L800 - Single Ended Amp
tjcinnamon
tjcinnamon Posts: 100
Hi All,
I have a down payment on some L800’s. I’m looking for amps. I know the Anthem MCA will work but the Monoprice Monolith is what I have my eye on. That’s a single ended amp, correct?
I heard in the reviews that a single ended amp is what these speakers like.
    F1nut Posts: 52,277
    Any amp or amps that are not fully differential balanced are ok to use with the L800.
    As for your Monolith question, that's a budget HOME THEATER amp. Surely, the L800 deserves better. That said, it has the option to use unbalanced RCA connections, so it should work, but it would be wise to ask them about the topology.
    mhardy6647 Posts: 35,501
    by "single ended" I assume the OP means "unbalanced" I/O?
    The thought of a single-ended power amplifier (as opposed to push-pull or "class D", i.e., PWM) with enough oompf to drive an L800 is... rather terrifying, actually! :o
  • invalid
    invalid Posts: 1,555
    https://www.nataudio.com/images/logo.png
    These single ended triode monoblocks might do it.
    pitdogg2 Posts: 27,750
    That is nothing but a logo picture.
  • BlueFox
    BlueFox Posts: 15,250
    Look at Pass amps. I have the X600.5, and love them. They have been upgraded to the X600.8.
    https://www.passlabs.com/products/x600-8/
  • tjcinnamon
    It's based off an ATI. It's $1300 for a 5 channel. It's well reviewed by AudioScienceReview and Audioholics. It's between that and an Anthem MCA525
    I'm confused on what kind of amp I can use. Apparently, hypex and purifi based amps can't be. So is basically, these speakers don't work well with balanced connectors? Or is it different? How can I tell an amp is fully differential?
  • tjcinnamon
    BlueFox wrote: »
    That looks great.. but my budget is under $3500 :)
  • BlueFox
    Been there. You’ll get there. :)
  • tjcinnamon
    Or is the term common grounded? the L800's don't play well with common grounded amps?
    invalid wrote: »
    Oh, yes -- it's achievable. :)
    But it's still terrifying, whether the output devices are vacuum tube or soiled state.
    Remember that the output devices will be at full power dissipation all of the time in a single-ended amplfier (Class A operation by definition). :#
    The plate voltage on that bad boy pictured above is lethal, too. :)
  • Emlyn
    Emlyn Posts: 4,888
    tjcinnamon wrote: »
    Look at the marketing language or contact the company. Usually if a company designs such an amp it'll say something like "fully balanced from input to output" for a differential design because such amps are claimed to be less subject to interference in the circuitry. Quite often such an amp will have two power supplies inside the chassis with one for each channel. They may have both balanced and single ended (RCA) connectors on them. I have a Sonic Frontiers Power 2 amp which is a differential design and not common ground. It has both types of connectors but the better set is the XLR set.
    F1nut Posts: 52,277
    tjcinnamon wrote: »
    Good reasons to avoid it.
  • Emlyn
    Emlyn Posts: 4,888
    I'd recommend spending the money to get a Parasound A21+ and be set for two channel amplification for the next twenty years.
  • Emlyn
    Emlyn Posts: 4,888
    The JC5 is an excellent amp. Nice price on that one. Better than paying sticker price!
    Clipdat Posts: 13,101
    The JC5 has excellent bass control of the woofers! It's seriously so good.
  • tratliff
    tratliff Posts: 1,871
    I just like looking at https://tmraudio.com/fresh-arrivals/ every day. It's OK if I look, as long as I don't touch!
    edited May 2021
    Clipdat wrote: »
    Nope, nope not gonna.....
    Even if I had a 10' pole.
    I want one of those JC5's!!!
    One day.
  • TopperDude
    TopperDude Posts: 166
    how about the amp selection from Sound United's own stable like Marantz and Denon?
    The higher end Marantz use hypex so may not be best match but i believe the higher Denon's should be good? anyone tried em with PMA-2500NE or the PMA-A110? hows the matching?
  • tjcinnamon
    Thanks for the suggestions all! I really like that JC5 but it’s out of my price range. I’m thinking the Anthem 325 is the best bet given that I need something for a center channel too.
    The only thing that gives me pause is this quote from their website: “8 bipolar output devices per channel for less stress on each device”
    https://www.anthemav.com/products-archived/series=mca-series-gen2/model=mca-325/page=overview
    I doubt it means fully balanced but I want to make sure. What does this marketing fluff mean as it relates to the fully differential setup.
  • tjcinnamon
    Emlyn wrote: »
    That one looks pretty nice too! If I could find one used.
    I found a really banged up Anthem P2 but it won’t fit in my cabinet because of those rack mount brackets
    audioluvr Posts: 6,051
    tjcinnamon wrote: »
    Nothing a hack saw won't fix
    F1nut Posts: 52,277
    TopperDude wrote: »
    The Marantz PM-10 is a definite no-go, but the rest of their gear is ok to use with the L800.
  • WLDock
    WLDock Posts: 3,073
    edited May 2021
    tjcinnamon wrote: »
    Don't sleep on the 3-channel Parasound Halo A31. The original retailed for $3000, the current version $3495. https://parasound.com/a31.php
    Retail price examples
    $3295 new, Dealer - https://www.audiothesis.com/product-page/parasound-halo-a31-three-channel-amplifier
    $3095.99 new, Dealer - https://www.ebay.com/itm/174701692706?chn=ps&mkevt=1&mkcid=28
    $2999 new, Dealer - https://new-age-electronics.com/halo-by-parasound-a31.html
    $2100 + $195 s&h used, Reseller - https://reverb.com/item/40465113-parasound-a31
    The specs are pretty much awesome. I have to repost these!
