RD0 Billet Faceplate Upgrade
13»
    xschop Posts: 5,927
    Toolfan66 wrote: »
    xschop wrote: »
    Aesthetics is one thing. I prefer the black and billet look. But if you're worried about oxidation, don't. I built these 6061 billet baffle plates a few years ago and they're untreated and unwaxed/polished even....
    I always wanted to build a set of monitor 7's out of billet aluminum..
    That'd definitely fix any baffle flex.
    Tony M Posts: 12,035
    The grills would retire to the closet if I had fronts that looked that darn good. ;)
  • plastic_avatar
    o.O
    Whoa.
    The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage
  • Gardenstater
    Gardenstater Posts: 4,991
    How thick is that 6061 T6(?) aluminium baffle? What is the Young's Modulus? Just kidding with the 2nd question ;)
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,927
    0.625 inch @ 40,000 psi.
    What do you think the particle board modulus is?😂
    xschop Posts: 5,927
    Toolfan66 wrote: »
    xschop wrote: »
    If I were to go that route, I would mount the MW and tweeter on one of the sides and have the passive pointed to either side. Slim, Tall 7's.
  • Gardenstater
    edited March 2022
    xschop wrote: »
    ***Nerd Alert***Nerd Alert***
    MOE (Modulus of Elasticity)
    6061 T6 68.9 GPa = 9.99 x 10^6 psi
    18mm Particle Board = 2.048 GPa = 2.97 x 10^5 psi
    18mm MDF = 3.326 GPa = 4.82 x 10^5 psi
    16mm Particle Board = 3.424 GPa = 4.97 x 10^5
    16mm MDF = 3.010 GPa = 4.37 x 10^5
    This is from a Chinese study (of course) that I found the other day. Pretty weird the difference in MOE for MDF vs Particle Board for 18mm (approx 3/4") thickness.
    https://asm.matweb.com/search/SpecificMaterial.asp?bassnum=ma6061t6
    https://www.fpl.fs.fed.us/documnts/pdf2019/fpl_2019_guan001.pdf
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    The 18mm PB panels they tested were lower density than the 16mm and than the MDF, by far. I wonder if the same holds true everywhere.......
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,927
    edited March 2022
    If it is MIC, then it's a crapshoot.
    You trusted your melamine baby formula...just sayin'
    pitdogg2 Posts: 27,918
    xschop wrote: »
    Do not forget that was also sold as a dog food ingredient.
  • Gardenstater
    edited March 2022
    For Made in USA Aurauco, standard PB (Duraflake) vs standard MDF:(Trupan)
    MOE (Modulus of Elasticity):
    PB: 350,000 psi = 2.41 GPa
    MDF: 420,000 psi = 2.90 GPa
    So it kind of bears out the Chinese paper, as far as the MDF being quite a bit stiffer.
    https://na.arauco.com/en/resources/download/DURAFLAKE_PB_STANDARD
    https://na.arauco.com/en/resources/download/TRUPAN_spec-Standard
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    Sweet!
    xschop Posts: 5,927
    1st class.
    txcoastal1 Posts: 13,520
    This thread is sick!! B)
    xschop Posts: 5,927
    As long as the perimeter of the silk diaphragm interfaces with them and the throat ID of the plate snugly, you're golden.
    VR3 Posts: 29,763
    Delrin?
    I don't know if it is this thread but I saw an aluminum baffle and it looked badddd ****
    xschop Posts: 5,927
    I don't want you to have any surprises with your new gaskets/insulators, but you may end up having to trim them around the RDO magnet top plate bosses.
    xschop Posts: 5,927
    edited March 2022
    Toolfan66 wrote: »
    xschop wrote: »
    Nope, already tried the fit up early this morning, won't be a problem..
    Good deal. Just wanted you to be aware that the factory RDO bosses are designed a few thousands shorter than their diaphragms to ensure compression once magnet screws are tightened down, yet not overtorquing diaphragm plastic.
    xschop Posts: 5,927
    That is true, but you COULD be introducing an uneven compressabilty around dome perimeter that you need to look out for. Those 4 new areas of plastic that will now reside between adjacent bosses could resonate. Hopefully not since it is only .010" thick. Just an FYI
    xschop Posts: 5,927
    Hey @Toolfan66, don't know who has that crafty polishing tool, but I don't need it and appreciate the offer sending it out.
    I got another personal set of modded RDO plates programmed on CNC with their new radius to try in the XS-TL's...
    If they exibit the off-axis response like the Dayton plates do, then Ill swap the RDOs back in....
    Rob stupid question, why can you not polish them while on the lathe?
    xschop Posts: 5,927
    edited July 2023
    My phalanges are invaluable. I now have a diamond tip insert that is producing the rainbow sheen there. So this next batch will be as close as you can get to a Scotchbrite finish.😉
    msg Posts: 10,650
    I thought I read in passing on one post that it takes a while? I could be making that up. In fact, it's likely.
    F1nut Posts: 52,406
    What takes a while?
    xschop Posts: 5,927
    What takes a while?
    Trying to find a vintage set of Polks that don't look like they've been used for target practice.
    msg Posts: 10,650
    edited July 2023
    What takes a while?
    Nevermind; I misremembered when Rob said it was his fingers that were the reason for post-polishing. That was in response to Ivan's question, but my post was hit with the Vanilla Time Drift.
    Same thing that happened to the USS Nimitz. They made a documentary about it.
    xschop Posts: 5,927
    msg wrote: »
    'Fraid of a little elbow grease? There's always black paint too...
