Jeff Bagby's Helios CM Bookshelf Speaker Kit
    VR3 Posts: 29,658
    That extends well below the brown note
    xschop Posts: 5,687
    Any updates? Looking forward to finish pics. Great build to follow.
    txcoastal1 Posts: 13,519
    stangman67 wrote: »
    LOL. End of the year is my goal. I have tons of half finished projects laying around. I do listen to them a lot as they sir though.
    How do they sound... >:):)
  • stangman67
    stangman67 Posts: 2,330
    They sound real nice! Smooth and easy to listen to. Really impressive sound for a “bookshelf”. I’m planning to do a no **** professional quality paint job on these. Hope to keep them for the long haul
    mhardy6647 Posts: 35,455
    How did I completely miss this thread until now?! :(
    Great loudspeaker project @stangman67!
    DIY is a great value proposition for those who can do the cabinet work. It's even a decent option for folks like me who torture/butcher lumber, but can still get exactly what we want (usually with the help of a bespoke cabinetmaker)! My father and my son were/are (respectively) good wordworkers, but those genes unfortunately skipped my generation. Guess they must be recessive, and I must be a heterozygote. >#
    Also Sprach Zarathustra? :p 24 Hz woofer buster I believe
    Edit - apparently it is "supposed" to be a low C, 16 Hz. I don't know why I can hear it on the recording I listen to cause my system doesn't go that low. They must've raised it for people with lesser sound systems.
    Yes 16 Hz. 32 foot organ pipe.
    To quote the late, great Col. Paul Wilbur Klipsch (who was responsible for generally rather bad sounding loudspeakers, but who still manifested great wit and wisdom doing it -- and turned out loudspeakers that were exactly what he wanted them to be):
    They make miniature tubes and miniature
    loudspeakers, but they have yet to come up with a
    miniature 32-foot wavelength
    source: https://2d73e25b29782b6d6766-9c8af5cbfef16739445bc76457060528.ssl.cf2.rackcdn.com/PWK_Klipschisms_130730_635108757549100000.pdf
    If you want to hear it (assuming your loudspeaker will let you, and not just tease you with doubling, i.e., second harmonic distortion), this recording'll do it. :)
    (an audiophile classic! :) )
    xschop Posts: 5,687
    Autosomal recessive perhaps?😁
    After the new Rondo wire upgrade, I re-ran some bass-tone tests and the 5Bs hit low 30's Hz with even more authority.
    I imagine the modded Monitor 7's would be able to hit upper teens?
    The trick isn't hitting :p those frequencies (i.e., providing audible output at x dB below midrange level, whatever value x might take) -- the trick is not to have that output overwhelmed by a huge amount of second harmonic distortion at twice the fundamental frequency. Doubling is easily audible on a sweep, but it is often misinterpreted as deep bass by even ears that should know better. It's pretty much baked in to the "psychoacoustics" since doubling results in a tone that's exactly an octave above the fundamental, and our brains are happy to re-insert the missing fundamental. Neuroscientist/psychologist Daniel Levitin discussed this effect in one of his books -- I believe it was This is Your Brain on Music, but I won't swear to it.
    SCompRacer Posts: 9,214
    Michael Murray/Bach The Great Organ At Methuen, Passacaglia and Fugue for organ in C minor will go pretty low. Some Skrillex for fun.
    Methuen?!? :o
    Gol'dang!
    https://mmmh.org/
    How did I live in the Bay State for 23 years and not know of this organ?!
  • ken brydson
    Too many jokes, too little time...
  • stangman67
    You all got me motivated. Disassembled the speakers and got them all prepped for paint. Sanded for about 3 hours to get all the panels even. All transitions are not indiscernible by feel. Final sanded with 220, now I need to seal the non machined edges with some wood glue and sand that back down and I should be ready for Primer. Won’t lay down the primer this weekend but should be good to go when I get my next wind
    Clipdat Posts: 13,101
    Nice cabinets.
