Legend L800 vs. SDA-SRS 1.2TL...
13
  • Mike Reeter
    Mike Reeter Posts: 4,315
    An update... Playing around with the room and speaker placement, and much of my earlier difficulties appear to be moving behind me as I begin to get acclimated to the new speakers. The one niggling little issue is that the L800 do not really generate that "wall of sound" presence the 1.2TL's had. They are far more accurate, incredibly fast and detailed, but just cant seem to elevate themselves above about 6 feet. whereas the TL's were simply huge in that regard.
    While I know nothing about the L800's (other then agonizing on whether to buy or not when they were on sale). I've only tried a couple of other speakers over the years, KEF R900 and a pair of Dynaudio Contour S3.4 LE's, while they sounded quite good, they didn't possess the scale of the SDA's.
  • Emlyn
    Emlyn Posts: 4,797
    EJMiller wrote: »
    Am I clear that you are driving your L800s with mono blocks? All the experts reviews that I have read say do not even use your balanced connections use unbalanced connections for the best results. The SDA's need the unbalanced signal for sda to function optimally. I have had my L800s for a few months and still waiting on my anthem 70 processor to balance the complete system
    I haven't come across any expert reviews saying balanced interconnects in a system present a problem for the L800s. Got a link to one of the expert reviews to share?
    There are known issues with fully differential stereo amps and the L800s but it wouldn't matter if a balanced or unbalanced cable runs from a preamp output to an amp of that design. The result would be less than desirable with either XLR or RCA cables for the SDA function on the L800s with a differential amp.
  • ptrooper
    ptrooper Posts: 501
    The amp for these should be common ground, duel monos whether they be separates or built into one unit i think from memory loose 6 db on the sda side!
    pitdogg2 Posts: 27,189
    edited November 2021
    ptrooper wrote: »
    New L800's are not tied to common ground only architecture.
    F1nut wrote:
    The way SDA is implemented in the L800 does allow for the use of non- common ground amps.
  • ptrooper
    ptrooper Posts: 501
    Sorry Pitdogg2 and F1,I was Still half a sleep here at 4:30 am...I see there has been a bit of confusion in the past with these and the word "balanced" !
    Not talking about the inputs to the amp but configuration when simplified being a + amp and - amp working together per channel. one pushing and the other pulling is where i beleive the problem starts.
  • invalid
    invalid Posts: 1,510
    Why didn't polk design the L800 to be used with the isolation transformer, just like the vintage later model SDA's?
    invalid wrote: »
    Larger market to sell them?
    Just a guess.
    VR3 Posts: 29,516
    Are you kidding? They can't even clearly distinguish left and right speaker on their website? Where the heck they going to make the Dreadnought work?? 😝😝
    ptrooper wrote: »
    @Emlyn nailed it.
    Polk wanted to use one of their upper Marantz products and found that particular one was a no go.
    I cannot remember which it was.
    mhardy6647 Posts: 35,171
    ptrooper wrote: »
    @Emlyn nailed it.
    It's in the big an early L800 thread.
    Marantz PM-10, per @F1nut
    https://forum.polkaudio.com/discussion/comment/2644399#Comment_2644399
    txcoastal1 Posts: 13,518
    Reminds me...and I'll discuss later when I do my Legend HT review
    Marantz pre/pro are Euro connects when using balanced cables...AV7706 XLR pins 2&3 are reversed
    F1nut Posts: 51,912
    EJMiller wrote: »
    I believe you are confused. You cannot use a dual differential (fully balanced) amp(s) with the L800, but there's no reason balanced cables can't be used.
    xschop Posts: 5,312
    Patiently awaiting pTrooper's comparison between the L800's and his Monoliths.
    nooshinjohn Posts: 25,968
    Today, I bypassed my Pass Labs gear and ran them from the Pioneer HT receiver in enhanced stereo mode. This allowed me to get the L900 Atmos modules involved. In this mode, they were brilliant. They equaled the TL's ability to project a soundstage, and they delivered in spades. Detail was astonishing compared to the TL's, but at the same time, they seemed to be missing that low-end growl. The best way I can describe it is that there is a lot of substance, but not texture. So polished and refined but still leaving you wanting them to take the gloves off and just get dirty.
    The L800's are above that. Feed them a string quartet, vocal heavy country/pop, or jazz, and they simply blow the doors off. Give them AC/DC, or other hard rock, and they don't really want to get into the music they are being fed. Too much information coming at them and they seem to get lost at this point.
    I only have 75 hours or so on them at this point, so that may change. At this point, the L800 are a nice speaker, but I am leaning towards the TL's...
    Clipdat Posts: 13,100
    Think of how they will sound once you actually start playing good music on them!
  • dr1978
    dr1978 Posts: 424
    Clipdat wrote: »
    That is good music......for me to p00p on!
    Pro-ject 2 Experience SB, OPPO BDP-103, Marantz SR5011, Lounge LCR MKIII, McCormack DNA-HT5, Polk LSiM705, Polk LSiM706C, Polk LSiM702, SVS SB16-Ultra
    Great review, @nooshinjohn!
    "Like a chrysalis..." :D
    I don't know if that means it's a good idea or a bad idea to listen to Jethro Tull records during break-in... B)
  • verb
    verb Posts: 10,176
    Wow John I just read this thread!
    I'm impressed as to the extent of detail you shared during your journey! Letting it all out there, as you did, creates a sense of vulnerability ripe for criticism.
    Please post some pics of your latest setup. Mine are essentially in the same spot my TL's were.
    Admittedly, I have less than 20 hours on mine, so I have some work to do!
    VR3 Posts: 29,516
    I'm glad you stuck in there and have them a fair shot!
    VR3 wrote: »
    Juggling a family while trying to figure things out is the only reason they are still here. By that, I mean I just did not have time to pack them off, but I did run them as background music while I went about caring for the kids. Towards the end of the week, I sat down finally for a sandwich and give them a final listen before pulling them out. That is when I started to hear their potential.
    I am going to make some more changes, like upgrading my DAC, AVR, and some other moves. I think there is far more they are capable of than what the current rig can give them. Just like their older siblings, these L800’s will really shine when the gear feeding them is of exceptional quality.
    Let me know when you get the crossover mods mapped out! B)
    VR3 Posts: 29,516
    I kind of have an idea what it is based off the L200.
    The sda and stereo array looks like the L200 crossover x2 based on that Pic plus a low pass circuit for the bass.
    None the less a **** load of parts... You would absolutely have to go external
    It looks like there is much room for upgrades over stock. Do you have an idea as to cost?
    VR3 Posts: 29,516
    Using csa, mox, Jantzen inductors.. You would be looking at atleast 3 to 4k in parts, assuming you cna keep it internal... Which is doubtful
    Using cmr and path audio... Maybe closer to 8k when you factor in the enclosure custom umbilical etc etc
    If you were to focus on the weakest link in this, where would us start, or is it best to just do it all at once.
    VR3 Posts: 29,516
    Biggest weak links would be the iron core inductors in the main path of the midrange... I would guess there are 4 total counting the sda circuit
    Next would be the sand cast resistors
    Following the caps
    So foil inductors would be the way to go here then?
    VR3 wrote: »
    Following the caps
    That leaves the solder & the printed circuit board. ;)
