Vintage Monitor and SDA Speaker Deals
1214215217219220235
  • VSAT88
    VSAT88 Posts: 1,184
    edited July 2021
  • Mike Reeter
    Mike Reeter Posts: 4,300
    edited July 2021
    pitdogg2 Posts: 22,390
    I'd pay 1500.00 for those 1.2tl's and yes they are TL's as that have the SL3000 tweeters.
  • Mike Reeter
    I'm sure you're correct, I was going by the I.D on the back label, I thought TL's were stated if so.
    https://img.usaudiomart.com/uploads/large/3361346-f75ada0a-polk-sda-srs-12-tl-speakers.jpglet0gy09325r.png
    SDA SRS 3.1TL's/SDA CRS+4.1TL's and some other stuff
  • tratliff
    tratliff Posts: 1,494
    edited July 2021
    Careful dealing with this guy. He had these on FB marketplace and I agreed to purchase them for $500 + shipping. The next day he raised them to $1000 without telling me. When I asked what was up he said he had so much interest that he decided to raise the price.
    He now has them for $700 but has commented to me that he would take $500. I told him No Thanks.
    Update:
    I just went to FB to get the link and they are now priced at $500.
    https://www.facebook.com/groups/904208026352351/posts/3862243100548814
    Legacy Focus SE's, 2 REL Carbon Limited, Norma Revo IPA-140, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Parasound Halo JC3, Denon DP-59l w/Denon DL-301MKII, AudioQuest Thunderbird Speaker and Interconnect Cables, AudioQuest Niagara 5000 w/Hurricane and Thunder Power Cables
    Vintage
    Pioneer SA-9800, Pioneer TX-9800, Pioneer PL-630 w/Ortofon 2m Bronze, PSB Imagine T2's
  • VSAT88
    VSAT88 Posts: 1,184
    Flip flop a flippity flop and you don't stop to the bang bang boogity beat. Some people are just plain ****'s. Agreed to do something... Just do it right ?
    you very well could be correct and they may have just put the tweeters in them. We all know Polk was very good at using up older stuff (labels) before using the newer stuff. easy enough to tell pull tweeter and look at the connection. I'm also going by the binding post they look correct for the 1.2tl
  • Mike Reeter
    Either way, they're not a bad buy...
  • verb
    verb Posts: 10,176
    edited July 2021
    Thanks for the information guys! My email was blowing up on these 2 pairs. I'm gonna take a look on Saturday! He wasn't sure if the 1.2's were TL's or not, as it was not labeled as such.
    Ivan - If I pull one of the tweeters out, what should I look for? @pitdogg2
    audioluvr Posts: 4,795
    la2vegas wrote: »
    Those look like they are in walnut! Nice!
    Belles 350A Reference modded with Mundorf Supreme caps
    There is about a 5% genetic difference between apes and men …but that difference is the difference between throwing your own poo when you are annoyed …and Einstein, Shakespeare and Miss January.
    by Dr. Sardonicus
    Probably spot on there Ivan. Low SN means they had some extra labels from the non TL models or something.
    by Dr. Sardonicus
    verb wrote: »
    The factory quick connects should be two different sizes and crimped the same. If someone came along and just switched out the tweeters one quick connect would not be the same factory crimp and possibly look much different.
    I'm fairly certain those are factory 1.2tls as the red binding post seem to be on the correct side.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,095
    No doubt that they are 1.2TL's like pitdogg said because they have the SL3000 tweeters. If you decide to pull one of the tweeters, the negative white wire post on the tweeter is larger than the positive post.
    SDA SRS 1.2TL's
    SDA 1C's w/Clarity Cap ESA; PA, Mills, RD0194-1's
    SDA 2B TL's w/RD0198-1's
    Yaqin MC-30L integrated tube amp
  • verb
    verb Posts: 10,176
    Thanks fellas! I’ve got an appointment this Saturday to review them!
  • JayCee
    JayCee Posts: 1,433
    edited July 2021
    verb wrote: »
    Even if they're not tl's it's not difficult to tl the XO's. On my pair, the owner I purchased them from @Neskahi had similar questions re. 1.2 vs tl's when he purchased them. As mentioned above, the transitional nature of Polk and using previous series parts contributed to the speculation. Conclusion was they were possibly tl'd at a later date. Just checked the s/n on my right speaker and it's 6240...less than 100 off from what you're looking at. Drivers in mine are from 1989.
    I paid $1500 in 2010ish, considered it a fair price, still own them and have zero regrets. Throw all the CP upgrades at them and you, my friend, should be a happy camper. Good luck.
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streamer: Roon ROCK on wifi'd NUC & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • michaeljhsda2
    They're TL's. The label on the back is leftover stock that Polk notoriously uses so you can't rely on that at all. To be absolutely certain, look at the tweeter wire harness Molex connector where it attaches to the crossover board and note that all 4 of the white wires are on the + and the colored wires are on the - It's wired in reverse polarity and it's supposed to be that way and if they're not, then the person that did the conversion didn't finish the job correctly.
    SDA SRS 1.2TL's
  • verb
    verb Posts: 10,176
    As always, I knew I could get the info here from the experts! These babies will replace my current 1st gen SRS's. The only thing I did to them was swap out the tweeters.
  • michaeljhsda2
    Hope you get them Verb. My 1.2 TL's are great, however, I'm tempted to get those 2.3TL's to add to the collection.
    SDA SRS 1.2TL's
  • verb
    verb Posts: 10,176
    Thank you sir! The guy said there was some wiggle room on the 2.3TL’s so I’d say go for it!
  • xsmi
    xsmi Posts: 1,751
    verb wrote: »
    Let me know what you decide to do either way.
    2-channel
    Belles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Schiit Mani Phono Pre, Moon LP 3 Phono Pre, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • xsmi
    xsmi Posts: 1,751
    Are there TL’s at Verb’s house?
    2-channel
  • Mike Reeter
    verb wrote: »
    Yes!
    More to come, but I verified the SL-3000 tweeters, and un-molested wiring harness by pulling a tweeter out. Thanks for the tip Ivan! @pitdogg2
    Date code is January 1989 on the tweeter, so an early build.
    Did the pressure check by pushing in the passive radiator and they seem fine.
    Got my buddies to help lug these downstairs (OMG I had forgotten how heavy they are!)
    Cabinets and grilles are in very very nice shape, you could call it near Verb minty! Except of course the coating on the LH XO mounting plate. Looks like the previous owner used a solvent or something on it.
    The IC cable is original, and in excellent condition also.
    And, best of all, got the price down to 13 hundie!
    Have not hooked them up yet, as I'm exhausted, but I'll be doing some A/B with the other SRS's, before I let those go up for sale!
    Great catch! At a GREAT price!!
    Any discernable difference between the old ones?
    by Dr. Sardonicus
  • verb
    verb Posts: 10,176
    Loving the SL3000 tweeters! The RD0194’s still seemed a bit spikey at times. These are smooth!
    verb wrote: »
    Let me tell you, the RD-0198's are easily 5x better than those SL3000's.
    I couldn't believe the difference in my 2.3tl's.
