What should I do (or what would you do)?
I picked up the guts of a 5A. Peerless tweeters, mw6500, and the PR. And crossovers
All in very good condition.
Should I build a m5 cabinet for them, I am confident enough in my woodworking skills to duplicate the cabinets. (i would probably go with wood on the front)
I have 2 sets of m4s, one m5a, one m7a all with Peerless and mw6500.
Just curious what others would do if they were in my position.
M7's 1982 Peerless tweeters
M5's X2 (1981 Peerless tweeters, 1988 with upgraded tweeters)
M4's X2 both with Peerless tweeters
M5Jr with SL1500 (in the garage, they sound great)
M4.6 series2 X2 with upgraded tweeters
SDA 2 with upgraded tweeters
    VR3 Posts: 29,394
    I mean technically building a box would also be spare parts... Just spare parts you are listneing to
    xschop Posts: 5,082
    Build the enclosures with a little more airspace. Maybe add a small weight to the PR and get them to dig lower.
  • VR3 wrote: »
    True, I guess, for anything that one is not using...
  • xschop wrote: »
    What do you mean by adding weight...?
    xschop Posts: 5,082
    edited February 2022
    wispolkboy wrote: »
    xschop wrote: »
    I have 5B's and wish they dug deeper like the 7's do, but keep their smaller footprint. You may have to experiment with adding small gram weights at a time until it is tuned to your liking.
  • I love my 7s bass... I wonder if I just make the cabinets a bit bigger... Not much but just to see. My 5a's with my xo upgrade was a big improvement...
  • F1nut wrote: »
    Build new cabinets the correct size/volume and add a sub if you want deeper bass. :)
    That was my original thought as well... I like to get feedback from people on this forum... So much knowledge.
  • I believe my 5a's are particleboard, but I think that i would go with MDF... Is that a good idea?
  • SIHAB
    SIHAB Posts: 5,402
  • SIHAB wrote: »
    Interesting,.... I think if I didn't have something to copy or if I was making something from scratch I would use this. Have you or anyone else use this to make a new cabinet with polk speaker components?
    xschop Posts: 5,082
    wispolkboy wrote: »
    Yes, and countersink the drivers on the baffle while you're at it.
  • SIHAB
    SIHAB Posts: 5,402
    what I was thinking was, if you like the 7's but can't fit them,
    skip the passive radiator and build a two way to suit.
    (plus the suggested subwoofer in a convenient place)
    No, I haven't done this with the 5's...
  • Build thuh box!
    Build thuh box!
    Build thuh...
    Srsly, that would be a neat project =)
    The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage
  • Gardenstater
    Gardenstater Posts: 4,751
    I think I would make an enclosure the same volume or if speaker calculators say larger might be better, go a bit larger and modify passive weight to tune, but try to make more of a pyramidal shaped enclosure and countersink the drivers in the front baffle which is 2 thicknesses of MDF. That would allow a 1" radius roundover on the front baffle and also non-parallel sides tend to defeat internal standing waves and the narrower cabinet towards the tweeter and midwoofer end will promote better imaging.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,082
    Calculate the volume of the 7's and 5's, then divide by 2. That's the volume I'd go with.
    F1nut Posts: 51,689
    wispolkboy wrote: »
    Yes.
  • I think I would make an enclosure the same volume or if speaker calculators say larger might be better, go a bit larger and modify passive weight to tune, but try to make more of a pyramidal shaped enclosure and countersink the drivers in the front baffle which is 2 thicknesses of MDF. That would allow a 1" radius roundover on the front baffle and also non-parallel sides tend to defeat internal standing waves and the narrower cabinet towards the tweeter and midwoofer end will promote better imaging.
    Do you have a rough plan for this? So something like 14" at the base and tapering to 8" at the top?... This is just an example...
  • Gardenstater
    wispolkboy wrote: »
    That's the idea, but to determine the exact dimensions I'd use a CAD program which would calculate internal volume. I'd probably slope the front baffle and sides but keep the rear plumb/vertical. I'd make relief cuts on the inner baffle layer coinciding with the basket windows on the MW and Passive (sort of like a 4 leaf clover) and maybe even go with 1" MDF for the outer baffle layer but countersink deeper than basket flange and also have an external 1/2" roundover. That would also work with a future trim ring that could be coming sometime (who knows). The 1" MDF would have hardwood around the perimeter so that could be radiused and you wouldn't have to do any crazy veneer bending. The rest would be wood veneer except maybe matte black painted finish for the front baffle because of the 1/2" roundovers.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • I see what you are getting at... An interesting idea.
    xschop Posts: 5,082
    I've always liked the Epicure 3.0's. Rare birds.
  • Nightfall
    Nightfall Posts: 10,084
    I'd stick with original cabinet size/volume.
    afterburnt wrote: »
    Village Idiot of Club Polk
    audioluvr Posts: 5,882
    You could build an awesome center channel speaker
  • audioluvr wrote: »
    Thats a good idea, I would have no idea how the crossover would be. And the structure of the cabinet. Such as internal bracing. Do you know of anyone that has done this?
  • westmassguy
    westmassguy Posts: 6,850
    Thanks for dragging me kicking and screaming into this Ivan.
    My advice, build two enclosures with the exact same internal dimensions as the originals. The hard part has already been done: crossover design, and passive radiator size and weighting. Polk had/has some really smart people in R&D who forgot what I know. Keep it simple!
    BTW, my center channel project used 5jr+ parts, not the early full size Monitor 5s.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    pitdogg2 Posts: 26,956
    I'm sorry Dave I couldn't find your thread with your excellent pictures.
    Please forgive me.
  • It would be a huge center channel with the pr from a regular 5a.
    I have decided to build an exact copy (size) of a 5a. Going to use mahogany MDF. Same for the face of the speaker.
  • westmassguy
    Please forgive me.
    Just busting your chops Ivan :)
    Oh and BTW, my center channel thread is in my signature dufus
    Please forgive me.
    LMAO ya know ever since we have legal weed in Illinois my memory has..... Wait what were we talking about?
