1149150152154155202
  • Thanks for the info pit, yeah those MELZ are a bit pricey!
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Bought some of these as well. Quad for $26.50/free shipping from Florida.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Nothing physical today, but I did get into the Foobar2000 settings just to look around, only to realize that all my HiRez playback settings had, unknown to me for probably six months, reset to standard playback.
    All fixed now, and amazed at HiRez playback again.
    Polk R200 SpeakersSchiit Saga S & AegirCr*pload of old disc players for my old CDs.
    treitz3 Posts: 20,105
    Well, call me crazy but I am so enamored with the Shunyata Ethernet cables?
    I am already thinking of returning one of them and going straight up to the Omega Ethernet cable from the router to the Auralic Vega G2. I'm just itchin' to pull the trigger.
    The sounds I am hearing as it stands? This is the best musical reproduction I have ever heard in my life. Bar none and I can say that in full confidence and without hesitation. From what I have read, the Omega is just insane. I think I might just need to find out just "how insane"... B)
    I still can't figure out how a cable that offers no power or even a music signal can make such a significant and profound change to the end result as to what one hears.
    VR3 Posts: 29,545
    Physical music is better
    VR3 Posts: 29,545
    On a more realistic note because streaming is obviously superior to physical media....
    3k for an ethernet cable is pretty wild, definitely look used
    If you had asked me if I would have ever spent more than a hundred dollars on an Ethernet cable two months ago, I would have not even answered. I would have just laughed.
    If you told me two months ago that I would one day be seriously considering a 3K Ethernet cable? I would have considered you 100 percent, certifiably bat **** crazy.
    Had I not tried the cheap Cat8 Ethernet cable about a month or so ago? I wouldn't be hearing what I am hearing. I actually looked down at the table next to the listening position earlier today (twice) to see what was ringing. It was the music! Last night, I muted the system because I heard someone talking outside of the room. Once again, it was the music. Both tracks were familiar music to me. I had not ever heard that before and definitely not in those locations.
    I have 2 pages of just "notes" to describe the changes to what I am hearing. This is SO MUCH FUN!!!!
    Last night, when I hooked the new ones up? I listened for 3 hours straight. Then Kimmie listened for 2 and a half hours. She even came in at one point dancing. I have never seen her just walk into the room and bust a move.
    After more listening tonight? I pulled the trigger. I don't feel like waiting for a used one to pop up.
    Now as to which cable gets sent back? Time will tell. I only need two, so some experimenting is in order once the Omega comes in.
    VR3 Posts: 29,545
    You need two right?
    Modem to router, router to streamer? 🚀🚀
    Yes. One of the two I have will go in the other location. The Venom does a great job between the modem and router but when the Omega comes in, I will try the Alpha in it's location. Not quite sure if upgrading that part of the equation would make that much of a difference. But, since I will have 3 cables in the house? Eh, I'll give it a whirl.
    The last cable (from all of the research I have done), leading to the NAP is the one that makes the most amount of difference. That's where I currently have the Alpha.
    The Omega is truly a state of the art piece. They went well beyond the typical metallugies and added technology I just got a taste of with the Alpha. I really like what I hear (obviously)
    VR3 Posts: 29,545
    edited December 2022
    Well don't forget upgraded DC cables for the linear power supply when the time comes
  • Gardenstater
    Gardenstater Posts: 4,803
    Congrats man! I just about had a heart attack coughing up $182 for 28ft of DH Labs Silversonic 12awg wire to construct my 2 power cables I have planned! I haven't gotten to your level yet :)
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Here's a company that makes some great audiophile network switches and steamers
    Silent angel is the name
  • rebelsoul
    rebelsoul Posts: 758
    Trying some speaker wires that the guy that has the Evolution Acoustics loudspeakers where I am working asked if I wanted to try out these speaker wires. They have a 14or 16 gauge cryo pure copper and a 14or 16 gauge cryo silver spun together for each the positive and negative and then therevuo155wkwwwl.jpg
    spun or twisted . His buddy makes them.
    pitdogg2 Posts: 27,290
    I have not been disappointed with any if my DH Labs purchases. I rewired my 2.3tls with the 14ga silver over occ copper wire. Enough black and red to do both sides, it was a bear to work with but the outcome was FAB U lous.
