You’re doing it wrong…
12324262829108
    treitz3 Posts: 19,945
    looks like EuroDates :)
    I look at the date. Are Euro dates that F'd up?
    I mean, given time in the whole grand scheme of things.... BF and AC.
    It kind of sets the whole date thing worldwide in to sync....don't you think?
    NM, this is getting deep. I could care less....
    Someone or some country is doing it wrong as I see it.
  • daddyjt
    daddyjt Posts: 3,029
    ― Aleksandr Solzhenitsyn
  • daddyjt
    Viking64 Posts: 7,508
    Jed Clampett was here.
    pitdogg2 Posts: 26,934
    Is that a buffet? If not, IT IS now!!1
    "You been heeya fowa owa! You go now!"
    nom nom nom ....appetizer....
    msg Posts: 10,451
    edited January 2024
    whatever tickles your fancy, I guess.
    I mean, I figured it all along.
  • skipshot12
    skipshot12 Posts: 1,805
    daddyjt wrote: »
    If you know, you know…;-)
    To add to this….
    Did you know we were building nuclear engines to power aircraft?
    My brother standing between two…..
    Toolfan66 Posts: 17,985
    edited January 2024
    You all should come over, we can hang out on the deck..
    I'm sure that retaining wall built up against that brick wall was a real good idea as well..
    Those deck supports aren't anywhere near as sad as that sidewalk to nowhere. :'(
    VR3 Posts: 29,388
    I think it will hold a hot tub
    msg Posts: 10,451
    What's wrong? They used a couple of bolts.
  • bcwsrt
    bcwsrt Posts: 2,373
    And (surprisingly) footers.
    Brian
    One-owner Polk Audio RTA 15TL speakers refreshed w/ Sonicap, Vishay/Mills and Cardas components by "pitdogg2," "xschop" billet tweeter plates and BH5 | Stereo REL Acoustics T/5x subwoofers w/ Bassline Blue cables | Rogue Audio Cronus Magnum III integrated tube amp | Technics SL-1210G turntable w/ Ortofon 2M Black LVB 250 MM cart | Teac VRDS-701T CD transport | LampizatOr Baltic 4 tube DAC | Nordost & DH Labs cables/interconnects | APC H15 Power Conditioner | GIK Acoustics room treatments | Degritter RCM
  • boston1450
    boston1450 Posts: 7,758
    I can imagine someone walking out on that. I'm surprised a neighbor hasn't called code enforcement officer. I'm not one to dry rat on someone, but I sure would hate to see that come down with someone on it. Heck if there was a fire I'd jump out the window next to it, which is higher lmao
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    msg Posts: 10,451
    msg wrote: »
    Oh...
    msg Posts: 10,451
    boston1450 wrote: »
    Would you truly hate to see it, Randy?
    I mean, I can think of some people I'd like to lure out there. You know, for the view. The brief view.
  • boston1450
    Yeah my ex wife & her new husband. Joking. He's a nice guy
    Randy-Maine
    by David WMG
  • daddyjt
    audioluvr Posts: 5,877
    That one going over the driveshaft is probably for the coffee maker.
    F1nut Posts: 51,678
    audioluvr wrote: »
    That's the sway bar.
  • bcwsrt
    bcwsrt Posts: 2,373
    audioluvr wrote: »
    It's awesome that an audio dude think that's a big, thick ol' power cable, though! 😂👍
    Brian
    edited January 2024
    audioluvr wrote: »
    I think that's a power cord he ran inside a rubber hose to go around the driveshaft. Usually swaybars are not curved like that and are forward of the front differential. But if you have personal knowledge of a vehicle with this configuration, I stand corrected.
    F1nut Posts: 51,678
    No idea what that vehicle is, but that is definitely a sway bar. That outlet box has 3 molded plug heads and 1 larger head plugged into it. The bar continues on past the box. Also, there is nowhere else to mount a sway bar that wouldn't get ripped off due to hanging down too far.
    nooshinjohn Posts: 25,879
    I am thinking it may be some sort of conduit pipe running power to the box. It appears to enter the box between the two top outlets