    • 250 watts RMS x 3, 20 Hz - 20 kHz, 8 Ω, all channels driven
    • 400 watts RMS x 3, 20 Hz - 20 kHz, 4 Ω, all channels driven
    • Current capacity: 60 amperes peak per channel
    • Complementary MOSFET driver stage and JFET input stage
    • 24 beta-matched 15 amp, 60 MHz bipolar output transistors
    • 1.5 kVA encapsulated toroid power transformer with independent secondary windings for each channel
    • 98,400 µF power supply filter capacitance
    • Power bandwidth: 5 Hz - 100 kHz, +0/-3 dB at 1 watt
    • Total harmonic distortion:< 0.2 % at full power
    • IM distortion: balanced 16 V rms < 0.04 %
    • Slew rate: > 130 V/µsecond
    • Dynamic headroom: > 1.5 dB
    • Interchannel crosstalk: > 78 dB at 1 kHz; > 63 dB at 20 kHz
    • Input sensitivity: 1 V for 28.28 V (THX Reference)
    • Input impedance: 47 k Ω unbalanced; 94 k Ω balanced
    • S/N ratio: 112 dB, input shorted, IHF A-weighted
    • Damping factor:> 1100 at 20 Hz
    • Adjustable gain for up to +6db over THX Reference level
    • Unbalanced RCA and balanced XLR inputs
    • Circuitry designed by legendary John Curl
    • High bias class A/AB operation
    • Direct coupled (no capacitors or inductors in signal path)
    • DC Servo and relay protection circuits
    • AC present, channel status, high temperature indicators
    • Heavy-duty 24k gold-plated 5-way speaker terminals
    • THX Ultra2 certified
    • Auto turn-on by 12v trigger or audio signal
    • Dimensions: 17-1/2" w x 7-5/8" h x 20" d, 7" h without feet
    • Net weight: 65 lb. Shipping weight: 79 lb.
    Reviews
    https://hometheaterhifi.com/reviews/amplifier/power-amplifier/parasound-halo-a-31-three-channel-power-amplifier/
    https://hometheaterreview.com/parasound-a31-three-channel-power-amplifier/
    https://www.soundstageaccess.com/index.php/equipment-reviews/629-parasound-halo-a-31-three-channel-power-amplifier
    Unboxing
    https://www.youtube.com/watch?v=GcDOxSLpgZE
    What to look for in a Amplifier
    https://www.youtube.com/watch?v=Qi7coPBLvSk
    BEAST!
    https://forums.audioholics.com/forums/threads/is-this-enough-ventilation-space-for-a-parasound-a31.111914/
    Post edited by WLDock on
    5.2 A/V Setup | OLED TV - Sony Bravia XR A80J 77" | Source - Fire TV 4K Max, Wiim Pro | AVR - Anthem MRX 520 | Integrated - Musical Fidelity A5 | Speakers: Main - Boston Acoustics VS 336 | Center - Boston Acoustics VS 325c | Rear - Boston Acoustics VR-MX | Sub 1 - Boston Acoustics VPS 210 | Sub 2 - HSU VTF-2 mk3
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,355
    I asked Polk's Scott Orth for recommendations and after he consulted with the electronics engineers he replied:
    "In general, the requirements for the mating amp/receiver are fairly simple:
    1. Not balanced/bridged output. SDA requires this to function at it’s best. A balanced/bridged amp should play, but the dimensional arrays will only get half of the signal they need.
    2. Should be able to drive a 4 ohm load. This is most receivers/amps.
    The speakers will benefit from higher power and higher quality amplification, just like any other speaker. I would recommend at least 50W and typically no more than about 300W. Of course, the user should exercise the usual caution: if things are distorting, turn it down, etc. You can use higher power, but be careful not to overdrive the speaker. Low output impedance/high damping factor is always a plus in my book.
    From our stable of brands, there are several amps and receivers one could use to drive the L800:
    Integrated amps:
    Marantz PM-KIRuby (200W into 4Ω)
    Marantz PM12SE (200W into 4Ω)
    Denon PMA A110 (160W into 4Ω)
    Marantz Model 30 (200W+200W into 4Ω)
    Marantz PM8006 (100W into 4Ω)
    A/V receivers/separates:
    Marantz MM8077 (180W into 6Ω)
    Marantz MM7025 (170W into 6Ω)
    Marantz 8000 and 7000 series
    Classe Delta Series
    There are certainly plenty of amps from other manufacturers that will drive the L800 as has been pointed out in reviews."
    I hope this is helpful information.
  • tjcinnamon
    Thank you all for the resposnes. I'm going to steer clear of the Marantz and Denon. Their support was great but I had bad luck with a Marantz AVR.
    I have a support ticket in to Anthem to validate that the P2 and MCA 325 are not Fully-Differential-Output amps. Also, I asked if the P2 rack brackets can be removed. This P2 already looked like a hacksaw was taken to it! It's in rough shape...
  • TopperDude
    Integrated amps:
    Classe Delta Series
    this is great! thanks for sharing.
  • TopperDude
    TopperDude wrote: »
    I thought it applied to all the hypex-based amps like the KI Ruby and Model 30 but based on the other post of what Scott Orth mentioned, both of them should be fine.
