1.2TLs A Winter Project
Picked these up the other day. As you can see they need some work. The tweeters are pyle drivers and the driver is a JBL car speaker. This should be a fun winter project.
Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
Amplifiers: ]Ashly FTX 2001 III, Dynaco ST-70, DIY F6
Pre: Adcom GFP 750, Aikido Tube Pre
«134
    Toolfan66 Posts: 18,082
    Hope you picked them up for a good price to offset the cost of some of the work..
    Have fun, and enjoy!!!
  • Amazing what that previous owner did there to avoid coughing up for the correct parts. Can't help but be curious about the tweeters. They are dome tweeters? OEM from "Pyle" or cobbled together with DIY bezels that don't quite fit the cutouts?
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,198
    Someone's been naughty to those.
  • bored184
    bored184 Posts: 329
    They are OEM from Pyle labeled "Pyle Drivers" on the magnets. They appear to be dome treaters but they have a plastic piece protecting the dome.
    Toolfan66 wrote: »
    I think I did? Haha. I did the math ahead of time and it was a "ok" deal. I wouldn't consider it a "great" deal or a "steal" but I am happy.
    The problem is I picked up some 2Bs not that long ago. I will be finishing that TL mod while working on these.
    pitdogg2 Posts: 27,079
    How did you determine they are 1.2tl and not 1.2?
  • bored184
    bored184 Posts: 329
    Pulled the crossover, they are marked BE-2000C. Pretty sure from the date these are early 1.2TLs. Prior to purchase I read and reread the SDA Handbook. Going into the deal I was pretty sure they were 1.2TLs because of the bolt pattern on the metal cover. If the bolt pattern was for the 1.2s I would been a bit more apprehensive because of Polks habit of using left over parts during a revision. Seeing as these had the "newest" bolt pattern I was pretty confident they were 1.2TLs.
    edited December 2021
    Most of the 1.2's had the same plate as the 1.2TL's, you can also pull the passive and see if there is a added brace behind it along the back wall..
    Not that it would matter, you're going to need tweeters, and you can mod them to 1.2TL's anyway, that is what I did to mine..
    Also, if someone fried the original tweeters, I am surprised the crossover looks as clean as it does..
  • 1. Remove one of the tweeters and note if each quick connect (positive and negative) is the same size. If they are, then they are 1.2's, not 1.2TL's. If the negative (white wire) connector is larger than the positive (colored wire), they are 1.2 TL's.
    2. Plug the tweeter wire harness into the Molex socket on the circuit board and note if the 4 colored wires (positives) are on each negative position (+ and - is printed on the circuit board) and the white wires (negative wires) are on each positive position. If so, then they are wired (correctly) as 1.2 TL's. If not then they are 1.2's and if you're interested in converting them to 1.2 TL's, you will need to reverse the wires using a Molex removal tool. To complete the process of converting them to 1.2 TL's, you will need to install a larger quick connector on the white (-) wire at the tweeters to accommodate the RD0-198 tweeters.
    I can't remember what capacitors, etc need to be changed on the board to finish the conversion to 1.2TL's....
    SDA SRS 2.3TL's
    SDA 2B TL's
  • bored184
    bored184 Posts: 329
    Toolfan66 wrote: »
    I am running a bit ahead of what I am posting progress wise. Trying to get my thoughts and notes organized before I post.
    I had enough 198 tweeters between some other Polk's and a few stashed back that I was able to populate these and give them a test. These sound very veiled and lack in midrange, honestly the SDA 2As that I recently sold sounded better then these. I've pulled and measured all the drivers and they measure fine. While I have the cabinets apart I will be epoxying the drivers and sealing the cabinets.
  • bored184 wrote: »
    Sounds like you have 1.2TL's since you were able to connect the tweeters. B)
    SDA SRS 2.3TL's
    SDA 2B TL's
  • bored184
    bored184 Posts: 329
    bored184 wrote: »
    It wasn't quite that simple, haha. When they swapped out the tweeters they also installed wider disconnects on the positive side. I had to go back in their and install the right size. The connections were the standard type you would find at any auto parts store. If the original connectors were for the SL2000 tweeters they would of not needed replacing because they would of been able to mount on the Pyle Drivers.
    xschop Posts: 5,198
    1.2 PL's.... Sorry couldn't resist
  • bored184 wrote: »
    bored184 wrote: »
    Gotcha. Were you able to confirm the reverse polarity at the circuit board?
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Does the large sticker on the back of each Speaker Cabinet show positive on the left?
    SDA SRS 2.3TL's
    SDA 2B TL's
    You look to have 1.2TL's That's a shame what was done to them, but look to be in good hands..
  • invalid
    invalid Posts: 1,469
    Well look at the bright side, they didn't ruin the cabinets.
  • bored184
    bored184 Posts: 329
    I've been using the schematics and wiring diagrams in the SDA Handbook.
  • Make sure the positive red binding post nuts are on the left, ignore the sticker on the back because it could be an old label leftover from the original SRS what shows red on the right
    SDA SRS 2.3TL's
    SDA 2B TL's
    F1nut Posts: 51,818
    bored184 wrote: »
    That's not what he asked.
  • bored184
    bored184 Posts: 329
    I see, I was thinking internal not external. I am in the process of making new jumpers, the DIY ones that came with them were bad.
    bored184 wrote: »
    I see that now.
  • Looks good, yeah those stock jumpers are pretty bad.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • bored184
    bored184 Posts: 329
    I know I'll probably get flamed for this but I'll probably do the recap with Erse capicitors first. Later on down the road I can slowly upgrade to better capicitors. December and January are expensive months for me.
    I've got the right speaker sealed and all the drivers epoxied. Sometime next week I should be able to do the same on the left speaker.
    VR3 Posts: 29,448
    Clarity cap px are great caps on a budget
  • bored184
    bored184 Posts: 329
    VR3 wrote: »
    They are and I may eventually go that route. Erse is more of a stopgap, better then the original while letting me focus on other aspects of restoring and modding these.
    bored184 wrote: »
    VR3 wrote: »
    Stop!
    Your going to waste good money on those Erse that could benefit you better down the line on something else.
    The stuff you have in it right now is as good as the Erse stuff.
  • bored184
    bored184 Posts: 329
    bored184 wrote: »
    VR3 wrote: »
    Stop!
    Really? I know Erse is frowned upon compared to Clarity or Sonicaps but I assumed they would atleast be better then what's in them now.
  • bored184
    bored184 Posts: 329
    I do know if I can lay my hands on set of gimpod boards I definitely would not use Erse in those.
    VR3 Posts: 29,448
    Clarity cap px has to be really close in price to erse.... Very affordable and much better
    IMHO of course, I feel it's a sideways move. Buy once cry once. Clarity makes a range of price points. I would have to run the cost comparison. Even if it's a hundred dollars more there you go one and done.
    Once again just my opinion.
  • indyhawg
    indyhawg Posts: 1,672
    Buy once cry once.
    Signature material there, Ivan.
