small bookies
no taller than 12" or deeper than 10".....no wider than 16". These are for a secondary rig so turning a bookie on its side, while not advisable, not a show stopper. Anything out there?
  • marvda1
    marvda1 Posts: 4,945
    Puritan PSM156
    msg Posts: 10,452
    How good a speaker are you looking for, and any budget constraints?
  • kevhed72
    kevhed72 Posts: 5,142
    msg wrote: »
    This is for a secondary, general listening system. I will have a pair of Polk 5 monitors to move along after I find something.
  • SIHAB
    SIHAB Posts: 5,429
    edited December 2020
    I just checked the Polk site for the size of their bookies
    but no information was forthcoming. :|
    I would buy the NHT Superzero 2.1 for a budget system
    if you are looking new.
    msg Posts: 10,452
    Maybe a set of RT25i or Signature S15? I can speak for the RT25i. Pleasing signature, and good performer for its size.
    Powered monitors of some sort, maybe?
    I've been very pleasantly surprised by some of the stuff out there.
  • rooftop59
    rooftop59 Posts: 8,121
    SIHAB wrote: »
    I agree that the superzeros are excellent little speakers, but two caveats: 1. they need good power behind them to not sound shrill, and 2. they have to have a sub to not sound very thin. But set up properly, they sound surprisingly good...
    Game Room 5.1.4:
    Bedroom 2.1
  • dromunds
    dromunds Posts: 10,125
    The Monitor 4 Peerless is surprisingly good with unbelievable bass for its size with a front port. I just measured mine and they are 14 inches high approximately. But if you are replacing a pair of Monitor 5s they are smaller and I think the Peerless Monitor 4 is a better speaker. Cheap and really easy and inexpensive to upgrade the crossover too.
  • halo
    halo Posts: 5,616
    I know a guy that has a pair of Triangle Audio Borea BR03 bookies for sale!
    https://forum.polkaudio.com/discussion/192597/for-sale-triangle-borea-br03-bookshelf-speakers-in-walnut#latest
  • CGTIII
    CGTIII Posts: 1,237
    Polk S4s w/ Matching Center - $60 plus actual shipping.
    Boston - CR7, CR6s, CR4s.
    ​Thompson Adventures, Inc.
