Been playing with these on the office rig
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Trey said he'd give $20 to the first person who could identify the unit....
IlL identify your unit- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Looks like Audio Note Kits...
Ank EL34 Monoblocks
Sounded relatively good but I think there's a bad tube somewhere in one amp, plan to track down later- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Uuhhhhh...I don't see any tubes installedAnk EL34 Monoblocks
Anyway, to quote our ol' friend Joe Coulson: "Tubes are fun. Tubes are noisy. Tubes are tubes.""This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
I believe the issue was using a trs 1/8" to stereo rca cable
Running them on the grandes now and sounding good
Different presentation but the kw750 honestly has alot of the positive attributes of this amplifier along with unrelenting dynamic range bass slam and extension.
These will work perfect in the office though, just need to find a preamp. Or something to go between the computer and the amps.
Tube amps do sound excellent at lower volumes,, great staging and details with excellent decay- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I really like the look of those. Glad to hear they sound great as well!
Thanks man, I have been very impressed with all of the ANK stuff- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Trey, did you buy the kits and build them yourself?"This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
I picked it up pre-owned with a full suite of mullards. I did go through and redo the binding post connections since the 4 ohm tap was not hooked up and organized the wiring without being to invasive.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
So, I quietly moved my ATCs to studio two and camouflaged them
in an attempt to go unnoticed.
I have streamed from my iphone to BlueSound Node 2i, but lacked the will and time to set-up its network feature-set. Yet, I wanted to access my music files stored on my PC.
Today, after much online research to make sure I had the appropriate IP address, Admin auth, guest usage, network settings, etc., I still had no success getting it configured to recognize my PC library on the BS app.
Finally, I connected my 1TB external SSD to the USB input and the Node 2i recognized it immediately with no effort.
For those BlueSound Node 2i users, who (like me) don’t enjoy spending their weekend fighting with their computer, hope this helps.CD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
Cables: Tripp-lite 14ga. PCs, Blue Jeans Cable ICs, Philips PXT1000 ICs; Kimber Kable DV30 coaxial ICs; Canare L-4E6S XLR ICs; Kimber Kable 8PR & 8TC speaker cables. -
Spinning some vinyl! Picked up a pile of freebies. Some are garbage but some are in great shape!
Built some custom cables for my subs. These are made for the high level inputs of my REL Carbons. They are made up of Furutech Alpha cables, AudioQuest spades and neutrik speak-on connectors.
2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables -
I’m on my 5th mid woofer on the upgrades for my SDA SRS’s.
First speaker done, the left, and wrapping up the right.
Next project is to attack the crossovers.
Haven’t decided yet whether to just replace or upgrade the caps & resistors.
Hey VR3….
I’m wondering how you find the bottom end, bass, of the KW’s?
I had the the KW 500.
Loved the sound but found with my speakers it didn’t have any slam on the lower freq’s. -
Bass is dependent on many things but the kw750 definitely is capable of amplifying the bass frequencies- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Yeah, it has no problem at all with the lower and lowest of frequencies. If the gear produces it and the speakers can distribute it? It has all one will ever need. Unadulterated, clean, controlled, pure power.
What speakers did you run the KW500 with?
Legacy-Audio Focus, the originals.
Then infinity prelude mts.
Hade the legacy focus being pushed by simaudio w-10’s before the kw.
I felt I lost some bottom end slam at louder levels with the kw.
I must add…. We do have a tendency to play at really loud levels.
Skip -
Musical Fidelity X-150
Per the owner's manual:
105WPC into 8 ohms
141WPC into 4 ohms
Peak-to-Peak output current: 50 amps
SNR >98dB (A-weighted)
Other online sources have slightly different output specs, but still close.
It's a half-size footprint amp from the X series (only ~8.5" wide), but still very powerful. I haven't tried the phonostage yet. I'm trying to NOT bring too much attention to it in the household...if you know what I mean
It should be a good foundation for a second, third, or whatever, system
I would never do that.
Cool volume knob.
https://youtu.be/fGx6K90TmCI