    Highly recommend a shellac based primer...lookin' good man!!
  • stangman67
    stangman67 wrote: »
    Holy double negative Batman! What I meant to say was not discernible lol. I’ll look up a shellac primer. I have automotive 2k DTM I was planning on using
    If you have the DTM, run a test coat on your scrap to see if it raises or swells the MDF. Not familiar with the 2k but read a bit where a guy used shellac based Barcoat the the 2k. Barcoat expensive but you can use zinsser BIN shellac primer
    https://www.mig-welding.co.uk/forum/threads/epoxy-and-2k-onto-mdf.110074/
    VR3 Posts: 29,658
    Mdf usually needs a really good sealer
    @F1nut
  • stangman67
    I did seal the edges with glue, so the edges won’t soak up paint. I have some BIN from my bathroom remodel so I can roll on a coat of that before laying down the automotive primer
    edited September 2022
    Good job on the edges....if not, doesn't happen right away, but time will expose them for what they are. ;)
    Keep going, I need some incentive. I have a Walnut TT plinth in raw state that needs finishing.
    Methuen?!? :o
    Gol'dang!
    https://mmmh.org/
    Oh please, you must have heard or felt its presence at some time. :)
  • stangman67
    txcoastal1 wrote: »
    Thanks for the suggestion, think this is going to end up being a very vital step. Rolled on two coats of B I N this morning and very happy with the results. Might do a third coat a little later so I have more sanding room.
    VR3 Posts: 29,658
    Looks great
    MOST
    I assume you will be adding the auto primer after the BIN. I'd start moving up on grit as you progress with coats. 400-800-1000 then the paint.
    Going to be exciting watching the progress. When all said and done you should literally be able to buff and polish like a car.
  • stangman67
    Yup, I’ll sand the B I N and then add the DTM. There are some visible seams on the top of one of the speakers, so I’ll attempt to address those in the sanding process prior to spraying the 2K primer.
    I will definitely sand in between the primer coats and the base coats and clear. Then I will wet sand will some 1000 and 2000 and then polish with compound/polish. I don’t think they will turn out perfect as I am a paint rookie but I am hoping for at least pretty good
  • stangman67
    I have come to the recent realization that these cabinets are a LONG ways from being ready for paint. I started blocking the top of one speaker about an hour ago and it still is not flat. I made the mistake of using titebond glue to fill in the very small imperfections where the panels met. I used too much glue which created a sanding distaster to get rid of the excess glue. To accomplish that task, I utilized an RA as a block would have taken way way too long. After I rolled on the primer I could tell I had a lot of high spots still. I moved to the block to verify and sure enough there are a lot of high spots that need to be knocked down, and then will have to roll on some more sealer before I move on to the coating system. I’d estimate I probably have 10-15 hours of blocking to go to get the panels evened out to an acceptable level.
    Learning a ton here and still having fun, despite minor frustrations like this.
    You have taken it this far, and you seem the like the speaker, so no reason to rush. I'll make another suggestion especially since your are sanding anyway. I recommend taking some flat black paint spray paint and hit the areas where the speakers mount with a couple of coats. No need to primer.
  • Gardenstater
    When I used to do my own auto body work on my 240Z I used alternating gray and red primers to show the high and low spots when wet sanding.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,687
    Truck bedliner takes all your problems away lol.
  • stangman67
    @xschop well I hate myself way too much to do something that easy lol. The paint is one of the things that got me most excited about this. Want to try to master a new skill
    xschop wrote: »
    FWIW, I had a similar thought -- although I was thinking more along the lines of Plastidip. :#
    That should cover those minor cabinet surface imperfections.
    https://plastidip.com/our-products/plasti-dip/
    pitdogg2 Posts: 27,682
    I've got a friend who plastidipped their car. It actually looks very good. I had just thought they painted it a flat color until they told me what it was. The color is navy blue and it is on a new Camero.