    VR3 Posts: 29,545
    DH Labs is fantastic wire. I do always caution folks with permanently installing silver wired but with SDAs given their warmer presentation should be a good combo :-D
    The Revelation and Air Matrix are fantastic ICs and the Q10/T14 is phenominal speaker wire.
    I find their ready made speaker wire to be $$$ for some reason...
    jdjohn wrote: »
    In short, it seemed that the CAT8 cable was emphasizing all the negative aspects of streaming digital playback. I found the BJC CAT6A cable to be more balanced and refined...forgiving.
    So, to answer your question from a couple of pages back? I don't think it was the "Cat" rating. It may have been that the connections were slightly better and that the cable was shielded. It turns out that both the Venom and Alpha Ethernet cables from Shunyata are Cat6A. They found that this cable has less noise/interference, amongst other things....which is why they chose Cat6A over any other cable.
    So, what you heard, may be the result of what their lab confirmed. FWIW.
  • motorstereo
    motorstereo Posts: 2,362
    I installed these feet under my SVS sb16. It was quite an upgrade over the get you started feet that came with sub. Listening to Manheim Steamroller's Halleluiah and the bass was vibrating the reading glasses I was wearing. That's a first for me.
  • pitdogg2 wrote: »
    Thanks for confirmation Ivan. I'm pretty confident in the results because I am replicating a friend's creation already tested on my subwoofer a couple times with great results, only mine is going to be 12awg and his was 14awg. Same otherwise; Cardas male wall plug and Cardas IEC plug. I might twist mine more than he did to get lower inductance. He doesn't really know exactly how much he twisted his so not a lot I think. I may do something closer to 1 twist per inch like Chris Venhaus suggests now.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • michaeljhsda2
    michaeljhsda2 Posts: 2,202
    Swapped out the Chinese 12AX7's for these...not sure what brand they are. There's a 12 etched in the bottom between the pins and 4 creases in the top.
    SDA SRS 2.3TL's
    SDA 2B TL's
    audioluvr Posts: 5,986
    How do they sound?
  • Really good. Someone on Audiokarma said they were Amperex. Shame all the lettering is missing.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Family Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Fluance bipolar Rear Surrounds FluanceXF8 Bookshelf Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp x2, Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Polk Audio R700 Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX301 Eversolo DMP-A6 Polkaudio R600 Towers Polkaudio Center R350 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Fluance Signature Bookshelf fronts, Rears Fluance Signature Bipolar Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX
  • recoveryone
    recoveryone Posts: 929
    Its' been over a year after the house remodel and finally getting this back in place
    https://youtu.be/dA5a4ls8ROk
    Sound demo (headphones recommended)
    https://youtu.be/NSlpiGBpwlo
    First video is private, bub...
    [Edit:] of the second post...(fixed/repaired since then, all is well...)
    Post edited by treitz3 on
  • michaeljhsda2
    I figured it out. It's a Siemens & Halske, I62 ≠3 ...can't see the rest.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • This hobby sucks! Every time I upgrade a component, reveals deficiencies elsewhere! I recently upgraded the digital side of my system with an Oppo BDP103 disk player and a Musical Fidelity Tri-vista 21 DAC. A Wireworld Silver starlight digital RCA cable between and a Wireworld Oasis RCA 1 meter pair fromtheDAC to the preamp. It sounds so good that now it outperforms my vinyl playback SQ for clarity and imaging. Of course I can't leave the vinyl playback the way it is, so I started investigating phono preamplifiers in another thread. I also ordered two pair of Wireworld eclipse RCA interconnects so I have the same input cables for both sources. Yesterday I purchased a Kimber TAC tonearm cable to try since the current tonearm wiring is a temporary solution and I think it is sucking the life out of the music with its high capacitance. I will be researching MC cartridges in the new year, and eventually upgrade to a VPI signature prime turntable to get my vinyl playback on par with the current digital setup.
    Clipdat Posts: 13,100
    I wouldn't be so quick to upgrade from the Technics table.
