1167168170172173204
    nooshinjohn Posts: 26,086
    treitz3 wrote: »
    Damn. I must be a bass trap then.
    Bass Ale maybe...
    pitdogg2 Posts: 27,683
    treitz3 wrote: »
    Maybe more of a BS trap..... :#:D
  • bcwsrt
    bcwsrt Posts: 2,613
    Probably the only thing it’s good for is some laughs from you guys! 😂👍
    Brian
  • stevep
    stevep Posts: 364
    edited May 2023
    It's a big old a$$ trap. Once you sit in it you can't gracefully get back up.
  • jdjohn
    jdjohn Posts: 3,425
    edited June 2023
    For my Micro Seiki MA-505L tonearm, I got this AST-05 stabilizing nut. The stock nut is on the right...quite a difference.
    These nuts screw onto the bottom of the tonearm pillar, under the arm board. It is clear how much more substantial the AST-05 nut is than stock.
    Similar stabilizing nuts exist for other tonearms. Except for suspended sub-chassis turntable designs, these bigger nuts make a lot of sense. I'm using mine on a Micro Seiki BL-91L turntable, which has a one-piece, solid plinth.
  • xsmi
    xsmi Posts: 1,812
    So, when I got my turntable and figured out the cue lever was sticky, I watched a video on YouTube about how to fix the problem. The guy on the video took the entire arm apart desoldering the cables from the main board and everything. I immediately decided it was not a job I could do because, if you know about the mockery I made of my SDA-SRS upgrades, you know my soldering skills are pathetic.
    Anyway, last week as I was watching other videos on YouTube, that video came on again, and there was a throw away line in the dialogue where he mentioned that he normally fixes this problem with the tone arm still attached. So, I started looking at mine, contacted Sumiko to get a new cue arm, and in 10 mins, I had it fixed and readjusted.
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • jdjohn
    jdjohn Posts: 3,425
    I believe Jelco made tonearms for Sumiko. You can normally remove the cue platform, and then the piston itself without dismantling the entire arm. It's typically a matter of stripping and replacing the very thick silicon oil, although getting the correct weight of oil can be a challenge...trial and error.
  • xsmi
    xsmi Posts: 1,812
    That’s what I did.
  • newbie308
    newbie308 Posts: 824
    jdjohn wrote: »
    I ordered this through Amazon and it worked great for my SME3009 cueing piston.
  • Braddles63
    Braddles63 Posts: 191
    Added a new Eversolo Streamer....
  • gidrah
    gidrah Posts: 3,049
    I recently shipped an ADS C2000 crossover out for repair and it came back last week. I took the Dunlavy SC-IIIs out of service and put the ADS L1530s back in. I'm currently bi-amping them with a 200wpc Soundstream SS amp on the bottoms and a 60 wpc VTA ST-120 tube amp on the mids and highs.
    Make it Funky! :)
  • TEAforONE
    TEAforONE Posts: 1,100
    Today I moved my gear from between the speakers,to the left wall next to my listening chair. I’ve been wanting to do this for,well, a very long time. I always felt my system threw a great soundstage, but this absolutely took it to he next level. Voices now truly sound like the vocalist is literally standing right in front of me. I knew from all the reading I have done over the years,that moving the gear out of there would make a difference. I’m shocked at how much it matters. The best 2 hours I’ve ever spent.
  • maxward
    maxward Posts: 1,732
    Good move! It’s worth the extra length of interconnects or speaker cables.
  • TEAforONE
    maxward wrote: »
    Longer interconnects in this case. I will eventually replace the old Wireworld cables I’m currently using.
    treitz3 Posts: 20,238
    Upgrade time, if you can wing it. It's a buyer's market right now, so make the most of it.
    That said, speaker placement is extremely underrated.
  • jbreezy5
    jbreezy5 Posts: 1,141
    TEAforONE wrote: »
    maxward wrote: »
    Soundstaging was the one thing I felt Wireworld cables upgraded, and in no small way.
    What version do you currently have?
  • TEAforONE
    jbreezy5 wrote: »
    TEAforONE wrote: »
    maxward wrote: »
    I picked these up off of flea bay a couple years back. Audio Vision, according to my purchase history. I’m sure they aren’t the final word in detail,but they suffice for the time being. They are 6 meters,and pick up no interference. I’ve had much shorter cables pick up radio stations.
  • jbreezy5
    TEAforONE wrote: »
    jbreezy5 wrote: »
    TEAforONE wrote: »
    maxward wrote: »
    I know @erniejade had higher end Wireworld cables than the ones I tried (Oasis 8). Going from memory, I believe he opined that Equinox is where they start to get good. That was too rich for my blood for wire.
  • Wardsweb
    Wardsweb Posts: 943
    New PSVANE Reference 845T tubes for my Antique Sound Labs mono blocks.
    You get those when you stopped by Josh's the other day?
  • Wardsweb
    Wardsweb Posts: 943
    treitz3 wrote: »
    Yes, got to spend a nice afternoon with Joshua spinning vinyl and talking audio.
    Can't ask for more than that. He's a great guy to hang around with and he has great taste in music. I'm planning on a couple of extra days when I'm down that way next year to do just that.
  • Wardsweb
    Wardsweb Posts: 943
    Nelson Pass Amp Camp Redux kit
  • Wardsweb
    Wardsweb Posts: 943
    Completed build
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,353
    edited August 2023
    Unusual looking heat sinks. Is there a schematic you could share?
  • Wardsweb
    Wardsweb Posts: 943
    the circuit is from Nelson Pass 1.6 build. Here is the schematic. A couple of changes from the black box build are the round pin heat sink build uses 2SK370 and IRFP048.
  • SeleniumFalcon
    Any idea why the positive output terminal is tied to ground?
