1.2TLs A Winter Project
    audioluvr Posts: 6,017
    Better caps are an investment you won't regret and are a relatively inexpensive step up compared to other components in the chain.
  • bored184
    bored184 Posts: 332
    edited December 2021
    Out of curiosity I did some pricing. Prices do not include taxes and shipping.
    Erse: $47.07
    Clarity PX (getting the right values required some paralleling of caps to get the right values): $97.10
    Sonicaps: $496.26
    Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
    Amplifiers: ]Ashly FTX 2001 III, Dynaco ST-70, DIY F6
    Pre: Adcom GFP 750, Aikido Tube Pre
    pitdogg2 Posts: 27,620
    I've spent a ton of money on 3 different SDA's for caps and resistors. SDA 1signature, SDA 2a and SDA SRS 2.3tl.
    I'm not in the least bit disappointed that I spent the money I did. Every time it was much more than I really wanted or could afford. Each time they went on a CC. Not once did I think "ya know I should have saved money and got the lesser product". I know had I got the cheaper version or cut corners I would have had in the back of my mind "what if" do not get the what if's. Most everyone here has been in your shoes.
    Sonicaps are great because they have the EXACT values needed and they sound good, very good if you're asking.
    Clarity has alway been just close enough yet not exact. They make very good caps, step up to the CSA/SA caps shouldn't be but a few dollars more. Put them in the critical areas and use the PX in the non-critical areas.
    The Erse are not worth the difference for that little amount of money saved.
    Lets be realistic here. You want to be able to smile and enjoy the heck out of these when completed, and you certainly will with good caps and resistors.
    I've always in the back of my mind wondered what a full compliment of Clarity CMR's would have brought to the enjoyment over my Sonicaps.
    One day I'll find out.
  • bored184
    bored184 Posts: 332
    Truer words could not of been more said!
    Looking at the schematic what is considered critical areas?
    VR3 Posts: 29,638
    I can say with some confidence that the cmr cap bypassed with a duelund jdm or cast is about as good as it gets unless you go full duelund cast.
    The price difference between those two are pretty substantial.
    The cmr for the price is one of the best on the market. The amount of transparency, detail, staging they are capable of is addicting.
    Path resistors are also pretty incredible
    Toolfan66 Posts: 18,303
    I actually have two sets of crossovers for my 1.2TL’s, one with Sonicaps, and Duelund’s, and another set with Clarity MR’s, and Duelund’s.. All of the inductors have been upgraded as well on both sets.
    My advice echoes Ivan’s, just bite the bullet, and get quality parts, IMO go with Sonicaps, and Mills, and call it a day, if you get the bug later down the line you can look at upgrading the inductors..
    Here is how my list would go if in your shoes, (without knowing your budget or financial situation) so I will keep it real.
    Tweeters RDO-198’s (what is in there has to go)
    Replacement Driver, this just might be the toughest part for you, but you will..
    Spikes, yes I said it, a very budget friendly upgrade..
    Dynamat the baskets on the drivers, and passives, another budget friendly upgrade..
    Black Hole 5 to place on the back wall directly behind the drivers, only suggesting this while you have the cabinets open, but can wait till a later date..
    Sonicaps and Mills for the Crossovers.
    Sit back and enjoy..
    On a later date when, and if you get the bug, you can order upgraded inductors, especially the 16mh, and order Duelund resistors.
    Or better yet build a dreadnought, with an 800VA, or if you can find someone willing to sell you a 1000va as these are not sold right off the shelf..
    Just food for thought..
    Enjoy your upgrades nonetheless…
  • bored184
    bored184 Posts: 332
    Just ordered 8 tweeters. I can now put what 198s I had back in my modded monitor 10s, RTA 11TLs and soon to be modded SDA 2Bs.
    Toolfan66 wrote: »
    Will the sonic barrier from parts express work and if so which version the AB-4 or the MX-4?
    Would the black hole 5 be cut in strips behind the drivers like the polyfill or is squares behind the drivers?
    VR3 Posts: 29,638
    If you do not use bh5, no rez is the next best thing
    Sonic barrier 3/4 in its a good product but not as good as the other two
  • bored184
    bored184 Posts: 332
    VR3 wrote: »
    How does the bh5 or no rez get attached to the back of the drivers? Individual squares behind the driver or a single strip moving from top to bottom behind the drivers?
    VR3 Posts: 29,638
    No, it is Placed behind the drivers on the enclosure wall.. Left center, back center to left and right array, then center right
    You would cut the BH5 into 4” wide strips 24” long, and place on the back wall behind the drivers, you will still put the polyfill back in place..
    F1nut Posts: 52,182
    bored184 wrote: »
    VR3 wrote: »
    A single strip 3 to 4 inches wide attached to the back wall directly behind the mid-drivers only. The strip should be as long as the distance from the top to bottom mid-drivers.
    Edit: Oops, already answered....lol
    Toolfan66 wrote: »
    In my 2.3tl's I also ran a 3" strip along the sides. Once again just the same length as the drivers.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    If you have to, wait and save until you can afford at least the Sonicaps/Mills combo. Sonicraft will occasionally have a sale that will cut the price enough to be able to afford some better quality Binding Posts ;)
    Enjoy the process B)
  • JayCee
    JayCee Posts: 1,509
    Toolfan66 wrote: »
    https://forum.polkaudio.com/discussion/148198/blackhole-5-damping-material-in-the-sda-srs-1-2tl/p1
    edit to add....Interesting, Ray put it behind the tweeters. Don't think it's the current line of thinking??? I didn't do it. Too many threads to cull through!
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
    xschop Posts: 5,677
    Holler if you need a set of XS semi-rings. I made a few more this weekend out of stock plate I had so I can send Jaycee the rest of his.
    JayCee wrote: »
    Toolfan66 wrote: »
    I saw that as well, I didn’t do it either, don’t think it’s worth opening up my speakers for.. 😆
  • JayCee
    JayCee Posts: 1,509
    Yah, I've been in in mine several times this past year but had to think long and hard..."did I or didn't I?" before I posted above.
    I used this Sonic Barrier and have been pleased with the results.
    https://www.parts-express.com/Sonic-Barrier-1-1-4-3-Layer-Damping-Material-w-PSA-18-x-24-260-535
    Black hole or sonic barrier behind the tweeter is a waste. Since the tweeter is sealed there's not much if any backwave like the open structure of the mid-woofer.
  • Gardenstater
    I seem to remember Darqueknight saying somewhere that he put those pieces behind the tweeters just to get more volume of BH5 into the speaker and that it wasn't because he thought tweeters had a backwave. In my mind, with 2 arrays of MW drivers close to that area on each side, there could very well be standing waves behind the tweeters too and the BH5 could help with that.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    Standing waves in the SRS speakers especially are rectified by the dado cuts in the MDF.
    F1nut Posts: 52,182
    In the 4th and 5th generation.
    F1nut Posts: 52,182
    BINGO!!!
  • bored184
    bored184 Posts: 332
    I wondered why those dado cuts where in there.
  • bored184
    bored184 Posts: 332
    xschop wrote: »
    Thanks, I'll keep that in mind.
  • bored184
    bored184 Posts: 332
    Photo of the dado cuts I meant to add with my original response.
    That is one clean looking speaker, I am used to seeing glue running down the corners..
