SRS-1.2tl
westmassguy
Build consisted of @gimpod boards, new Mate-N-Lock connectors, hand matched Clarity PX Capacitors, hand tuning existing inductors, new mounts, and new hand tuned SuperQ Sub-Bass Inductors.
Home Theater/2 Channel:
Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
Interconnect: Furez 10/2 with SpeakONs
ICs: Custom Furez by Douglas Connections
Den:
Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
Carver CT-3 Pre, Carver C-500
dhsspeakerservice.com/
Den:
Nice
When you hand tune is this to measurement (spec), by ear and approximately how far off are they? Curious minds....how many of Tony's boards remain?
Nice work, as usual!!➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streamer: Roon ROCK on wifi'd NUC & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
They turned out beautifully, Dave.....thanks! Currently warming them up inside of these guys and initial impressions are super favorable. I'll post some detailed impressions once they've burned in good....again, thanks for the great work and service!
SDA SRS 1.2tl's
Adcom GFA-585's -
Den:
dhsspeakerservice.com/ -
I use an Inductance Meter, and always tune them to spec. If they are slightly low, less than 2% or so, I'll match the opposite channel. I'd rather they be slightly low, but matched within les than 1%, than mismatched.
Tony's boards are no more. All gone.Home Theater/2 Channel:
Den:
Nice, Dave, clean.
What did you use for the mounts, and what are those two white strips?
Is that a threaded insert in the center?I disabled signatures. -
Nice, Dave, clean.
Scott, the mounts are made from 1/2" MDF, same size as the original circuit boards. There's a 1/4-20 Hurricane nut in the center, and I send along new, shorter cap screws. The white strips are foam tape. Once you tighten the cap screws, the foam tape compresses and keeps the crossover from spinning or vibrating.Home Theater/2 Channel:
Den:
Looks great, and a nicely thought out design extra.I disabled signatures.
Damn I should have bought another set before they vanished.
westmassguy wrote: »Build consisted of @gimpod boards, new Mate-N-Lock connectors, hand matched Clarity PX Capacitors, hand tuning existing inductors, new mounts, and new hand tuned SuperQ Sub-Bass Inductors.
I like how the resistors are on the back of the board to keep the heat away from those pretty, new caps! Nicely done Dave!Gustard X26 Pro DAC
Belles 350A Reference modded with Mundorf Supreme caps
There is about a 5% genetic difference between apes and men …but that difference is the difference between throwing your own poo when you are annoyed …and Einstein, Shakespeare and Miss January.
by Dr. Sardonicus -
Scared the crap out of me. I saw the 2 resisters on R5 in series and thought that's not what I did back in 2011. Pulled up a pic and I have much different values. Jumped on Gimpod's placement site and verified. I have 22 and 24.9, parallel, but he gives the series example, as you have. First thought...oh $hit...they've been wrong for 10 years?
I'm no electronics tech but am capable of soldering XO's and following directions, so quick Google search for resister calculator, 2 in parallel, and see my values, combined, are very much within tolerance of the 11.5 ohm spec. Whew. Pucker factor back to zero.
My board:
Quite sure I did the research back then and have done 4 sets of additional XO's but didn't need to double up, that I recall. Obviously, I have different values and probably worked through this w/Jeff @ Sonicraft when I ordered the parts. All this to say....I don't recall the discussion. Are there pros/cons to series vs. parallel or do you have a preference?➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streamer: Roon ROCK on wifi'd NUC & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
Thank youHome Theater/2 Channel:
Den:
My board:
Both parallel and series are acceptable. I have no preference, all depends on what's available from my vendors.Home Theater/2 Channel:
Den:
The same power should be dissipated by each resistor, regardless of parallel or series. We know that power dissipation is in the form of heat which increases thermal noise but should be the same in each case.George / NJ
Crown D150 amp
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Great job Dave!2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Den:
