The AI-1 Dreadnought Project Pt.1
It's very hard to believe it has been 10 yrs. already. Great stuff that is still very relevant today.
He got an award from Polk years ago.
Think of how many wallets opened up over the years because of Ray’s hard work, and dedication to the hobby. He has done this with selflessness, and shared all to help many of us achieve the same goal, if I had to pick one member here (and there are many well deserving members) that should get an award for their work and help to achieve better audio, I would nominate Ray for that reward..
With that said, Thank you Ray!!!
With that being said Larry you too have done a ton to help us all out to my friend.
Thanks to you as well... -
deletedSDA SRS 2.3TL's
SDA 2B TL's -
Built a new case, looking for ideas for labeling on the outside for the right and left channels.SDA SRS 2.3TL's
SDA 2B TL's -
Good question!SDA SRS 2.3TL's
SDA 2B TL's -
The side on the right is right, left is left, assuming you lay it flat. Always worked well that way for me. No need to label. Otherwise, I've never found any difference with which side is which.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
SDA SRS 2.3TL's
SDA 2B TL's -
michaeljhsda2 wrote: »Built a new case, looking for ideas for labeling on the outside for the right and left channels.What matters most is the transformer is wired correctly in the case. I just did a test, played two of my favorite tracks on the SDA’s, I flipped the dreadnought on both tracks, sounded incredible both ways, I did not hear any changes in stage presentation..
The Dreadnought is based on a 1:1 isolation transformer, so, as Toolfan said, as long as it is wired correctly per the manufacturer's diagram, it does not matter which side you label left or right.Proud and loyal citizen of the Digital Domain and Solid State Country! -
Welcome back Raife
DarqueKnight and Toolfan66, Good to know after all these years."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
O.k., Dreadnought nerds, a question:
Realistically, is it worth using the 800va coil since the 1000va coil isn't available?
Is it something I'm going to notice the difference on with my 1c project. Or is it degrees of a smidge of a difference?The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage -
The Polk-supplied AI-1 used a 0.13-ampere current-capacity, and 15VA (!!!) transformer.plastic_avatar wrote: »Realistically, is it worth using the 800va coil since the 1000va coil isn't available?
Matthew Polk suggested a transformer that could handle "5+ amperes" peak current.
The 800 VA transformer is rated for two RCHs less than 7 amps.
Folks with better ears than mine say that there's still improvement in the larger transformer. You may be letting "perfect" be the enemy of "good"; I wouldn't NOT use an 800 VA transformer because I was waiting on a 1000 VA transformer. -
I'm stepping into enemy of good territory at the moment, I do agree.
I'm months out from realistically going Dreadnought facsimile, and have the other coils and internal wires to consider on the way. BUT, I'm trying to suss out all the options while I chug towards my first listen on the upgraded 1c. I didn't even attempt to test them out before I stripped them down. I want the experience to be totally new.
Anyhow
Yeah. if 800va is an audible improvement over stock? I think that'll do me when the time comes
I did find this thread to digest.
https://forum.polkaudio.com/discussion/131537/plitron-1000va-transformer-evaluationThe Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage -
The Avel-Lindberg 800VA Y236906 is off the shelf model, meaning stocked all the time. I've used it it works very good. I seriously doubt there will ever be a group effort again to get the minimum number needed, not to mention it's cost is going to be close to $300 each if not more.
Get the 800va and do not look back.
The only reason I sold my 800va was because I was sharing lead in the last group buy. Unlike previous group buys IIRC we did not get bigger discounts after a certain number. Cost did go down once we hit a certain number threshold but did not continue to drop if we doubled the count.
Get the 800va...... -
Depends on the quality of the equipment upstream and your ears. As for me I thought I could hear a slight difference but it could have been the placebo effectGustard X26 Pro DAC
