Tube Amp released magic smoke...
My right channel decided to put on a show for me this morning, with the second tube from the left flashing a bright blue several times then going dark, as the fuses in both locations literally exploded in the sockets and the magic smoke appeared. I have opened it up, but everything looks clean internally, except the fuses. Transformers are also good, with no smell of burn or melted wires.
One resistor looks a little scorched in one spot, but everything else is clean. After 10 years of near daily use, I think now would be a good time to pull them from service and get them looked at... They will be out for the next six to eight weeks. Man, this sucks.
    Clipdat Posts: 12,607
    This is good time to go Class D.
    nooshinjohn Posts: 25,100
    You sending them to Frank for repair?
    I wish middle finger emoji was available on this site😂😎
    Clipdat wrote: »
    Uhmmmm…. NO!
  • maxward
    maxward Posts: 1,517
    Do you have a backup?
    treitz3 Posts: 18,334
    Now, that there is the funniest damned thing I have read in a long time! Quick wit, Ivan...LOL
    John, that bites. This is the number one reason I got out of having tube amps. Yours lasted a lot longer than any of mine but still. I just got tired of the maintenance aspect of tube amps. They are so finicky. They sound great, mind you but they are akin to having a nagging woman.....always needing your attention and denying you of what you want to do for whatever reason.
    maxward wrote: »
    I will need to pull my amp that I use for my height channels. It is a Marantz 7025...
    In all seriousness John I have one of these I could easily ship down to you if you need/want a loaner. LMK.
    https://boxem-audio.eu/en/stereo-amplifiers/2-91-arthur-2408n2.html
    That’s why I love this place. Thank you for the kindness but I’m covered. I haven’t use my hate channels yet anyway so I’ll give this Nampa chance to break in
    audioluvr Posts: 5,437
    If you were closer I'd loan you my Belles. Who's doin the fixin? Hi-Tech? He has expedited if you're willing to pay a little more.
    I am taking them to a local high-end shop that has a tube guru on their staff. It may cost a grand to get them back up and running, but that will be money well spent. I am specifying a few changes as well to bring them up to date.
    Bob used some redundant parts on these because he did not have some of the correct values when I was there. I was going to make the changes myself but never got around to it. This will get them cleaned up and they should be good to go for a very long time.
    Is it a trustworthy shop?
    They handle McIntosh, and a host of others, so yes, I think so. I got out my high power flashlight and think I found the problem. There is a wire wound resistor on the 8 ohm speaker output that is cooked, causing it to short. This is the same fail I had several years ago and it was an easy fix.
    heiney9 Posts: 25,081
    edited May 2022
    Clipdat wrote: »
    No one should ever go Class D. ;)
    F1nut Posts: 49,802
    Class D done right is excellent. Ken Ishiwata knew how to.
    Very few are done right........I'll have to get my ears on a Ken Ishiwata piece some time.
    F1nut Posts: 49,802
    Jeff Rowland is another.
    Jesse, I love's ya' bro but seriously?
    Can you please give me an example of one? (Not confronting, just curious as I would never buy one.....but may hear one in my travels...).
    Please advise and thanks.
    edited May 2022
    If anyone has one of the Ki Ruby's within the Tri-State area of N/SC? I will be more than willing to hook it up to my rig and I am sure the NC/SC boys will as well. I have heard Class D. Many systems. No issue. No complaints (well, for a normal system) but if you want to try it out and get a "real" evaluation?
    We are planning another GTG very soon. We can try it out on multiple systems. If you talk the talk? Well.....ya' got's ta' be willing to walk the walk.
    We do. The end result as to what hits our ears are all that matters...
    txcoastal1 Posts: 13,132
    treitz3 wrote: »
    Tri-State?
    You missed one...VA? just asking ;)
    TX behautch....that's within the tri-state, no?
    treitz3 wrote: »
    Lol... I see is NC/SC...Tri=3, just was wondering who was #3
    Don't fry me bro ;)
    txcoastal1 wrote: »
    treitz3 wrote: »
    Don't fry me bro ;)
    The third one in would be sloppy seconds...
  • tratliff
    tratliff Posts: 1,663
    Not a good way to start the weekend. Hope its an easy fix John.
    2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Silver 4+ Interconnect Cables, AudioQuest Niagara 7000 w/Dragon and Hurricane Power Cables
    Correct parts have been found and ordered. I am going to try and repair them myself by replacing a few parts in that path and replacing the tube...
    SCompRacer Posts: 8,352
    May the force be with your repairs!
    Maybe add Franks self repairing tube option..... :D
    *ToobsTheSameTempuhtureAsUrMouth'd*
    I am going to use this opportunity to get the part numbers off the transformers and order a couple sets of them. I have been wanting to do a new build so I guess no time like the present to get started.
