Denon AVR-X1600H with RTi-A7's?
So recently I picked up a beautiful pair of A7’s and a CSi-A4 for a buddy:
https://forum.polkaudio.com/discussion/194109/this-is-nuts
Now he wants a new AVR. I’ve been looking at this one from Denon:
https://www.denon.com/en-us/product/av-receivers/avr-x1600h
Looks like it’d be around 70wpc in stereo... The system isn’t in a dedicated theater space or anything, just a living room, not a critical or high end rig…. Any thoughts about this pairing? Are there better, modern options out there? He doesn’t want to spend a ton, wants “lots of HDMI”. Surround/Atmos isn’t important to him. He’ll only run it as 3.1.
Any opinions or suggestions are appreciated!
TIA
-j
Current Collection: Monitor 4a (Peerless), Monitor 5B (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), SDA CRS+ (194’s), SDA SRS 2.3TL, R100's, R200’s, R300 🤩
Pairs that have passed through: Monitor 4b (Peerless), Monitor 5a (Peerless), Monitor 5b (SL1000), Monitor 5b (SL2000) (3x pair), Monitor 7b (Peerless), Modified Monitor 7c’s (194’s), Monitor 10a (Peerless), Monitor 10b (5x pair), RTA8, RTA8TL, RTA 11T, RTA12c (194's), SDA CRS, SDA 2 (2x pair), SDA 2a, SDA 2b, SDA 1b, SDA 1c, SDA SRS 2 (2x pair), SDA SRS 3.1TL (198’s) (2x pair)...and more to come, it’s a sickness.
  • mantis
    mantis Posts: 17,056
    I think it will work just fine. Run them small 80hz and rely on the subwoofer for the heavy lifting and I think you'll have a Nice affordable system.
    Dan
  • gp4jesus
    gp4jesus Posts: 1,969
    edited September 2021
    Check rear panel for LCR pre-outs. “No pre-outs” is a deal breaker.
    My Denon AVR rated @ 100 in stereo struggles to drive my more sensitive Kefs. I wouldn’t expect they’ll drive those more power hungry A7s any better WITH a sub handling the bottom.
    Approximate sq footage?
    Make and model sub?
    My $0.02 Tony
    Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
  • stevep
    stevep Posts: 328
    gp4jesus wrote: »
    Check rear panel for LCR pre-outs. “No pre-outs” is a deal breaker. Tony
    Typically with Denon, not until the AVR-X3X00H level. So they would be looking at a AVR-X3600H or X3700H model.
  • rooftop59
    rooftop59 Posts: 7,978
    JayMX wrote: »
    TIA
    -j
    This setup will be serious nails on a chalk board toothpick in your ears type of thing. Definitely need a warmer and more powerful AVR…I would encourage him to look at used NAD or Marantz or Cambridge. Or at the very least a denon with preouts to add a warmer amp down the road…
    Game Room 5.1.4:
    Bedroom 2.1
  • JayMX
    JayMX Posts: 435
    rooftop59 wrote: »
    Ten four. I was a little concerned about the paring. I will keep shopping for him. Thanks!
  • JayMX
    JayMX Posts: 435
    Picked this up for my friend today. $200. Should do the trick. Has pre outs if he wants to go bigger…. Marantz SR-5006 in mint condition. 🤘🏻
  • rooftop59
    JayMX wrote: »
    That’ll do it! Nice find! As long as atmos, 4K, or more than 7.1 isn't a need, then this will be just fine.
    Game Room 5.1.4:
    Bedroom 2.1
