LED Turntable released by Brian Eno
It's an interesting project. I imagine the novelty wears off pretty quickly and the price must be eye-watering ("Enquire" is the only way to find out). That said, it would be pretty fun to listen to the Yes Fragile one step or Pink Floyd Echoes on this.
https://www.musicradar.com/news/brian-eno-led-turntable
https://www.paulstolper.com/artists/56-brian-eno/works/143-turntable/
Primary: Doshi V3.0 pre and phonostage, Vandersteen M5-HPA, Vandersteen Quatro CT, AMG viella, Goldfinger Statement, AQ Niagara 5000, AQ IC and power cords, Mapleshade Samson V.5
Secondary: Nakamichi PA7, Nak CA5, Polk LS90, Sota Sapphire, Sumiko MDC800, Van den hul Crimson
  • maxward
    maxward Posts: 1,732
    Interesting. Darko.audio has a piece on this, too. He speculates about which manufacturer is making it. He thinks it might be Clearaudio, but the arm looks to be be more like ProJect.
  • Emlyn
    Emlyn Posts: 4,888
    My guess is the artist took an existing Pro-Ject model turntable with an inexpensive Ortofon cartridge and built a plastic light box around it.
    I am a Brian Eno fan though.
    treitz3 Posts: 20,239
    Hello, DividedSky and good afternoon to you. Glad to see that you decided on joining in on the discussions.
    IMO, the last thing that I want in my listening room (especially at night) is light. When I turn off all of the lights, even the displays on the rig are turned off. Not only for better sound quality but for the loss of light.
  • TEAforONE
    TEAforONE Posts: 1,100
    edited December 2021
    It’s definitely got the “cool” looking factor. I used a strip of blue led’s.
    mhardy6647 Posts: 35,455
    strobes in the base and/or platter would have been... interesting.
    "No sales to epileptics."
    msg Posts: 10,592
    I like the lights a lot. As long as I'm able to control them.
    I need a good turntable lamp. DK had a post a while back where he made some gels that I thought were pretty cool. I've just had my vinyl obsession renewed and back at it. Can't seem to find any lamps I like though. Too many choices, most of them cheap garbage or too bright.
    I do like the mood of the Eno and of TFO's
    TEAforONE wrote: »
    msg Posts: 10,592
    That looks like that could work nicely.
  • DividedSky
    treitz3 wrote: »
    I should probably try total darkness as I do really enjoy low light as well. But I also enjoy changing up the lighting/atmosphere. Most times just a few candles/oil lights… on rare occasions with the right music/friends I will break out small light rig and hazer (not a smoke machine).
    Clipdat Posts: 13,101
    Nice TT bro'. 😉
    Eh. It's okay.
    Tonearm could be longer, for starters.
  • jdjohn
    jdjohn Posts: 3,425
    But only if there were strobe markings on the side of the platter :) I don't see any 'fine-pitch-tuning' adjustment pots :p
    @DividedSky I will echo Tom's welcome, and glad to see you hanging around. But...I have to ask about the guy circled in this pic:
    Is that merely a threaded weight to add mass, or an audio 'tweak'? I promise, I am not trying to set you up for a debate...just curious.
    Always interesting to see a new brand introduced. AMG...I thought that was Mercedes Benz American Motor Group line of performance cars :p
    Clipdat wrote: »
    It's 12 inches, dude...what are you looking for???
    Tony M Posts: 11,925
    These Sparkly Lamps have been great low-level lights for decades around here. In fact, I just placed one above my cottage fridge the other night and left it on for a while. :D I've seen quite a few lava lamps in people's stereo set-ups over the years. Not in person, just on the web.
    I know the lamp isn't beside my TT's but one placed there would be fine with me. I have a painting light over the center TT now for low-level. I also have that "dollar general" $2.50 light I've been using for a year just above and to the left.
  • DividedSky
    Clipdat wrote: »
    Haha! Yeah there you go, now that's a tonearm!
    audioluvr Posts: 6,037
    Clipdat wrote: »
    Won't LED lighting give of RF interference that close? I have to unplug my Wifi antenna for my streamer & Ring security system, my cell phone booster and turn off my living room lights when playing vinyl.
  • jdjohn
    jdjohn Posts: 3,425
    Ok, my bad. I thought Drew was dissing the AMG tonearm...not the LED tonearm. I should know better! Move along, people...nothing to see here :)
    Wait...still interested in that weight on top of @DividedSky 's tonearm/headshell.
    audioluvr wrote: »
    Clipdat wrote: »
    Depends on how they're driven -- LEDs are, first and foremost, diodes. Feed 'em clean DC and they shouldn't do much except light up.
  • jdjohn
    jdjohn Posts: 3,425
    Light Emitting Diodes, to be specific, and of course, you are right (as usual) @mhardy6647.
    We would need Neon bulbs (or some equivalent) in order to get a 60Hz light emission suitable for strobe timing.
  • DividedSky
    jdjohn wrote: »
    Thanks for the welcome! So its not a weight… it’s basically a third screw for cart mounting. It doesn’t screw down into the cartridge of course, but rather, into a washer that is designed to make the cartridge mounting a little easier.
