Tube Amp released magic smoke...
nooshinjohn
My right channel decided to put on a show for me this morning, with the second tube from the left flashing a bright blue several times then going dark, as the fuses in both locations literally exploded in the sockets and the magic smoke appeared. I have opened it up, but everything looks clean internally, except the fuses. Transformers are also good, with no smell of burn or melted wires.
One resistor looks a little scorched in one spot, but everything else is clean. After 10 years of near daily use, I think now would be a good time to pull them from service and get them looked at... They will be out for the next six to eight weeks. Man, this sucks.
You sending them to Frank for repair?
This is good time to go Class D.
I wish middle finger emoji was available on this site😂😎You sending them to Frank for repair?
Do you have a backup?
Now, that there is the funniest damned thing I have read in a long time! Quick wit, Ivan...LOL
John, that bites. This is the number one reason I got out of having tube amps. Yours lasted a lot longer than any of mine but still. I just got tired of the maintenance aspect of tube amps. They are so finicky. They sound great, mind you but they are akin to having a nagging woman.....always needing your attention and denying you of what you want to do for whatever reason.
I will need to pull my amp that I use for my height channels. It is a Marantz 7025...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
In all seriousness John I have one of these I could easily ship down to you if you need/want a loaner. LMK.
https://boxem-audio.eu/en/stereo-amplifiers/2-91-arthur-2408n2.html -
That’s why I love this place. Thank you for the kindness but I’m covered. I haven’t use my hate channels yet anyway so I’ll give this Nampa chance to break inThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
If you were closer I'd loan you my Belles. Who's doin the fixin? Hi-Tech? He has expedited if you're willing to pay a little more.Gustard X26 Pro DAC
I am taking them to a local high-end shop that has a tube guru on their staff. It may cost a grand to get them back up and running, but that will be money well spent. I am specifying a few changes as well to bring them up to date.
Bob used some redundant parts on these because he did not have some of the correct values when I was there. I was going to make the changes myself but never got around to it. This will get them cleaned up and they should be good to go for a very long time.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Is it a trustworthy shop?
They handle McIntosh, and a host of others, so yes, I think so. I got out my high power flashlight and think I found the problem. There is a wire wound resistor on the 8 ohm speaker output that is cooked, causing it to short. This is the same fail I had several years ago and it was an easy fix.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Class D done right is excellent. Ken Ishiwata knew how to.
Very few are done right........I'll have to get my ears on a Ken Ishiwata piece some time.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Jeff Rowland is another.
Jesse, I love's ya' bro but seriously?
Can you please give me an example of one? (Not confronting, just curious as I would never buy one.....but may hear one in my travels...).
Please advise and thanks.
If anyone has one of the Ki Ruby's within the Tri-State area of N/SC? I will be more than willing to hook it up to my rig and I am sure the NC/SC boys will as well. I have heard Class D. Many systems. No issue. No complaints (well, for a normal system) but if you want to try it out and get a "real" evaluation?
We are planning another GTG very soon. We can try it out on multiple systems. If you talk the talk? Well.....ya' got's ta' be willing to walk the walk.
We do. The end result as to what hits our ears are all that matters...
Tri-State?
You missed one...VA? just asking
TX behautch....that's within the tri-state, no?
Lol... I see is NC/SC...Tri=3, just was wondering who was #3TX behautch....that's within the tri-state, no?
Don't fry me bro
Not a good way to start the weekend. Hope its an easy fix John.2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables
Correct parts have been found and ordered. I am going to try and repair them myself by replacing a few parts in that path and replacing the tube...
Nice!
May the force be with your repairs!
Maybe add Franks self repairing tube option.....
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
*ToobsTheSameTempuhtureAsUrMouth'd*
I am going to use this opportunity to get the part numbers off the transformers and order a couple sets of them. I have been wanting to do a new build so I guess no time like the present to get started.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
