Lets talk Sample rates.
  • ChrisD06
    ChrisD06 Posts: 929
    Measure ? Why not use the best measuring device made, your ears?
    Because ears aren't reliable due to the brain. The brain is a very cool meat computer but it can get pretty messed up. Was it Monster who made people think their cables were better simply by turning the volume up a few decibels?
    Either way, the ears alone are reliable, but the brain isn't, and it can be subtly subconsciously tricked too easily for me to consider my subjective testing good enough to be fact.
    My gear:
    • TCL 75QM7K TV
    • Onyko TX-NR656 AVR
    • RT3000p Fronts
    • CS1000p Center
    • RT35 Side Surrounds
    • RT35 Rear Surrounds
  • ChrisD06
    ChrisD06 Posts: 929
    edited October 20
    You’re contradicting yourself, aren’t you? How can you be sure you heard differences in the various caps, then?
    Good point. I suppose the only real argument I could give is that with cables I'm testing frequency response, the capacitors actually gave entirely new detail and let me hear parts of the song I genuinely couldn't before (I did do a comparison side by side with the old board).
    I can't necessarily say I genuinely did though, it really could be placebo. I do know that the parts needed replacing anyways because they were like 35 years old and would be drifting out of tolerance anyways. So even if it were placebo I can still justify the new high quality components.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    F1nut Posts: 52,406
    More like talking out his a$$.
  • ChrisD06
    ChrisD06 Posts: 929
    edited October 20
    ChrisD06 wrote: »
    Hmm, so I've come to an epiphany.
    If cables (conductors) don't affect sound, then how on earth do capacitors affect sound (which I've personally heard the massive differences they do make)?
    ChrisD06 wrote: »
    Now you’re talking in circles.
    Carry on …
    Yeah it's entirely contradictory, I've acknowledged that. I'm just saying that I'm open to the fact that it's placebo. I mean, hey, wouldn't it be funny if I was wrong?
    I hear a difference, yet it might be my brain playing tricks on me. Seems to make sense to me. My perception might be different than the objective truth. So what? I could have worded it better but you know what I meant.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • ChrisD06
    ChrisD06 Posts: 929
    edited October 20
    No, I massively, entirely, genuinely don’t know what you meant.
    You either heard with your own two ears (and, yes, brain) differences you described with those adjectives/adverbs, or it was placebo.
    Which one?
    Having a little trouble are we? I believe I heard with my ears, but it also could have been placebo.
    If you need an analogy Id be happy to provide one
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • tophatjohnny
    tophatjohnny Posts: 4,189
    I’ve seen some piss threads here but this one has gots to be the yellowist mine eyes have laid their balls upon! 😳
  • invalid
    invalid Posts: 1,559
    edited October 20
    ChrisD06 wrote: »
    ChrisD06 wrote: »
    ChrisD06 wrote: »
    Carry on …
    Just buy a cheap system and tell yourself it sounds better than anything you've ever heard.
    Viking64 Posts: 7,817
    treitz3 Posts: 20,363
    VR3 Posts: 29,752
    All gear actually sounds the same, it's just the sampling that makes the difference
    Ymmv
    msg Posts: 10,650
    Yeah, but you can't hear the difference between 44.1kHz and AM radio.
  • HzTweaker
    HzTweaker Posts: 1,136
    "All gear actually sounds the same, it's just the sampling that makes the difference
    Ymmv"
    So on that note, I was looking for identical albums on HDtracks that I could get in different SRs. I got distracted when looking for music that I'm Familiar with and found this: https://www.hdtracks.com/#/album/5debab08f73cc8ae84d3332e . I'm a huge fan of Radiohead and lately cover tunes. It comes in two different SRs and bit depths.
    2ch rig: Speakers: LSi9s with VR3's Fortress mods Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
    Standby: Magnepan LRS w/Magna Riser stands
    msg Posts: 10,650
    Interesting. I like a couple of those Radiohead tracks. A bit pleasantly-melancholy/haunting. Is that that singer's vocal style?
    When you buy music on HDTracks, if you buy higher resolution, do you also have access to lower resolution, or are those separate purchases?
  • HzTweaker
    edited October 2023
    msg wrote: »
    You know your question has got me thinking. Couldn't I Take an album in 192Khz and down sample it step by step? I'm thinking I could save some $$ by not having to buy the same album over and over, just make the devices do all the work?
  • HzTweaker
    My experience With downloaded hi-res is that it's only in the SR/BD that is downloaded in.
    msg Posts: 10,650
    HzTweaker wrote: »
    msg wrote: »
    Yeah, you can. I wonder what they use to create lower resolution versions, and whether it matters. I'm sure somewhere there's an argument about this on both sides.
    I'm not familiar enough with this process. Are there music processing engines that are better than others?
    Would you be able to tell the difference if you just downsampled in Audacity or CoolEditPro? (is that even around anymore?)
    I suppose you could convert a track and then compare the waveform to a downloaded one for a visual sense as well as what you hear? Not sure any of those tools would be definitive.
    Reminds me of a discussion about cables some time ago. I came across a vendor or manufacturer a while back who proposed using a "difference" wave or file or something. I forget what it was called, but it involved taking a recording of playback output from a particular set of parameters, and overlaying that recording on another one, capturing the diffence data to a new track. In theory, this would give you an audio recording of what is different between a control and test track.
    I did this, and it actually, works, however there's a glaring question of timing, and how sensitive the ear is to offset.
    See, the tracks have to be overlaid at the exact same point of start. Audacity, I think, was only accurate to hundredths or thousandths of a second, so while there was difference data between recordings from two tracks, I couldn't be sure whether it was "missing" information, or simply delay offset data, or maybe both.
    It was interesting, though. I'll try to find that thread.
    (*written on stupid mobile. any typos are my fault, but I don't effing care anymore)
  • invalid
    According to a study conducted by Aalto University and genelac, the human ear can detect timing anomalies to a half a millisecond.
  • jbreezy5
    jbreezy5 Posts: 1,141
    edited October 20
    ChrisD06 wrote: »
    ChrisD06 wrote: »
    ChrisD06 wrote: »
    Carry on …
    Have you heard of the law of non-contradiction?
    Or… that “a double-minded man is unstable in all his ways?” (James 1:7,8)
    At this point, you’re on your own kid.
    msg Posts: 10,650
    Good info. I suspected as much - not necessarily those specifics, exactly, but that a fine degree of offset would be detectable.
    Can we get back to goats?
    invalid wrote: »
    This should be why very minute speaker movement (assuming proper setup) can be so drastic in the changes.
    msg Posts: 10,650
  • invalid
    treitz3 wrote: »
    invalid wrote: »
    That is true, I never thought of that.
  • HzTweaker
    treitz3 wrote: »
    invalid wrote: »
    Not to mention the design of time alignment in some speakers.
    F1nut Posts: 52,406
    Viking64 wrote: »
    No
    Viking64 wrote: »
    No
    Donkeys?
    edited October 20
    Hot sauce!
    So . . . . MALE donkeys. Got it.
    msg Posts: 10,650
    This thread's got it all! It's like its own microforum!
  • FTGV
    FTGV Posts: 3,650
    Viking64 wrote: »
    Brady, Gretzky, Senna, Nicklaus, Petty, Reagan
    SCompRacer Posts: 9,400
    Hi Fred!
