SDA SRS new to me
1810121314
    F1nut Posts: 51,870
    The polyswich has a resistance of .5 ohms. If you don't replace it with a .5 ohm 10 or 12 watt resistor the top end gets brighter, which is not a good thing.
  • skipshot12
    skipshot12 Posts: 2,029
    That small gold round piece behind the 12.0J 250v cap is the polyswitch yes?
    pitdogg2 Posts: 27,142
    Yes that is it. They can also be blue
  • skipshot12
    ^ ok.
    Another question, looking at these 4 blue caps… one is facing a different direction. What would be the reason for that?
    + & - reversed at that location?
    Aren’t caps supposed to be oriented a certain way dependent on which is the inner wrap & which is the outer wrap?
  • skipshot12
    edited November 2022
    Reason for asking so I can install correctly when going back with the new caps.
    I’m not very good with orientation between looking at a schematic and trying to transfer that to understanding a pcb layout…… 😳
    I’m a parts replacer with mad soldering skills 🤣
    skipshot12 wrote: »
    ^ ok.
    They are bi-polar electrolytic caps. Shut off your OCD for a bit. I've never worried about any of the "inner/ outer" wrap nonsense when it comes to caps. I'm not about to go and de-solder and 180* them to TRY and hear a difference. If it made a huge difference cap producers one would think put a symble as to which way the signal needs to flow. Only 1 or 2 cap producers actually have a red and black tail to orientate the cap to signal flow. If you use those then by all means follow the flow :smiley:
    I will say you are going to need to get real creative, that 130uf cap is going to be multiple caps or one REAL BIG cap. It will take a monster amount of space.
  • skipshot12
    Excellent….
    Going at the crossovers one step at a time.
    Gonna do the bypass of the polyswitch first to see what that brings.
    That’s what’s skull f-ing me on the cap replacement gig right now.
    It’s really overwhelming at this point to think how to go about getting those large caps installed.
    Thinking of replacing like for like, for the caps, in changing out those 36 year old caps to start with. It’ll give me a little confidence before going ball’s deep with installing soda can sized caps 😳
    Even thinking about not un-soldering the wires, to the drivers, and doing it in place.
    Must get the gumption to get started. Don’t want to screw this up.
  • invalid
    invalid Posts: 1,497
    Solen is the only one I know of that make that 130 if cap, I used them in my sda2a's, but I wouldn't use them anywhere else.
    F1nut Posts: 51,870
    Why do I bother!?!
    nooshinjohn Posts: 25,939
    Why do I bother!?!
    Because deep down, you are just a fuzzy widdle teddy bear... :p
  • skipshot12
    Polyswitch out and jumper installed on the right speaker. Dang, I’ll be…. Inductor lead fell off while removing the crossover. No worries as it was obvious where it went. It’s a little shorter now but ok.
    Have resistors coming in various ohmages to try in place of the jumper, up to 0.5.
    Will move them in & out to see how they affect the sound of the tweeters to decide what sounds best to us.
    Then on to caps….. 😳
  • skipshot12
    First impression of the change from the polyswitch to jumpering....
    Definitely more treble. Nothing objectionable yet but have limited time listening. Could be source material as I've only listened to Taj Mahal?
    Will throw some rock on tomorrow.
    txcoastal1 Posts: 13,514
    Hence the resistor to pad down :)
  • skipshot12 wrote: »
    You can put a meter on the polyswitches and see what they ohm out at. When they get tripped multiple times they can acquire a permanently raised resistance.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • skipshot12
    skipshot12 wrote: »
    Didn't think of that. I reflowed the two solder points for the switch, cut the leads below the body then soldered the two leads together. Threw the switch away.
    Will do the measurement on the switch when I do the left speaker.
    I like a little more detail in the sound of my speakers.
    Think I'll end up towards the lower end of those resistor values, from what I'm hearing with just the jumper installed.
    The wife likes to play music quite a bit lower than me.
    It has a nice detailed top end at the lower volume.
    Testing with music playing louder will determine where to go from here.
    That's where I found the SL2000's to show their nasty side.
    skipshot12 wrote: »
    ^ ok.
    They are bi-polar non-polar electrolytic caps. Shut off your OCD for a bit. I've never worried about any of the "inner/ outer" wrap nonsense when it comes to caps. I'm not about to go and de-solder and 180* them to TRY and hear a difference. If it made a huge difference cap producers one would think put a symble as to which way the signal needs to flow. Only 1 or 2 cap producers actually have a red and black tail to orientate the cap to signal flow. If you use those then by all means follow the flow :smiley:
    Fixed it.
  • JayCee
    JayCee Posts: 1,509
    Redid my 1.2tl XO's back in ~2013 and, as I recall, the prevailing advice was to try the polyswitch removal w/o and if found to be too hot move from and closer to a .5 resistor. Also, since then, my 3.1tl's, 1C's and 4.1tl CRS+'s. Like you, I preferred a bit of top air and believe my gear choices (more laid back and not aggressive ie. Parasound, Anthem tubed pre and now BHK tubed pre and amp) aided this decision. To date, I've never felt the need to add a resistor. Since you're in tinker mode and having fun w/this, I'd encourage experimenting wit and witout (Philly reference) while it's easy to do. YMMV.
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • skipshot12
    skipshot12 wrote: »
    ^ ok.
    Fixed it.
    Did see two 130’s while doing the polyswitch.
    Are those 130uf’s in the tweeter or mid circuit?
    Saw Solen makes 130uf 400v caps.
    Did a short search to see if I could parallel a couple of 65’s but didn’t see much.
    skipshot12 wrote: »
    skipshot12 wrote: »
    ^ ok.
    Fixed it.
    https://forum.polkaudio.com/discussion/55888/polk-audio-speaker-wiring-schematics-amp-more-stereo-dimensional-array-sda#latest
  • skipshot12
    After looking at the schematics for cap values I have a question for you’s before I decide on which caps to purchase.
    Which are the most important caps to spend cash on?
    Which are least important?
    What about a cap to ground?
    Post edited by skipshot12 on
    F1nut Posts: 51,870
    High frequency circuit caps are supposed to matter more, but IME they all do.
    The 130uf caps you will need to put on a board in another location and run wire to there respected location if you go film caps. They will be too large and too many to fit as it is now. You will have very few options for that location. Yes they all matter IMHO
  • skipshot12
    Thanks.
    Pulled the left crossover, removed the polyswitch and got a 0.2 ohm reading.
  • skipshot12
    Crossover back in, time to give it a listen to see how it balances out with the right speaker.
    Dang pit, you ain’t a kidding on the size of replacement film caps. Looking at the dimensions of various manufacturer’s caps.
    Wonder if a couple may fit between the board & the plate?
    That may help a bit.
    Don’t know if I’m quite ready to remote mount at this time. Thought of it makes my grey stuff hurt 😬
  • skipshot12
    Poly on the left was blue.
    VR3 Posts: 29,474
    I won't be able to find a picture, but I did a repair for a guy and I removed the inductors on the mounting plates, drilled holes and secured the 130uf to the aluminum mounting plates for the inductors for the Sda srs. Solen 130uf will fit, one per side
    VR3 Posts: 29,474
    Nvm, found a pic.. You can kind of tell what's up in the photo
  • skipshot12
    ^ Nice, thank you.
    Your picture answered one of my questions… wasn’t finding a 92uf cap and was wondering if a 91 was ok 👍
    Other question…. Did you put the 130’s between the plate & pc board?
    VR3 Posts: 29,474
    Yes you can see them in the pic, they are strapped to the inductor mounts
