1…137138140142143…207
    SCompRacer Posts: 9,408
    edited April 2022
    I made an add on counterweight for my spare tonearm after the years ago putty fix had dried and cracked off. You could say I have the Midas touch.... :D (A Denon 103r is in that Midas body).
  • rebelsoul
    rebelsoul Posts: 802
    Just ordered a Denon 103 with sapphire cantaleaver and nude elliptical and ebony body.
    edited April 2022
    Congrats, great cartridge! I nuded and potted my 103r with no fatality. B)
    xschop Posts: 5,932
    edited April 2022
    I still have to machine off 0.005 from the face and add the throat profile. Haven't decided cross-hatch fly cut on mill or simple finish turn on lathe for contrast....
    Foam mount mod clears X-over nicely...
    VR3 Posts: 29,763
    That baffle is... Amazing
  • Navy_Goat
    Navy_Goat Posts: 375
    Added a pair of Trey's diffusers to my 2.3 and 2B last night. This simple addition seems to have brought the stereo image more clearly into focus. Sorry, I do not excel at describing sound. Sounds good to me, I guess that is what counts!
    SDA SRS 2.3tl, SDA 1C, SDA 2B (TL mod), Reserve 200
    xschop Posts: 5,932
    Thanks Trey, these are my 4th and final Jr's.
  • Gardenstater
    Gardenstater Posts: 4,991
    xschop wrote: ยป
    I think it is safe to say that you put the Magic(O) into those 5 jrs!
    https://www.magicoaudio.com/enclosures
    MAGICO has spent many years developing an enclosure system that successfully balances the 3 elements that constitute a proper loudspeaker enclosure: stiffness, mass, and internal damping. The graphs here show the spectral decay data across the range of typical enclosure construction methods.
    No singular material can satisfy all of the properties desirable in a loudspeaker enclosure.
    As stiffness increases, moving from MDF to phenolic resin to aluminum, cabinet vibrations are drastically reduced, although a sharpened Q of the resonance results in an audible ring.
    By damping the high Q resonance via elaborate constrained layer damping we have eliminated all energy storage and audible resonance from our enclosure.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,932
    edited April 2022
    I foamed the inner baffles on this build so I went ahead and cut out the original baffle area. I gained about 50 cu. In airspace and will try a couple different port lengths before gluing one on to the inside.
    What I learned from building these, is that Polk's cabinet builders were all over the place or inebriated lol.
    Profiled the new tweeter bezels today also...
    treitz3 Posts: 20,367
    Be careful not to over dampen them. It affects the sound greatly. I learned that the hard way.
    VR3 Posts: 29,763
    he speaks truths!
    xschop Posts: 5,932
    Hopefully with the extra baffle area removed, the foam doesn't displace the same volume that was removed.
    Sticky dome mounted. I think I like the factory black oxide Torx screw heads to match the MW....
    Roll off the edges of the baffle if you can. If not? Get a diffuser.
  • Gardenstater
    edited April 2022
    I think you should send pics to the CEO of Magico and maybe he will fly you out to the manufacturing plant in CA (perhaps in an electric airplane) for a free tour:
    https://www.soundstageglobal.com/index.php/blogging-on-audio/134-jeff-fritz/961-magico-m9-loudspeakers-no-compromises-allowed
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,932
    Are you referring to a tweeter diffuser?
    Yuppers. Sharp edges on a baffle creates unwanted reflections.
    xschop Posts: 5,932
    edited April 2022
    I've got 2 versions of Trey's anti-diffraction pads I can experiment with.
  • rebelsoul
    Picked up a box to put albums I am going to listen to for the evening.w22mcy3qd0yp.jpg
  • rebelsoul
    $16.99 at Michaels
  • Gardenstater
    edited April 2022
    xschop wrote: ยป
    Let us know what you think. I removed mine and I confirmed that I did not like what I heard so I did some measurements to see, just out of curiosity, if there was any visible difference in freq. response and I must say that despite the dip which I didn't used to have (aging tweets?), it was flatter in the 3kHz + region with both the MW and tweeter felts installed (left speaker only/right channel disconnected). It is mostly an audible thing though. Freq. response curves don't seem to show the whole picture at all. Cleaner, more transparent, more phase aligned and coherent sound could result in a less smooth curve but still sound much better. Just my opinion at this point:
    No felts:
    Tweeter felt only:
    MW and Tweeter Felt:
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    Each speaker is different, so I can't speak to yours but on my Tylers's? I have the MTM network with the diffusers. That worked better than just the tweeter diffuser.
