Post a picture... any picture
16376386406426431073
    mhardy6647 Posts: 32,926
    NotaSuv wrote: »
    Yup.
    Settled science.
  • Clipdat wrote: »
    unnamed_1_2f661c79-84ab-4090-8cdc-f34a5d4c85a7.jpg?v=1612227991
    Nice! Tell us a little something about it.
  • maxward
    maxward Posts: 1,490
    Clipdat Posts: 12,560
    edited December 2021
    TEAforONE wrote: »
    The Arioso 300B is an integrated class A SET amplifier. The output tubes use stabilized DC current heater supply. A dedicated system separates the tube heating circuit from the stabilizer system. The entire amplifier circuit was built using the point-to-point method. The unique design and high grade components allowed us to achieve a very natural, incredibly detailed and musical sound, with well-controlled bass and a rich but not „emphasized" midrange.
    Technical Specification
    Output power: 2 x 8W
    Frequency range: 15Hz – 32KHz +/- 3dB
    Input sensitivity: 1V RMS
    Input impedance: 100KOhm
    THD: 0,3% @ 1KHz @ 1W and 2,5% @ 1KHz @ 8W
    Input selector: 3 RCA inputs
    Remote control: ON-OFF, input selector, volume, mute
    Dimensions: 410x 330 x 210mm (incl. tubes)
    Weight: 25kg
    Designed, developed & made 100% in Poland
    Box content
    Beautifully hand-crafted Tube Amp
    Electro Harmonix Gold 300B power tubes
    CV181-TII PsVane 6SN7 driver tubes
    NOS rectifier tube
    AC cord
    User Manual
    Warranty Card
    Wonder what the output impedance is and who did the OPTs for it?
    I assume it's a zero added NFB design (?).
    Also wonder what they used for the "NOS" HV rectifier -- looks like maybe a 5U4, but it's hard to tell how large it is, hidin' behind the 300Bs.
  • tonyp063
    tonyp063 Posts: 1,044
    Rectifier is a russian 5C3S. Which is indeed analogous to a 5u4.
    Output transformers (according to some digging I did) are from Leszek Ogonowski.
    Based upon published specs for the amp, possibly these. 2500 ohm.
    http://www.ogonowski.eu/transformers/single-ended/lo-se25-5/
    tonyp063 wrote: »
    Most impressive. :)
  • motorhead43026
    motorhead43026 Posts: 3,892
    Yeah, I got a robot vacuum as an early Christmas present. It spends more time trying to hump table legs like a randy turtle than vacuuming.
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
    Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
    The best way to predict the future is to invent it.
    It is imperative that we recognize that an opinion is not a fact.
    Imagine making politics your entire personality.
    audioluvr Posts: 5,420
    You must have some pretty sexy table legs! My GF just bought me a Shark with the dump station. It does a fantastic job.
  • soundfreak1
    soundfreak1 Posts: 3,374
    Clipdat wrote: »
    Ok Dad!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    treitz3 Posts: 18,230
    Ok Dad!
    You do know that he is talking about corralling the tadpoles, correct?
  • soundfreak1
    Just one of my "Dads" most repeted phrases, over and over and....
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    ^^^ @CH46E that first photograph (in particular) is fantastic!
  • TEAforONE
    TEAforONE Posts: 999
    A
  • TEAforONE
    Quick question. How come I can’t delete my post????
    Because Vanilla.
  • Clipdat wrote: »
    Because Vanilla.
    That’s what I thought. Why on earth would the ability to delete your own post be removed? Am I censored from self censoring??
    Apparently yes. You can only edit posts for an hour, but you can never delete them or edit them after the initial hour. It's pretty stupid.
    It's amazing what you are censored from on this forum nowadays. We went from the gun slingin' wild west to Oprah's rainbow filled wonderland of the woke seemingly overnight.
    It's actually better as of late though, so I'll give them that. Still, some things still just leaves one scratching their head...
  • CH46E
    CH46E Posts: 3,521
    Thanks but I did not know there was a delay for night shots. That's why it's a bit fuzzy. I moved. It's like a 2 to 3 second exposure I guess for night.
    CH46E wrote: »
    That's not a bad thing, IMO. It adds an aura of surreality to the photo, which is really what makes it for me. The reflections on the water are incredible.
  • CH46E
    CH46E Posts: 3,521
    CH46E wrote: »
    Me too. I liked the reflections. I wish I had a real camera and knew how to use it.
    Blurry pic but....1938 Dymaxion
