf that is
    Randy-Maine
    by David WMG
  • boston1450
    If you look you can see cord that is plugged in NEXT to the stabilizer bargo99ptur9bsj.png
    Randy-Maine
    by David WMG
    txcoastal1 Posts: 13,520
    ALL WRONG.....!!!!!
    https://youtu.be/CFdJza0AbeA
  • motorstereo
    motorstereo Posts: 2,428
    At least he had it chained down well enough
    F1nut Posts: 52,406
    Gonna need a bigger trailer
    That is some serious wood!
    msg Posts: 10,650
    Should justa put it on the roof rack. Coulda saved his trailer. Some people just don't think.
  • ken brydson
    That's what she said 🤣
  • agfrost
    agfrost Posts: 2,497
    daddyjt wrote: »
    Kick that guy out of the Snake River demo.
    Jay
  • sucks2beme
    sucks2beme Posts: 5,703
    Looks like the trailer my next door neighbor had, minus the wood.
    He finally moved out. I don't know how the landlord got rid of the
    thing. It was NOT road worthy. Good news it's been a few months
    and he can't find a tenant. Maybe he'll sell it and a real home owner
    will move in.
    I found a discussion on Reddit about that junction box under the car which includes a high-resolution pic.
    Apparently it is common in cold climates to have such a set-up for various 110V heaters (engine block/oil pan, transmission, fuel/fuel tank, battery blanket, etc.).
    https://www.reddit.com/r/Justrolledintotheshop/comments/ygm0ve/ive_never_seen_a_car_that_failed_a_home/
    The rubber hose over the driveshaft is going to the oil pan. If you look closely on a big screen, you can see a slit in the hose where the upper-right cord comes out and you can even see the end of the hose butting up against the rusty cover plate on the junction box.