    I don't do measurements but your observations mimic mine. The sound is much cleaner, the aura surrounding instruments and singers became more palpable, definition of location within the spatial locationality cues became sharper, certain instruments and passages got less "shouty", if you will and the overall presentation became more defined.
    The best way to describe it would be akin to if you were looking at rocks at the bottom of a slow moving stream through window panes and then those panes were removed. It simply improved the definition of what you were looking at and it allowed you to spot more texture on the rocks, observe the minute air bubbles floating by and see slight color variations within the moss that's on the rocks. It's not a night and day difference but it sure does make what you "see" much clearer.
    VR3 Posts: 29,763
    Anti diffraction pads are the way to go! ๐Ÿ˜๐Ÿ˜๐Ÿ˜๐ŸŽ‰๐ŸŽ‰๐ŸŽ‰
  • Gardenstater
    It sounded very smooth with the felts removed but all the life had been sucked out. Returning the felts the cymbals had long decay times and I had so much more airiness to the music.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    edited April 2022
    Oh, and the combination of the Felts and Heavily Rounded Cabinet Edges (or an Anti-Diffraction Frame) is really the key in my opinion and experience.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,932
    Burning in caps still, will be switching out the Dayton cap on tweeter circuit to Clarity cap and see if I hear any difference. Can't imagine the tweeters sounding better...
    These will also be getting seismic isolators next.
    Power Port or leave well enough alone?
    Even at low listening levels, I can hear low midrange coming from ports, although no 'chuffing'.
    Finally.....FINALLY got that daggum Auralic Vega G2 to play some music!
    I haven't heard it since this past Polkfest at Troy's pad. Well, I did but only was able to extract less than 3 minutes of music out of her after working on it for a collective 24 hours.
    I started again today after a good, long cooling down period and while it took me about 2 and half hours of further diagnosis? I now have sound out of her and I'm back in the streaming game.
  • 55SLA70
    55SLA70 Posts: 45
    Success!! Weโ€™ll done!
    Old Name: 55LS70Preamp: Decware CSP3 w/ 1 x Amperex 7308, 2 x Amperex 6922's, 1 x RCA 5R4GY Power Amp: Cary SLA Signature 2 X Mullard GZ32's, 2 X RCA 5691's, 4 X Tung Sol 6550 reissuesAnalog: Rega Planar 3 w/ P2000 motor, Deep Groove sub platter, Incognito tonearm wiring, JA Michell counterweight, Tangospinner feet, Dynavector 10 x 5 cartridge, Parks Audio Budgie Hybrid phono stage w/ 2 x BEL 6922's.Radio: HH Scott 330D tuner with HH Scott Type 335 multiplex. Both modified by Mapleshade.Digital: Marantz ND8006Speaker Cables: Kimber Kable 8TC'sSpeakers: Polk Audio LSIM 703'sInterconnects. Tuner: Audioquest Black Mamba II's, phono stage: Kimber Kable Hero's, PreAmp/Amp and Digital: Audioquest King Cobra"s
    Clipdat Posts: 13,107
    Enjoy!
    Now, I have to be honest....that GD Auralic Vega G2 pissed me off to no end. Those that know me or have followed my posts know why.
    Let it be known that earlier on today? I wanted to throw it in the trash (no lie).
    12 hours of constant listening? There is some serious merit to why I chose this player. 4 hours ago? I would have laughed if you told me I would say this.
    It's just now starting to "bloom" and there are now aspects to where....
    Well, I'll save that for day three.
    I HATED what I heard when I first heard it earlier on today.....but I heard it playing for the first time in months. After 12 hours? I have to say that I am fairly impressed. This is a nice unit. More to come.
