Vintage Monitor and SDA Speaker Deals
1214215217219220261
  • verb
    verb Posts: 10,176
    Thanks fellas! I’ve got an appointment this Saturday to review them!
  • JayCee
    JayCee Posts: 1,509
    edited July 2021
    verb wrote: »
    Even if they're not tl's it's not difficult to tl the XO's. On my pair, the owner I purchased them from @Neskahi had similar questions re. 1.2 vs tl's when he purchased them. As mentioned above, the transitional nature of Polk and using previous series parts contributed to the speculation. Conclusion was they were possibly tl'd at a later date. Just checked the s/n on my right speaker and it's 6240...less than 100 off from what you're looking at. Drivers in mine are from 1989.
    I paid $1500 in 2010ish, considered it a fair price, still own them and have zero regrets. Throw all the CP upgrades at them and you, my friend, should be a happy camper. Good luck.
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • michaeljhsda2
    michaeljhsda2 Posts: 2,207
    They're TL's. The label on the back is leftover stock that Polk notoriously uses so you can't rely on that at all. To be absolutely certain, look at the tweeter wire harness Molex connector where it attaches to the crossover board and note that all 4 of the white wires are on the + and the colored wires are on the - It's wired in reverse polarity and it's supposed to be that way and if they're not, then the person that did the conversion didn't finish the job correctly.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • verb
    verb Posts: 10,176
    As always, I knew I could get the info here from the experts! These babies will replace my current 1st gen SRS's. The only thing I did to them was swap out the tweeters.
  • michaeljhsda2
    Hope you get them Verb. My 1.2 TL's are great, however, I'm tempted to get those 2.3TL's to add to the collection.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • verb
    verb Posts: 10,176
    Thank you sir! The guy said there was some wiggle room on the 2.3TL’s so I’d say go for it!
  • xsmi
    xsmi Posts: 1,812
    verb wrote: »
    Let me know what you decide to do either way.
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-59L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • xsmi
    xsmi Posts: 1,812
    Are there TL’s at Verb’s house?
  • Mike Reeter
    Mike Reeter Posts: 4,315
    verb wrote: »
    Yes!
    More to come, but I verified the SL-3000 tweeters, and un-molested wiring harness by pulling a tweeter out. Thanks for the tip Ivan! @pitdogg2
    Date code is January 1989 on the tweeter, so an early build.
    Did the pressure check by pushing in the passive radiator and they seem fine.
    Got my buddies to help lug these downstairs (OMG I had forgotten how heavy they are!)
    Cabinets and grilles are in very very nice shape, you could call it near Verb minty! Except of course the coating on the LH XO mounting plate. Looks like the previous owner used a solvent or something on it.
    The IC cable is original, and in excellent condition also.
    And, best of all, got the price down to 13 hundie!
    Have not hooked them up yet, as I'm exhausted, but I'll be doing some A/B with the other SRS's, before I let those go up for sale!
    Great catch! At a GREAT price!!
  • verb
    verb Posts: 10,176
    Maiden voyage!
    audioluvr Posts: 6,050
    Any discernable difference between the old ones?
  • verb
    verb Posts: 10,176
    Loving the SL3000 tweeters! The RD0194’s still seemed a bit spikey at times. These are smooth!
    pitdogg2 Posts: 27,741
    verb wrote: »
    Let me tell you, the RD-0198's are easily 5x better than those SL3000's.
    I couldn't believe the difference in my 2.3tl's.
  • verb
    verb Posts: 10,176
    Sounds like a plan! Easy swap too. Thanks Ivan for your guidance on these babies. I’m a happy camper for sure. Lots of upgrade paths, plus now I can finally use my dreadnaught!
  • invalid
    invalid Posts: 1,555
    I don't know what the rd0194's sound like, but the rd0198's in my 2A's sound smooth without lacking any detail.
  • scubalab
    scubalab Posts: 3,105
    Apologies if these have been posted before. Not sure if it's a deal or not, but not much coin...
    https://maine.craigslist.org/ele/d/topsham-polk-srs-sda-23-speakers/7348979902.html
  • stereo55
    stereo55 Posts: 418
    edited July 2021
    SDA-2B's ~ Pair SDA-CRS's ~ ,*** Main listening: Maggies MG1 ~ Polk SDA 2B's ~ Monitor 10's , 3-pairs (2 pairs moded into SDA's w/SDA-2B/CRS cross-overs) , * DCM TF600's * Mission M71/M72 *** Main brdrm FRT: RTiA-5's /Presence RTi-4 / LSI-704 Cntr / Rear FXI3's ~~~ Assorted Main listening rm : , 2- Heathkit W-5M /tube mono blocks (Parasound P/HP-850)* * 2- Altec Lansing 1590b's/mono blocks (Yamaha C-45) * CM Labs 35D * Dynaco ST-70 ~ Occasionally ~* Yamaha CR-820/A-760 ,* Sansui AU-317/AU-217 * Carver 900 rec *2-Dynaco ST 120* 1 Hafler DH-220* Marantz 1040 ... more
  • aprazer402
    aprazer402 Posts: 3,456
    scubalab wrote: »
    These are priced very nice. Would be a good entry into full sounding SDA for someone. The small chips
    in the veneer could be repaired, or even touched up and they would hardly be noticed. The 2.3's have pin/blade interface cable connections and can use the Dreadnought isolation transformer.
  • VSAT88
    VSAT88 Posts: 1,379
  • engie490
    engie490 Posts: 447
    Polk SDA 3.1 TL Speakers - $535 near San Bernadino, CA
    KEF Xq5s / Velodyne DD12 / Apollon Purifi 1ET6525SA / SST Thoebe II / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
  • VSAT88
    VSAT88 Posts: 1,379
    I would almost kill to live close by them right now.
  • stereo55
    stereo55 Posts: 418
    Saw those 3.1's on other site and those SDA 3.1 TL's are in reach distance wise , but the wallet says different atm .BUT ....may sell some stocks to grab'em ......
  • engie490
    engie490 Posts: 447
  • VSAT88
    VSAT88 Posts: 1,379
  • alexanikin
    alexanikin Posts: 106
    edited August 2021
    Hi guys. I have three pairs of Polk Audio speakers and thinking to sell two of them (Monitor 7c and RTA 12c). Looking for an advice on how to sell, so they will end up in good hands, and for fair market price.
    Is it the right thread to ask?
    Try Craigslist. Do a search on eBay "completed items" for what they are selling for currently.
  • alexanikin
    audioluvr wrote: »
    Yeah, it’s obvious. But it doesn’t help much, cuz basically eBay prices are exceed common sense and craigslist listings expire in a week. So it doesn’t much with both problems..
    edited August 2021
    alexanikin wrote: »
    audioluvr wrote: »
    But the completed eBay sales DO give some indication of market prices … No? In reality they are only worth what someone feels like paying.
    The RTA12c is a very good speaker and I've tried to buy a set here near me for years. The seller does own an audio store and feels they are worth 600.00 yet the top hats are in terrible shape and there is sun fading on one side of one of the speakers. I offered 250 and he flat out laughed. I then told him I would need to recap the XO and that cost is going to be substantial. He then recapped them with TERRIBLE cheap electrolytic caps and then preceded to tell me how cheaply he was able to do it. Then he wanted 750.00 since they were "recapped", It was my turn to laugh and walk out...
    The best thing for you to do is settle on a price YOU think is far and go from there. The problem is not many want speakers of this caliber anymore, big floor standers do not have the WAF going for them.
    You will need 100 post to list them here FWIW so keep that in mind.
