You’re doing it wrong…
1…457910…132
  • daddyjt
    daddyjt Posts: 3,257
    ― Aleksandr Solzhenitsyn
  • daddyjt
  • daddyjt
    Viking64 Posts: 7,811
    EEGADS! The bushing on that clutch is a bit off-center! :o
    treitz3 Posts: 20,359
    daddyjt wrote: »
    Still tryin'a figure out how that happened...
  • bcwsrt
    bcwsrt Posts: 2,687
    edited August 2023
    Not sure, either. Looks to me like the fifth wheel is installed backwards? Too bad it’s not a video!
    Brian
  • daddyjt
    Redneck super charger…;-)
    daddyjt wrote: »
    I would sure hate to see their version of a turbo. :o
  • Unknown
    edited August 2023
    mhardy6647 Posts: 35,562
    daddyjt wrote: »
    I bet it does work a lilt bit
    I was actually thinking about that when I saw the photo...
    msg Posts: 10,650
    You guys are both assuming that the fan is powered somewhere, and doesn't just turn in the breeze like a turbofan engine on the tarmac.
  • chrispyfur
    chrispyfur Posts: 170
  • Unknown
    edited August 2023
    msg Posts: 10,650
    msg wrote: »
    Heater blower fan, easy enough to run 12v to it. You could even have fast, faster and out of site man ....
    You're right. I don't know what I was thinking.
  • Milito
    Milito Posts: 2,003
    Well at least it's cheap to do, that's about all it has going for it.
    maybe not fatally wrong but certainly an interesting solution to a problem...
    (ASR)
    msg Posts: 10,650
    I wouldn't be doing that with any less than 2 support ladders. In mud.
  • daddyjt
    daddyjt wrote: »
    I’ll bet this one is even better…;-)
    What the scary thing is to me? These people have a right to vote.
  • motorstereo
    motorstereo Posts: 2,427
    treitz3 wrote: »
    And breed
    msg wrote: »
    I figured you for a safety first kind o' guy, @msg :D
  • GlennDog
    GlennDog Posts: 3,158
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • ken brydson
    ken brydson Posts: 9,103
    F1nut Posts: 52,406
    Ouch
    msg Posts: 10,650
    Talk about high torque.
    "See, Albert? I told you that plastic wheel idea was stupid."
    audioluvr Posts: 6,079
    daddyjt wrote: »
    So my guess is the front u-joint (of the rear driveshaft) snapped, dropping the driveshaft to the ground where it speared into the pavement, snapping off the u-bolts holding the rear end and slamming it into the back half of the truck bed. Which due to the weight of the 5th wheel caused what you see here.
    Learning lessons:
    1. Chinese u-joints are a no no
    2. Diesel performance tunes seem like a good idea until stock components fail due to the added stress.
    3. If you feel an unusual vibration STOP! You may not make it to the next town.
  • maxward
    maxward Posts: 1,742
    ^^ I like it!
  • tonyp063
    tonyp063 Posts: 1,156
    I mostly agree, but looking at the stuff behind the glare it seems the rear joint is the one that grenaded.
    Advice listed is spot on
