1143144146148149203
    VR3 Posts: 29,550
    treitz3 Posts: 20,121
    Trey said he'd give $20 to the first person who could identify the unit....
    VR3 Posts: 29,550
    IlL identify your unit
  • DaveHo
    DaveHo Posts: 3,583
    VR3 wrote: »
    nooshinjohn Posts: 26,002
    Looks like Audio Note Kits...
    VR3 Posts: 29,550
    Ank EL34 Monoblocks
    Sounded relatively good but I think there's a bad tube somewhere in one amp, plan to track down later
  • jdjohn
    jdjohn Posts: 3,384
    edited August 2022
    VR3 wrote: »
    VR3 wrote: »
    Ank EL34 Monoblocks
    Uuhhhhh...I don't see any tubes installed ;)
    Anyway, to quote our ol' friend Joe Coulson: "Tubes are fun. Tubes are noisy. Tubes are tubes."
    VR3 Posts: 29,550
    I believe the issue was using a trs 1/8" to stereo rca cable
    Running them on the grandes now and sounding good
    VR3 Posts: 29,550
    VR3 Posts: 29,550
    Different presentation but the kw750 honestly has alot of the positive attributes of this amplifier along with unrelenting dynamic range bass slam and extension.
    These will work perfect in the office though, just need to find a preamp. Or something to go between the computer and the amps.
    Tube amps do sound excellent at lower volumes,, great staging and details with excellent decay
    Clipdat Posts: 13,100
    I really like the look of those. Glad to hear they sound great as well!
    VR3 Posts: 29,550
    Thanks man, I have been very impressed with all of the ANK stuff
  • jdjohn
    jdjohn Posts: 3,384
    Trey, did you buy the kits and build them yourself?
    VR3 Posts: 29,550
    I picked it up pre-owned with a full suite of mullards. I did go through and redo the binding post connections since the 4 ohm tap was not hooked up and organized the wiring without being to invasive.
    audioluvr Posts: 5,987
    VR3 wrote: »
    The optional playpen upgrade makes it go from really good to seeing Jesus!
  • newbie308
    newbie308 Posts: 811
    Amplifier and preamp from @engie490 and the CD player from @clipdat plus interconnect RCA cables from @PSOVLSK took my system to levels I never imagined possible. Not just better, but a whole nother level of amazing! Thanks guys!
  • SIHAB
    SIHAB Posts: 5,604
    So, I quietly moved my ATCs to studio two and camouflaged them
    in an attempt to go unnoticed.
  • jbreezy5
    jbreezy5 Posts: 1,141
    I have streamed from my iphone to BlueSound Node 2i, but lacked the will and time to set-up its network feature-set. Yet, I wanted to access my music files stored on my PC.
    Today, after much online research to make sure I had the appropriate IP address, Admin auth, guest usage, network settings, etc., I still had no success getting it configured to recognize my PC library on the BS app.
    Finally, I connected my 1TB external SSD to the USB input and the Node 2i recognized it immediately with no effort.
    For those BlueSound Node 2i users, who (like me) don’t enjoy spending their weekend fighting with their computer, hope this helps.
    edited September 2022
    Spinning some vinyl! Picked up a pile of freebies. Some are garbage but some are in great shape!
  • tratliff
    tratliff Posts: 1,811
    Built some custom cables for my subs. These are made for the high level inputs of my REL Carbons. They are made up of Furutech Alpha cables, AudioQuest spades and neutrik speak-on connectors.
  • skipshot12
    skipshot12 Posts: 2,092
    I’m on my 5th mid woofer on the upgrades for my SDA SRS’s.
    First speaker done, the left, and wrapping up the right.
    Next project is to attack the crossovers.
    Haven’t decided yet whether to just replace or upgrade the caps & resistors.
  • skipshot12
    Hey VR3….
    I’m wondering how you find the bottom end, bass, of the KW’s?
    I had the the KW 500.
    Loved the sound but found with my speakers it didn’t have any slam on the lower freq’s.
    VR3 Posts: 29,550
    Bass is dependent on many things but the kw750 definitely is capable of amplifying the bass frequencies
    Yeah, it has no problem at all with the lower and lowest of frequencies. If the gear produces it and the speakers can distribute it? It has all one will ever need. Unadulterated, clean, controlled, pure power.
    What speakers did you run the KW500 with?
  • skipshot12
    Legacy-Audio Focus, the originals.
    Then infinity prelude mts.
    Hade the legacy focus being pushed by simaudio w-10’s before the kw.
    I felt I lost some bottom end slam at louder levels with the kw.
    I must add…. We do have a tendency to play at really loud levels.
    Skip
  • jdjohn
    jdjohn Posts: 3,384
    Musical Fidelity X-150
    Per the owner's manual:
    105WPC into 8 ohms
    141WPC into 4 ohms
    Peak-to-Peak output current: 50 amps
    SNR >98dB (A-weighted)
    Other online sources have slightly different output specs, but still close.
    It's a half-size footprint amp from the X series (only ~8.5" wide), but still very powerful. I haven't tried the phonostage yet. I'm trying to NOT bring too much attention to it in the household...if you know what I mean ;) It should be a good foundation for a second, third, or whatever, system B)
  • tratliff
    jdjohn wrote: »
    I would never do that. B)
    Cool volume knob.
    SCompRacer Posts: 9,123
    Clipdat wrote: »
    Cool volume knob.
    We're talking turning it up way past 11 now.
    Nice X!
  • jdjohn
    jdjohn Posts: 3,384
    "X gon' give it to ya!"
    WARNING: Explicit language
    https://youtu.be/fGx6K90TmCI
