Polk Magnifi Mini
JamesV
Hi guys
So I bought this unit today.. Worked for three hours and the sub stopped working.. Have to revert back to Bose unfortunately.
Hello,
I'll ask a friend at Polk to send you an email, unfortunately it won't be until Monday. -
Thanks Kenneth.. Just was not a good experience today. I am from South Africa and the Polk call Centre in the US only works from Monday to Friday.
No problem, I'm sorry you're having a problem, but hang in there Polk will respond and help.
Thank you, is this a common issue with this set? Can't seem to get the sub working at all.
How do you sync the Magnifi Mini sub-woofer to the sound bar?
I don't have the mini, but I believe the Magnify X states...with the sub plugged in but turned off, press the sync button on the soundbar until it starts blinking, then without releasing the sync button, turn on the sub without releasing the sync button and hold the sync button for another 6 seconds then release.
Hello
hi my subwoofer doesn’t work, sync is constantly blinking, and no matter what I do, it doesn’t help, (Привет у меня не работает сабвуфер , моргает синхронизация, нет связи что бы я ни делал ) -
Hello,
In what country are you living? -
Russia
Let me ask a friend at Polk for a recommendation.
as I understood, this is a very common problem
you need a guide on youtube so that everyone understandably
Hello
Gotta love it when Crylic appears in posts..More later,
Tour...
Vox Copuli
I believe someone from Polk Europe will contact you via email.
SeleniumFalcon wrote: »I believe someone from Polk Europe will contact you via email.
HI there
Did you get any help? I'm from south africa too and I had a same problem with my polk subwoofer that doesn't connect to my soundbar -
I tried everything now and I'm frustrated🤦🏾♂️
Hello
Did you get any help buddy? -
I'm going through the same thing here
