sda srs 2.3 polyswitch removal
I have the sda 2.3 speakers, serial# - SRS 2.3 L 3955, they have always sounded muffled with no treble - am wanting to remove the polyswitches as some members have suggested. I am trying to identify them correctly - is a schematic available for the crossover or is a part number available. Pictures would be great - I'll take anything! Already modded the crossovers with new audio film capacitors - made no difference to the sound. Wanting to try this first before replacing all the tweeters.
Answers
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,370
    edited August 2022
    Hello, here is the crossover schematic, the poly switch (Safetyguard) is shown. You should be able to test the switch with a volt/ohm meter to see if it is open.
    pitdogg2 Posts: 27,883
    Two different photos of what they can look like. You should replace them with a 10 or 12 watt 1/2 (.5) ohm resistor. If you do not your tweeters may be too bright.
  • Lee Berger
    I'm looking at the right channel board and I don't see any safety guard components. Looks like it should be physically located next to C5.wns8s5oq2r52.jpeg
    If one is not there I would think there should be a wire to jump the connection.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,207
    edited September 2023
    Looks like it's just above the Molex connector.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • michaeljhsda2
    SDA SRS 2.3TL's
    SDA 2B TL's
    Man great eyes! I searched I expanded I went everywhere I could not find that sucker 🤣🤣
  • JCL
    JCL Posts: 174
    L600 (front), R200 (rear), R200 (rear surround), L400 (center), Sunfire HRS-10 (2)Marantz AV7706Sunfire Cinema Grand, Marantz M8077, Music Hall Stealth, Ortofon bronze cartridge, Parasound Zphono XRM, Sony UBP-X800
  • michaeljhsda2
    Yes
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Lee Berger
    Here's what I think the capacitor values are:
    C1 20uf 50v NP
    C2 40uf 50v NP
    C3 12uf 50V NP
    C4 750pf 100V
    C5 4.4uf 100v
    C6 12uf 50v NP
    C7 5.8uf 50v NP (to T1 +)
    F1nut Posts: 52,381
    edited August 2024
    Lee Berger wrote: »
    C1 20uf 50v NP
    C2 40uf 50v NP
    C3 12uf 50V NP
    C4 750pf 100V
    C5 4.4uf 100v
    C6 12uf 50v NP
    The schematics are posted here in the Vintage Speaker section.
  • Lee Berger
    Yes. I have the schematic, but I was looking for confirmation because it's hard to read some of the values and voltage values are not noted.
    If you're looking to replace with the same stuff that's a fools errand. Get some good poly caps and much better resistors. It will take them to another level. Mine absolutely astound me every time I sit and listen to them.
