sda srs 2.3 polyswitch removal
wilyJ
I have the sda 2.3 speakers, serial# - SRS 2.3 L 3955, they have always sounded muffled with no treble - am wanting to remove the polyswitches as some members have suggested. I am trying to identify them correctly - is a schematic available for the crossover or is a part number available. Pictures would be great - I'll take anything! Already modded the crossovers with new audio film capacitors - made no difference to the sound. Wanting to try this first before replacing all the tweeters.
Answers
Hello, here is the crossover schematic, the poly switch (Safetyguard) is shown. You should be able to test the switch with a volt/ohm meter to see if it is open.
I'm looking at the right channel board and I don't see any safety guard components. Looks like it should be physically located next to C5.
Looks like it's just above the Molex connector.SDA SRS 2.3TL's
SDA 2B TL's -
SDA SRS 2.3TL's
SDA 2B TL's -
I believe that is where mine are on my 2.3’s
L600 (front), R200 (rear), R200 (rear surround), L400 (center), Sunfire HRS-10 (2)Marantz AV7706Sunfire Cinema Grand, Marantz M8077, Music Hall Stealth, Ortofon bronze cartridge, Parasound Zphono XRM, Sony UBP-X800 -
YesSDA SRS 2.3TL's
SDA 2B TL's -
Here's what I think the capacitor values are:
C1 20uf 50v NP
C2 40uf 50v NP
C3 12uf 50V NP
C4 750pf 100V
C5 4.4uf 100v
C6 12uf 50v NP
C7 5.8uf 50v NP (to T1 +)
Lee Berger wrote: »Here's what I think the capacitor values are:
C1 20uf 50v NP
C2 40uf 50v NP
C3 12uf 50V NP
C4 750pf 100V
C5 4.4uf 100v
C6 12uf 50v NP
The schematics are posted here in the Vintage Speaker section. -
Yes. I have the schematic, but I was looking for confirmation because it's hard to read some of the values and voltage values are not noted.
