You’re doing it wrong…
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc. -
― Aleksandr Solzhenitsyn -
EEGADS! The bushing on that clutch is a bit off-center!
Not sure, either. Looks to me like the fifth wheel is installed backwards? Too bad it’s not a video!
Brian -
Redneck super charger…;-)
Post edited by nooshinjohn onThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
You guys are both assuming that the fan is powered somewhere, and doesn't just turn in the breeze like a turbofan engine on the tarmac.I disabled signatures.
Heater blower fan, easy enough to run 12v to it. You could even have fast, faster and out of site man .... -
You're right. I don't know what I was thinking.I disabled signatures. -
OMG !!! ^^^
Well at least it's cheap to do, that's about all it has going for it.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream
maybe not fatally wrong but certainly an interesting solution to a problem...
(ASR)
I wouldn't be doing that with any less than 2 support ladders. In mud.I disabled signatures.
What the scary thing is to me? These people have a right to vote.
I figured you for a safety first kind o' guy, @msg
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12
