Polk Magnifi Mini
Hi guys
So I bought this unit today.. Worked for three hours and the sub stopped working.. Have to revert back to Bose unfortunately.
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Hello,
    I'll ask a friend at Polk to send you an email, unfortunately it won't be until Monday.
  • JamesV
    JamesV Posts: 4
    Thanks Kenneth.. Just was not a good experience today. I am from South Africa and the Polk call Centre in the US only works from Monday to Friday.
  • [Deleted User]
    No problem, I'm sorry you're having a problem, but hang in there Polk will respond and help.
  • JamesV
    JamesV Posts: 4
    Thank you, is this a common issue with this set? Can't seem to get the sub working at all.
  • captaintor
    How do you sync the Magnifi Mini sub-woofer to the sound bar?
  • gmcman
    gmcman Posts: 1,887
    I don't have the mini, but I believe the Magnify X states...with the sub plugged in but turned off, press the sync button on the soundbar until it starts blinking, then without releasing the sync button, turn on the sub without releasing the sync button and hold the sync button for another 6 seconds then release.
  • Egor
    Egor Posts: 5
    Hello
    hi my subwoofer doesn’t work, sync is constantly blinking, and no matter what I do, it doesn’t help, (Привет у меня не работает сабвуфер , моргает синхронизация, нет связи что бы я ни делал )
  • SeleniumFalcon
    Hello,
    In what country are you living?
  • Egor
    Egor Posts: 5
    Russia
  • SeleniumFalcon
    Let me ask a friend at Polk for a recommendation.
  • Egor
    Egor Posts: 5
    as I understood, this is a very common problem
  • Egor
    Egor Posts: 5
    you need a guide on youtube so that everyone understandably
  • Tour2ma
    Tour2ma Posts: 10,177
    Egor wrote: »
    Hello
    Gotta love it when Crylic appears in posts.. ;)
    More later,
    Tour...
    Vox Copuli
  • SeleniumFalcon
    I believe someone from Polk Europe will contact you via email.
  • Egor
    Egor Posts: 5
    Hello, RU, Moscow
  • Vset077
    JamesV wrote: »
    HI there
    Did you get any help? I'm from south africa too and I had a same problem with my polk subwoofer that doesn't connect to my soundbar
  • Vset077
    I tried everything now and I'm frustrated🤦🏾‍♂️
  • Vset077
    Egor wrote: »
    Hello
    Did you get any help buddy?
  • Vset077
    I'm going through the same thing here
  • jjimenez
    jjimenez Posts: 2
    edited September 2025
    Someone found a solution for the "No Sinc" between the Sub Woofer and the Bar Sound? I can't believe nobody from Polk give us a good response.
  • SeleniumFalcon
    Hello,
    Welcome to the Polk forum. I'm sorry you're having a problem. Can you describe what you're experiencing and what you've tried. Also, where do you live?
