Phase Plug design for MW65xx
1…89111314
    xschop Posts: 5,931
    You're raising the bar on vintage SDA mods.
  • Gardenstater
    Gardenstater Posts: 4,991
    @plastic_avatar do the shims fit your drivers with a nice slip fit between the pole piece and your voice coil formers, or do you think they need to be thicker? They fit my 6500s perfectly.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • plastic_avatar
    @Gardenstater I think they're fine. Snug fit.
    @xschop From your workbench to my hands, master artificer.
    The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage
    xschop Posts: 5,931
    edited November 2022
    The 11's have landed. Finally got ahold of a set of Original 6511's to plug.
    Took some measurements and they both test out at 3.5 ohms.
    These two units' magnets are actually centered in relation to pole-piece, so I won't disassemble.
    However, the spiders and surrounds are the exact same as a 6510. I did a quick depth measurement using my alloy VC jig and the suspension matches the 6510's as well.
    So my final conclusion is a I suspected, that the 6511 is a 6510 (6.5 ohms) but with a 3.5 ohm voice coil.
    The 6502 is a 6511, but with a tighter suspension/thicker weave spider, sharing the same 3.5 ohm voice coil...
    Same transparent woven-mesh dust cap...
    xschop Posts: 5,931
    Went ahead and cut frame tabs, glued magnets and butyl matted the frames, then cut dust caps and made matching felt rings. These will accompany some felt-ringed 6510s for an "XS-CRS-TL" build.
    Almost every vintage driver has the terminals loose on frame.Some terminals can dangerously teeter towards frame and can let the magic smoke out. I let a small amount of Super Glue wick between tab and frame and they lock up solid...
    xschop Posts: 5,931
    6511's are done...
    Another piece of the MW puzzle that's solved for me . The 6510's and 6511's, when stored face-up for a long time, have their strokes settle close to bottom and the spiders will developed a "memory" so to speak. They'll settle about 1/8" down. But I'm sure once mounted in sealed enclosures, they'll settle back to center.
    Just an observation, maybe some seasoned members have experienced?
    So to help them along, I run a hair dryer on low for about 10 min. each while they are setting on felt rings. They settle almost close to center again...
  • plastic_avatar
    Damn, those look nice. Is the cone material different than my 1C drivers?
    xschop Posts: 5,931
    Same cone material and doping compound from all other MW65xx's I've done. Judging by some drivers' sloppy application of it, the tech that day was probably on a special doping compound lol.
    And this is what they should look like when set back to center...
  • plastic_avatar
    And in all that awesome up there, a little section to add to my modding chores:
    "Almost every vintage driver has the terminals loose on frame. Some terminals can dangerously teeter towards frame and can let the magic smoke out. I let a small amount of Super Glue wick between tab and frame and they lock up solid..."
  • Gardenstater
    @xschop Does the pole piece height and magnet height vary at all across the range of MW65xx that you have measured?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,931
    No. They are all the same. With the dust cap removed, you can run a straight edge across top of frame and measure to top of pole-piece.
    xschop Posts: 5,931
    2 more 6510s and 6511's showed up. No factory sagging going on with these...
    xschop Posts: 5,931
    Their complement drivers showed up. Magnets not locked up thankfully.
    The 6511 pair are not showing any suspension sag here either...
    pitdogg2 Posts: 27,921
    So curious, were the voice coils burnt or bad in any way?
    xschop Posts: 5,931
    None were. They all ohmed out correctly too.
    edited February 2023
    Rob,
    One of the rarest woofers that many need and would pay top dollar for. I'm sorry but I find this to be horrendous that you are murdering them.
    You're a excellent machinist and I give you high marks for the things you have created, for example the tweeter plates, work of art !
    I just cannot get onboard with this on drivers that are so desirable and rare.
    xschop Posts: 5,931
    I take it you won't be sending any to convert?
    F1nut Posts: 52,406
    Judge ~ On the charge of murdering Polk drivers how do find?
    Jury foreman ~ Guilty your Honor.
    nooshinjohn Posts: 26,184
    xschop wrote: »
    In some cases, what you are doing is no different than swapping an original 426 Hemi for a Chevy LS in a one of one ‘Cuda… Some of these drivers are incredibly hard to find any longer.
    xschop Posts: 5,931
    edited March 2023
    The only thing RARE about these drivers is when you find one....
    that the suspension isn't wore out,
    the voice coil set wrong/cocked from factory,
    magnet/pole-piece not concentric,
    dust caps glued offset, mold-rotted
    frame edge bent/ out of round
    or the butyl surrounds dry-rotting.
    ..and to add to the list,...I have encountered quite a few where the zinc plating undergoes galvanic corrosion between their base-plates and coil winding areas causing deterioration of the coil. There's a fix for that too.
    Your one-off 'Cudas are ticking time-bombs due to their mechanical disposition and organic composition. You know that microscopic white mold eating your dust caps? It really has an appetite for the thin suspension spiders.
    Sometimes an LS is the only option, unless you enjoy polishing a garage paperweight...
    https://youtu.be/vy0eWHuWmnk
    xschop Posts: 5,931
    edited March 2023
    That was a fun Pacer that out-ran a few Vettes. The look on the other drivers' face was priceless.
    Last I heard, the new owner's kid blew out the tranny.
    xschop Posts: 5,931
    edited March 2023
    You mean hard to find in original working order with any resemblance of original TS parameters due to their gentrification.
    xschop Posts: 5,931
    You may consider straightening up, or F1 will ship you out lol.
    F1nut Posts: 52,406
    xschop wrote: »
    You're on your way.
  • BlueBirdMusic
    BlueBirdMusic Posts: 3,140
    The Expanse Speaker Universe.
    Harry / Marietta GA
    xschop Posts: 5,931
    Be patient, I've got more modding to do. Mine and yours.
    Looks like a 4th set of M7's are about complete.
    It's now clear why there are so many closet-modders here.
    xschop Posts: 5,931
    edited March 2023
    Another set of 6510's showed up with magnet shift. One so bad it severed the coil lead wire (on left). I was able to scrape the dust cap glue away, lift the wire up and over enough to get it repaired with fine tip soldering iron and Cardas Quad...
    Saved from the heap or trash-Bay...
    Back 100% Concentric...
    xschop Posts: 5,931
    edited March 2023
    xschop Posts: 5,931
    edited March 2023
    Never posted this. Here's a fast way to remove a factory glued magnet without breaking it. Use exactly 0.500" alloy bar and gently wedge for pressure. Takes only 1 to 1.5min heating and you'll hear a distinct snap (Loc-Tite release). Let cool and pull magnet off by hand....
  • gp4jesus
    gp4jesus Posts: 2,025
    W/all the skill of a brain surgeon… you’re the man Rob😊
    *all connected w/Premiere ICs
