Stupid Question: Why are they called "5-way" binding posts?
    msg Posts: 10,650
    invalid wrote: »
    My amp has 1 way binding posts.
    Output only
    txcoastal1 wrote: »
    At least you don't own a 5-way tire tool
    But it sounds like I should?
  • Geoff4rfc
    Geoff4rfc Posts: 3,053
    mantis wrote: »
    The correct answer is banana, spade, pin, bare wire and alligator clips.
    WRONG,
    dual banana is the correct answer
    bare wire , Spade , Pins , banana and DUAL BANANA , this is what makes a 5 way binding post a 5 way binding post. You don't use Alligator clips for speakers. Could you? Sure but it's not technically the reason a 5 way binding post is called a 5 way binding post. Who told you that?
    I use alligator clips padded with rubber bands for soldering at the terminating end of the speaker cable B)
    Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3
  • invalid
    invalid Posts: 1,559
    Geoff4rfc wrote: »
    mantis wrote: »
    WRONG,
    Dual banana post is incorrect
  • Geoff4rfc
    invalid wrote: »
    Geoff4rfc wrote: »
    mantis wrote: »
    WRONG,
    Ummm, you must be referring to earlier posts.....I don't play with dual banana posts :D
    mhardy6647 Posts: 35,562
    Something of a banana post duel brewing here? B)
    I remember feeling so powerful when I grabbed a couple of surplus :# Pomona dual banana plugs from JHU and installed them on the speaker wires for my Polk Monitor 7As ca. 1978. I still have those banana plugs, too. They're on the "home theater" system (which also contained the Polks until we moved to House 4.0 in 2013) in the den to this day. :)
  • Geoff4rfc
    '78 ???? Dang dude....I was just learning how to salute over at Lackland AFB as a young lad at 18. You've been with Polk a L O N G time, and now, I salute you!!
    Geoff4rfc wrote: »
    I mean... everybody kept purchase receipts from 1978... right? Right?! :#:blush:
  • invalid
    Geoff4rfc wrote: »
    Maybe you can return them.
    invalid wrote: »
    Geoff4rfc wrote: »
    Why would I? B)
    treitz3 Posts: 20,359
    Because they can't connect to wi-fi, of course!
  • bcwsrt
    bcwsrt Posts: 2,688
    That’s awesome!
    Brian
  • Geoff4rfc
    Geoff4rfc wrote: »
    I wonder if that 10% restoring charge would still stand :#
    Geoff4rfc wrote: »
    Geoff4rfc wrote: »
    John Dorsey's a good guy -- he'd probably let it slide. :)
  • SeleniumFalcon
    It looks like Len Bradford was your salesperson.
    edited October 2023
    He was indeed per the receipt. I actually remember John as having done the deed, so when I dug that receipt out a few years back (to post here), I was surprised to see Len's name on the receipt.
    I do know Len sold me my Philips AF877 - about a year later. I remember hanging around for quite a while as he set up the cartridge. Len was quite the perfectionist. Hangin' out at Soundscape was never a bother, though. :)
    In those days, it was John & his two brothers and Len at Soundscape. I think brother Ed was usually at the Park Radio store (which was still operating then). Their father Lee Dorsey founded Park Radio a long ways back now. EDIT: I am thinkin' 1948... but my memory's gettin' pretty flammable, umm I mean fallible.
  • SeleniumFalcon
    Len was certainly the consummate audio expert and music enthusiast. I met him when I started working at Gramophone and we became good friends.
  • vocalkeny
    I am just picked up some spades.
  • PSOVLSK
    PSOVLSK Posts: 5,448
    11 years of five way binding posts.
    Make that 12 years🤣🤣🤣
  • gmcman
    gmcman Posts: 1,874
    The fifth way may be the two options for bare wire.
    That's how I understood it. Through the hole with bare wire is one, solid metal post through hole is two, then wire wrapped around post, banana, & spade.
  • kevhed72
    kevhed72 Posts: 5,229
    edited March 2024
    Does the dual banana go in the same hole used for bare wire....then you are counting 1 hole as two...really making it a 4 way binding post.
  • gmcman
    gmcman Posts: 1,874
    edited March 2024
    kevhed72 wrote: »
    How would a dual banana go in the same hole as a wire? ;)
    Clipdat Posts: 13,104
    I'm reporting all these insanely graphic sexually explicit posts. Enjoy your bans.
    VR3 Posts: 29,748
    Bare wire
    Pins
    Spades
    Banana
    Eyelet
    Viking64 Posts: 7,812
    eyeletafart
    Eyelet -- Piglet and Eeyore's love child?
    VR3 Posts: 29,748
    Lol how about ring connector
  • kevhed72
    kevhed72 wrote: »
    (smacks forehead)
    The dual bananas are the width of a standard spacing of the binding posts. They go into the end like EVERY other banana plug....
    Oh....I get it. Still the same "openings" as regular bananas (as not to offend some with graphic details). Im still sticking to my 4 way binding post nomenclature though!