    The amg tonearm head has three slots. The two outboard slots are for typical cartridge screws. The middle is for that large “knurl” screw. The process for mounting a cart is that you use the included washer/spacer and attach the outer cartridge screws to the washer. Then you can easily attach the washer/cartridge combo unit to the tonearm head with that large screw. It just makes for a slightly easier mounting process and then it’s still very easily adjustable for alignment etc. I hope that description makes sense.
    My understanding is that the company was definitely playing on the mercedes performance moniker but with a different acronym of course. That kind of move would probably bring a lawsuit here in the United States!
    Cheers! Frank
  • DividedSky
    Tony M wrote: »
    Love the art there with that light. I had a lava lamp in my listening area for a while that I enjoyed but my daughter took it back from me and I was pissed (but it was hers).
  • jdjohn
    jdjohn Posts: 3,425
    DividedSky wrote: »
    Cheers! Frank
    Thanks for explaining, Frank. It is NOT unusual for higher-end manufacturers to engineer an easier mounting process, so kudos to AMG for that. You may be aware of some 'products' that offer tiny little plugs for strategic placement on headshells for some sort of acoustic improvement. I have no direct experience with those.
    Regarding the AMG moniker, I have no doubt that some music lovers got sucked into that vortex. We will have to depend on you to say whether it is worth the price of admission...and perhaps some comparisons to other, previous gear.
    gudnoyez Posts: 8,201
    No problem with my Clearaudio Bluemotion just stick a submersible puck or a string of these Phillips led string lights up under the platter and look at the pretty lights. The Wife got me the puck shopping at Ross the other day she knows I like my lights when spinning some Vinyl. With the puck there is a remote with different colors, jump and Fade patterns when your listening to some of those early Floyd Albums. Cant do that with my Technics Tables.
    jdjohn wrote: »
    Actually, LEDs fed AC of known frequency (doesn't have to be 50 or 60 Hz, just known and with an appropriately calibrated disc) will make a simply grand strobe.
    The ol' Technics SL-Q2, e.g., uses a red LED (not the traditonial neon bulb) for its stobe -- the strobe being about as useful on a quartz-locked, non-adjustable tt (the SL-Q2) as a tachometer is on a car with an ordinary automatic transmission ;)
    24216429785_2ef0ace7e3_b.jpgDSC_2464 by Mark Hardy, on Flickr
    Even incandescent bulbs will exhibit some stobe effect when they're lit with AC. The filament, of course, doesn't go completely dark as the waveform passes through zero V, but the brightness of the filament does wax and wane throughout the AC cycle, and a strobe disc can usually be read when illuminated with bright incandescent lamps in a home environment. Try it some time (if you can find an old-school incandescent bulb)! :)
    Fluorescent bulbs (at least the old-school kind) will work OK with a strobe disc, too.
  • motorstereo
    motorstereo Posts: 2,401
    I've been using 12 volt automotive led strips underneath my CA emotion for several years as my only tt lighting. Even with my less than stellar 66 year old eye sight it provides enough light to get the job done. As was mentioned a well shielded 12 volt power supply is a must. I found the cheapo adjustables to be one of my biggest sources of noise according to my emi meter. Even when on a different circuit and different 120 leg they would add line noise and cause problems with radio reception.
    ^^^ ooh, cool idea (no pun intended)!
    Could do that with the Emoticon Emotion's soulmate/cousin, the TT15S1, too... :)
  • motorstereo
    Cousins? I'm thinking they're more like twin brothers :) . They look the same to me except for the feet on the Marantz look slightly larger.
    If one does choose to do the underside lighting some sort of an opaque barrier around the bottom is a must. Mine is a home made frame for the old Pioneer pl41 acrylic cover that just happens to fit the Emotion perfectly.
  • DividedSky
    DividedSky Posts: 108
    jdjohn wrote: »
    From what I saw, there was (thankfully) never any cheesy marketing to MB/performance car people. IMO, it came across more as just a slightly funny, slightly heady nod to good engineering.
    Value discussions are so subjective, so I will just say I love the AMG. My prior tables were both vintage... Pioneer PL570 and SOTA star sapphire. I love the SOTA and still use it regularly. The AMG was a leap in imaging, transparency, backgrounds black as night, and low end performance. At AMG sticker price, the SOTA was the better value. But store demo price was (retrospectively) a no-brainer and tips the value to the AMG (for me).
    A downside is that poor recordings are completely exposed and unlikely to be played much. Clean copies of used records can sometimes be a disappointment with "played-out" A sides. These things were true on the SOTA but it's dramatic on the AMG. The flip side of this is that 45rpm audiophile releases can often blow my mind apart. That's great for listening, not great for music acquisition budget :D . The table also really needs great isolation, so that's another add on cost.
    Also noteworthy is the, ahem, nice long tonearm. That AMG 12JT tonearm is so easily adjustable in all facets from VTA to azimuth to tracking force. As someone who enjoys that "tweaking" side of analog, its a delight. The first generation of that tonearm (12J2) was similar in design but not nearly as easy to adjust (I had a loaner 12J2 for a few months).
    Frank
