1168169171173174203
  • For the dedicated 2 channel enthusiast:
  • Wardsweb
    Wardsweb Posts: 942
    Any idea why the positive output terminal is tied to ground?
    The circuit Q1 is taking the signal from the drain and not the source, so the signal is inverted.
  • Makes sense, thanks!
  • Wardsweb
    Wardsweb Posts: 942
    Did a little customizing. The base holds a fan.
    treitz3 Posts: 20,123
    I gotta admit, I have seen a lot of unique amps in my time but this one? This one may take the top spot.
    xschop Posts: 5,417
    Working on my next set of near-fields....
    xschop Posts: 5,417
    edited August 2023
    Got my TeCu binding post prototypes done...
    Think I should coat entire plug with dielectric grease, or just add it to the banana plug port?
  • Gardenstater
    Gardenstater Posts: 4,804
    edited August 2023
    I like Mapleshade Silclear silver platelet contact enhancer grease. Just a trace amount.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    Very nice, Todd. If you don't mind me asking, what type/brand of rack is that?
  • tratliff
    tratliff Posts: 1,811
    Hey Tom. It’s a SolidSteel.
    Thank you sir. I am having to look at rack options for the new room. There is no way I can utilize my current rack.
  • GlennDog
    GlennDog Posts: 3,158
    edited August 2023
    hey Todd,
    Rosso is new to you? what were you rock'n before?
    Your ears gotta be in heaven!
    edit; I've really been wanting to roll Norma IPA140 into the mix . . . someday!
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • tratliff
    edited August 2023
    GlennDog wrote: »
    hey Todd,
    I had Legacy Focus SEs. Sold them about 8 months ago. Skip let me borrow his Volterras for the last 2 months. The ones you see in the picture are mine with Dark Grey Sand finish. They look and sound great. Need a couple hundred hours on them.
  • PSOVLSK
    PSOVLSK Posts: 5,400
    Glad to see your pair arrived. I know you’re excited to finally get them. Shipping issues stink.
  • sgmsmg
    sgmsmg Posts: 556
    @Mike Reeter
    Looks amazing and I can only image how it sounds!
    Enjoy it!
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
    Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
    Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
    Display: Sony XBR65Z9F
    Pre: Anthem AVM90
    Amps: Buckeye NC502
    Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
    Subwoofers: SVS SB16 x 4
    Source: Oppo UDP-205, Apple TV, Amazon Fire
    Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
    Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
    Display: Sony XBR85Z9G
  • GlennDog
    along with some new Revival Audio Atalante 5 Speakers to celebrate my 70th.
    A big relief to achieve good sound in the new room :) It's not as large as my last, but I've got room for everything.
    You don't need a Big room for Big sound. Congrats brother, looks great ...
    Happy belated 70th Mike!
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • GlennDog
    edited August 2023
    tratliff wrote: »
    did you score the Legacy's from @tonyB ? . . . if so, that was a killer deal B)
    those Volts are awesome . . . I gotta get my ears on them
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • tratliff
    edited August 2023
    GlennDog wrote: »
    tratliff wrote: »
    No I purchased my Legacy’s direct from the factory.
    The Volterras are awesome.
  • TEAforONE
    TEAforONE Posts: 1,077
    Thanks for vacuuming @Mike Reeter ! I was starting to worry.
  • zarrdoss
    zarrdoss Posts: 2,562
    I got a couple of Rhythmic L12's to go with my Audio Physic Avanti III, a perfect match.
  • Family Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Fluance bipolar Rear Surrounds FluanceXF8 Bookshelf Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp x2, Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Polk Audio R700 Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX301 Eversolo DMP-A6 Polkaudio R600 Towers Polkaudio Center R350 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Fluance Signature Bookshelf fronts, Rears Fluance Signature Bipolar Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX
    SCompRacer Posts: 9,123
    I replaced the dry rotted vacuum tubing on my old Discwasher DiscKeeper LP rack. One for sale ad called them 'rubber compression bars.' I keep demo albums in this. IIRC Discwasher ceased in mid 80's.
  • As the Eversolo DMP A6 moved into the main rig in the familyroom, the Pioneer N-50 has a new spot in my home office
  • xsmi
    xsmi Posts: 1,804
    Let us know how you like the Eversolo. I might have to invest n one since it streams AppleMusic in Hi Res.
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • xsmi wrote: »
    I posted 3 videos on it already, it should be in a post under "Eversolo DMP A6"
  • xsmi
    xsmi Posts: 1,804
    Oops. Sorry I missed it.
  • TEAforONE
    edited August 2023
    I just made an impulse buy. I picked a Revelation Audio Labs Precept CryoSilver Reference power cable, on the used market . Any thoughts? Am I dipping my toes in big boy territory?
