Post a picture... any picture
17857867887907911158
    SCompRacer Posts: 8,485
    edited October 2022
    agfrost wrote: »
    Nice. Been looking (not very hard) for one for my LT20 and LT30. Both need a little love to get them running though, and cartridge setup isn't the issue for either!
    Hi Jay! The Technics style gauges are easily obtained although they are 52mm. One can carefully sand/file end or scribe a line at 50mm, if that is the spec.
    The other must haves for linear arms with no VTA adjustment are cartridge shims. Cartridge height varies. The Harmon Kardon ST-8 with Rabco linear arm align tool also had a stylus height incorporated into the stylus align gauge as well. My LT-5V manual provides stylus height off flat surface in the manual (18mm or 11/16"). You add or subtract shims to get proper VTA.
    Ed's ST-8 had a .055" shim on the arm, but three other thickness that were originally supplied are missing. Unless he has that stuff squirreled away in his treasures. :D
    Harmon Kardon ST-8 3D printer gauge from ShapeWays.
    Shims from ebay. These are .015" each x 4. The light color ones are tapered, .0145" to .015."
  • aprazer402
    aprazer402 Posts: 3,144
    NotaSuv wrote: »
    The 1950-1970 era the smell was possibly a combination of cattle and lead smelting.
    No particular odor these days, unless you drive by Warren Buffett's very modest home, you can smell money.
    In 1955 Omaha overtook Chicago as the World's Largest Meatpacking Center.
    Lead was smelted on the riverfront for 125 years.
    https://cumulis.epa.gov/supercpad/cursites/csitinfo.cfm?id=0703481
    txcoastal1 Posts: 13,262
    The 2 worst smelling towns/cities that I have been through
    #1 Silsbee TX...Papermill plant OMG for miles and you cant's get that smell out of your car for another 20 miles.
    #2 Jimmie Dean meat processing out by Lubbock TX
  • soundfreak1
    soundfreak1 Posts: 3,414
    Oh crap I remember that pappermill smell! The smell of HELL!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    Tony M Posts: 11,141
    New world record. :o
    Over 1200 lbs.
    treitz3 Posts: 18,994
    Never fall for the bumper sticker....
  • I like the description of the way the subwoofer works. This is a picture only - no links.
    Harry / Marietta GA
  • sgmsmg
    sgmsmg Posts: 546
    @BlueBirdMusic :D
    I saw that listing today and had a chuckle as well. They are local to me and often have some fun with their listings.
    Pre:Bryston BP173
    Amp:Bryston 14B3
    Speakers: Golden Ear Triton Reference
    Source: Oppo UDP-205, Bryston BDA-3, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
    Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
    Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
    Display: Sony XBR65Z9F
    Pre: Anthem AVM90
    Amps: Parasound A31, A51x2
    Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
    Subwoofers: SVS SB16 x 4
    Source: Oppo UDP-205, Apple TV, Amazon Fire
    Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
    Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
    Display: Sony XBR85Z9G
    This is the Hisashimichi interchange. It's a Japanese highway junction, made with minimum loss to Environment. This is a seriously impressive engineering masterpiece situated in Hachioji, near Tokyo, Japan.
    P.S. - I'd hate to miss the right exit!
  • soundfreak1
    Real nice areodynamics! Reminds me of a brick.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    The only advertisement a window installer will EVER need....
    pitdogg2 Posts: 25,380
    The amount of pressure against that is astronomical.
    mhardy6647 Posts: 33,727
    That photo, amusingly enough, was posted to twitter by Dixie Whatley, who used to be a TV reporter on WCVB in Boston back when we were in the Bay State. :) Guess she moved south.
    edited October 2022
    Now that's a great looking fence!
  • OleBoot
    OleBoot Posts: 2,683
    The Virginia creeper foliage on the Tu Hwnt i'r Bont (Beyond the Bridge) tearoom in Llanrwst, Conwy, north Wales, has changed colour from green to red. It was built as a home in 1480 but has been a tearoom for more than 50 years.
    10-4.
    That's our across the street neighbors.
    That's a big-money dry field stone wall, and it is indeed gorgeous.
    Interestingly, it needs a fair amount of maintenance, due to the annual freeze-thaw.
    It's rather enjoyable to watch a stone wall builder... umm... build a stone wall.
    Most of us have the 18th/19th century field stone walls, which are rather more utilitarian. ;)
    msg Posts: 9,987
    treitz3 wrote: »
    Chevy has released a sneak photo of next year's truck model....
    You think they went far enough this time?
    Hopefully the lights are brighter than those on current trucks and cars.
    I'm only blinded enough to see spots right now, which I particularly enjoy when I'm riding a motorcycle on a dark road at night, but it's not quite bright enough to force a crash yet, and I enjoy a good challenge.
    msg wrote: »
    treitz3 wrote: »
    I hear you! They might as well finish the job when they start it, right? :#
