SRS-1.2tl
westmassguy
westmassguy Posts: 6,816
edited April 2021 in DIY, Mods & Tweaks
Build consisted of @gimpod boards, new Mate-N-Lock connectors, hand matched Clarity PX Capacitors, hand tuning existing inductors, new mounts, and new hand tuned SuperQ Sub-Bass Inductors.
Home Theater/2 Channel:
Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
Interconnect: Furez 10/2 with SpeakONs
ICs: Custom Furez by Douglas Connections
Den:
Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
Carver CT-3 Pre, Carver C-500
dhsspeakerservice.com/
  • JayCee
    JayCee Posts: 1,433
    When you hand tune is this to measurement (spec), by ear and approximately how far off are they? Curious minds....how many of Tony's boards remain?
    Nice work, as usual!!
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streamer: Roon ROCK on wifi'd NUC & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • Boost1
    Boost1 Posts: 13
    They turned out beautifully, Dave.....thanks! Currently warming them up inside of these guys and initial impressions are super favorable. I'll post some detailed impressions once they've burned in good....again, thanks for the great work and service!jv88vlfy0w61.jpg
    SDA SRS 1.2tl's
    Adcom GFA-585's
  • westmassguy
    oldrocker wrote: »
    Nice
    Den:
  • westmassguy
    JayCee wrote: »
    I use an Inductance Meter, and always tune them to spec. If they are slightly low, less than 2% or so, I'll match the opposite channel. I'd rather they be slightly low, but matched within les than 1%, than mismatched.
    Tony's boards are no more. All gone.
    Den:
    msg Posts: 7,655
    Nice, Dave, clean.
    What did you use for the mounts, and what are those two white strips?
    Is that a threaded insert in the center?
  • westmassguy
    msg wrote: »
    Nice, Dave, clean.
    Scott, the mounts are made from 1/2" MDF, same size as the original circuit boards. There's a 1/4-20 Hurricane nut in the center, and I send along new, shorter cap screws. The white strips are foam tape. Once you tighten the cap screws, the foam tape compresses and keeps the crossover from spinning or vibrating.
    Den:
    msg Posts: 7,655
    Looks great, and a nicely thought out design extra.
    pitdogg2 Posts: 22,388
    Damn I should have bought another set before they vanished.
    audioluvr Posts: 4,789
    I like how the resistors are on the back of the board to keep the heat away from those pretty, new caps! Nicely done Dave!
    Belles 350A Reference modded with Mundorf Supreme caps
    There is about a 5% genetic difference between apes and men …but that difference is the difference between throwing your own poo when you are annoyed …and Einstein, Shakespeare and Miss January.
    by Dr. Sardonicus
  • JayCee
    JayCee Posts: 1,433
    edited April 2021
    Scared the crap out of me. I saw the 2 resisters on R5 in series and thought that's not what I did back in 2011. Pulled up a pic and I have much different values. Jumped on Gimpod's placement site and verified. I have 22 and 24.9, parallel, but he gives the series example, as you have. First thought...oh $hit...they've been wrong for 10 years?
    I'm no electronics tech but am capable of soldering XO's and following directions, so quick Google search for resister calculator, 2 in parallel, and see my values, combined, are very much within tolerance of the 11.5 ohm spec. Whew. Pucker factor back to zero.
    My board:
    Quite sure I did the research back then and have done 4 sets of additional XO's but didn't need to double up, that I recall. Obviously, I have different values and probably worked through this w/Jeff @ Sonicraft when I ordered the parts. All this to say....I don't recall the discussion. Are there pros/cons to series vs. parallel or do you have a preference?
  • westmassguy
    audioluvr wrote: »
    Thank you
    Den:
  • westmassguy
    JayCee wrote: »
    My board:
    Both parallel and series are acceptable. I have no preference, all depends on what's available from my vendors.
    Den:
  • Gardenstater
    Gardenstater Posts: 3,460
    The same power should be dissipated by each resistor, regardless of parallel or series. We know that power dissipation is in the form of heat which increases thermal noise but should be the same in each case.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • xsmi
    xsmi Posts: 1,751
    Great job Dave!
    2-channel
    Belles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Schiit Mani Phono Pre, Moon LP 3 Phono Pre, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • westmassguy
    xsmi wrote: »
    Great job Dave!
    Thank You
    Den:
