RD0 Billet Faceplate Upgrade
13
    xschop Posts: 5,047
    Aesthetics is one thing. I prefer the black and billet look. But if you're worried about oxidation, don't. I built these 6061 billet baffle plates a few years ago and they're untreated and unwaxed/polished even....
    F1nut Posts: 51,666
    Put me on the mailing list, please.
    xschop Posts: 5,047
    Is there an "official" TL mod/addition to the original ported 5Jr x-over? Don't want to go rogue lol.
    Toolfan66 Posts: 17,979
    xschop wrote: »
    I always wanted to build a set of monitor 7's out of billet aluminum..
    F1nut Posts: 51,666
    xschop wrote: »
    Not that I'm aware of.
    xschop Posts: 5,047
    Toolfan66 wrote: »
    xschop wrote: »
    That'd definitely fix any baffle flex.
    Tony M Posts: 11,566
    The grills would retire to the closet if I had fronts that looked that darn good. ;)
  • o.O
    Whoa.
    The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage
  • Gardenstater
    Gardenstater Posts: 4,726
    How thick is that 6061 T6(?) aluminium baffle? What is the Young's Modulus? Just kidding with the 2nd question ;)
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,047
    0.625 inch @ 40,000 psi.
    What do you think the particle board modulus is?😂
    xschop Posts: 5,047
    Toolfan66 wrote: »
    xschop wrote: »
    If I were to go that route, I would mount the MW and tweeter on one of the sides and have the passive pointed to either side. Slim, Tall 7's.
  • Gardenstater
    edited March 2022
    xschop wrote: »
    ***Nerd Alert***Nerd Alert***
    MOE (Modulus of Elasticity)
    6061 T6 68.9 GPa = 9.99 x 10^6 psi
    18mm Particle Board = 2.048 GPa = 2.97 x 10^5 psi
    18mm MDF = 3.326 GPa = 4.82 x 10^5 psi
    16mm Particle Board = 3.424 GPa = 4.97 x 10^5
    16mm MDF = 3.010 GPa = 4.37 x 10^5
    This is from a Chinese study (of course) that I found the other day. Pretty weird the difference in MOE for MDF vs Particle Board for 18mm (approx 3/4") thickness.
    https://asm.matweb.com/search/SpecificMaterial.asp?bassnum=ma6061t6
    https://www.fpl.fs.fed.us/documnts/pdf2019/fpl_2019_guan001.pdf
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    The 18mm PB panels they tested were lower density than the 16mm and than the MDF, by far. I wonder if the same holds true everywhere.......
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,047
    edited March 2022
    If it is MIC, then it's a crapshoot.
    You trusted your melamine baby formula...just sayin'
    pitdogg2 Posts: 26,922
    xschop wrote: »
    Do not forget that was also sold as a dog food ingredient.
  • Gardenstater
    edited March 2022
    For Made in USA Aurauco, standard PB (Duraflake) vs standard MDF:(Trupan)
    MOE (Modulus of Elasticity):
    PB: 350,000 psi = 2.41 GPa
    MDF: 420,000 psi = 2.90 GPa
    So it kind of bears out the Chinese paper, as far as the MDF being quite a bit stiffer.
    https://na.arauco.com/en/resources/download/DURAFLAKE_PB_STANDARD
    https://na.arauco.com/en/resources/download/TRUPAN_spec-Standard
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,047
    1st class.
    edited March 2022
    I’m not sure what they use to cut these but they did end up a hair bigger than the template I set him, with a print as well. since it is very thin and very flimsy I’m sure that was part of the issue, not a big deal, and I didn’t want to bother him with it.
    So I am sandwiching them (six at a time) between two templates, and taking a small file to them, and finishing them off with emory cloth. It’s really not that bad, takes a few minutes is all, much better fit.
    txcoastal1 Posts: 13,499
    This thread is sick!! B)
    xschop Posts: 5,047
    As long as the perimeter of the silk diaphragm interfaces with them and the throat ID of the plate snugly, you're golden.
    This one was built for the SL3000/2000 tweeters so the four holes don’t line up, my new ones for the RDO’s is at the platers, but it gives you the idea..
    VR3 Posts: 29,384
    Delrin?
    I don't know if it is this thread but I saw an aluminum baffle and it looked badddd ****
    xschop Posts: 5,047
    I don't want you to have any surprises with your new gaskets/insulators, but you may end up having to trim them around the RDO magnet top plate bosses.
    xschop wrote: »
    Nope, already tried the fit up early this morning, won't be a problem..
    VR3 wrote: »
    Delrin?
    Yes delrin. yep the work on that baffle is sweet!!!
    xschop Posts: 5,047
    edited March 2022
    Toolfan66 wrote: »
    xschop wrote: »
    Good deal. Just wanted you to be aware that the factory RDO bosses are designed a few thousands shorter than their diaphragms to ensure compression once magnet screws are tightened down, yet not overtorquing diaphragm plastic.
    Post edited by xschop on
    edited March 2022
    xschop wrote: »
    Toolfan66 wrote: »
    xschop wrote: »
    Good deal. Just wanted you to be aware that the RDO bosses are designed a few thousands shorter than their diaphragms to ensure compression once magnet screws are tightened down, yet not overtorquing diaphragm plastic.
    By putting the same thickness across all of the surface you should be getting the same compression with or without it would you not? it is one of the reasons I wanted to cover the surface, yet have something better than electrical tape. Overtorquing? we are going from a plastic bezel to an aluminum billet bezel with four cross screws, well mine will be stainless hex, but that is not relevant. These are tweeters, not heads on a motor...
