Post a picture... any picture
18578588608628631084
  • engie490
    engie490 Posts: 426
    edited March 2023
    Is that a Lancaster?
    Yes. Powered by 4 Rolls Royce Merlin V-12s and carried the largest conventional bomb of WWII (22,000 lb Grand Slam).
    Sonus Faber Liuto / Coda Continuum / Anthem STR Preamplifier / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Ikeda 9C2 & Dynavector XX2 Mk II carts
  • bcwsrt
    bcwsrt Posts: 1,595
    Brian
    One-owner Polk Audio RTA 15TL speakers refreshed w/ Sonicap, Vishay/Mills and Cardas components by "pitdogg2," "xschop" billet tweeter plates and BH5 | Stereo REL Acoustics T/5x subwoofers w/ Bassline Blue cables | Rogue Audio Cronus Magnum III integrated tube amp | Technics SL-1210G turntable w/ Ortofon 2M Black LVB 250 MM cart | Sony CDP-508ESD CD player (as a transport) | LampizatOr Baltic 4 tube DAC | Nordost & DH Labs cables/interconnects | APC H15 Power Conditioner | GIK Acoustics room treatments | Degritter RCM
  • engie490
    engie490 Posts: 426
    Where it all started....
    mhardy6647 Posts: 33,037
    Jack Northrop was obsessed with flying wings.
  • soundfreak1
    soundfreak1 Posts: 3,387
    bcwsrt wrote: »
    It's funny if you think about all it took to design that aircraft was a pair of Binoculars
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    pitdogg2 Posts: 24,560
    bcwsrt wrote: »
    Do they make high speed binoculars?
    F1nut Posts: 49,795
    OleBoot wrote: »
    Ah so, that's a coon dog.
    msg Posts: 9,434
    bcwsrt wrote: »
    Is this to scale?
    SCompRacer Posts: 8,352
  • engie490
    engie490 Posts: 426
    edited March 2023
    Maybe...if it's the Giant Claw!
  • soundfreak1
    msg wrote: »
    That pair came after me once for my dangling participle.
    SCompRacer wrote: »
    They best not come to my door! Corrections will be made immediately
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    saw this at ASR today...
    Finally, a Venn Diagram that looks accurate to me (seen at ASR):
    edited March 2023
    Man I wish they would figure out this picture thing. @CFarrell_SoundUnited
  • bcwsrt
    bcwsrt Posts: 1,595
    Brian
    audioluvr Posts: 5,432
    But not near the torque.
    msg Posts: 9,434
    Good point, Rob.
    Also, I'm pretty sure that the torque is so weak, that if you were to get a ladder and climb up to the Boeing at idle and grab the cone with both hands, you would not be ripped from your perch and flung off against the fuselage.
    nooshinjohn Posts: 25,095
    msg wrote: »
    Good point, Rob.
    Is that before or after you get sucked through that swirling Ginsu knife set and BBQ’d before your azz hits the ground 3 seconds later?
