Best Tube PreAmp under $500???
Ok thanks invalid. Glad i asked. I'll just stick with the 6922.
With this new Anthem tube pre, it uses 6922 tubes. I have some (6) 6SN7 tubes ( that I use in my Yaqin CD3 buffer) and found that the TubeDepot has some adapters so I can run the 6SN7 in a 6922 socket. Is this a bad idea? I will be buying some 6922s to play with along with the OEM tubes that JayCee is sending.
Just wanted some feedback about adapters.
It's as good idea as, say, popping the GM-supplied engine from your new Corvette & dropping in a Ford GT40 engine.
Why buy a preamp designed to run 6922s if you want to use 6SN7s? The 6SN7's triode sections are not identical to those in a 6922, so the operating points in your new preamp won't be ideal for the 6SN7s. You might like the sound, but wouldn't you be better off going for a 6SN7-based preamp if that's what you want? {This is a rhetorical question }
These are pretty nice and not too expensive. I was fairly impressed with one I had here for a day, courtesy of a local enthusiast.
http://www.tubes4hifi.com/SP14.htm
EDIT: Yeah, the heater current thing (which I wouldn't have even thought to check, which is a severe oversight on my part) is probably a deal breaker. You need to know how much current the filament windings of the power transformer in your Anthem is rated for.
Ask more of it than it is capable of, and the magic smoke will be loosed.
Post edited by mhardy6647 on -
Great info thanks. I have no idea what I'm doing when it comes to tube. So yall just saved me from making a mistake for sure.
So... the 6922 has a 6.3V 300 mA filament.
The 12AU7/12AT7/12AX7 family all have a center-tapped 12.6V filament. Run the two halves of the filament in series, and the heater current's 150 mA @ 12.6V; run 'em in series, and the current's 300 mA @ 6.3V (Ohm's Law and all that).
The amplification factor of the 6922 is 33 ("medium mu"), which is kinda in between the 12AU7 (mu of 19.5 for triode section 1 and 17 for section 2) and 12AT7 (mu = 60 for each section). The high-mu12AX7 is similar to all of these, but with mu = 100 for each section.
http://www.tubebooks.org/tubedata/HB-3/Receiving-Type_Industrial_Tubes/6922.PDF
http://www.tubebooks.org/tubedata/HB-3/Receiving-Type_Industrial_Tubes/6681_12AX7.PDF
http://www.tubebooks.org/tubedata/HB-3/Receiving_Tubes_Part_2/12AU7-A.PDF
http://www.tubebooks.org/tubedata/HB-3/Receiving_Tubes_Part_2/12AT7.PDF
The 6SN7 is also a twin triode, but of an earlier (and, some hifi buffs would argue, better) kind -- descended from very early indirect heated filament triodes like the 27, 56 and 76 (which are also popular preamp tubes in some circles ).
The 6SN7 has an untapped 6.3 V filament that draws 600 mA (as pointed out by @invalid above) and two triode sections each of mu = 20
http://www.tubebooks.org/tubedata/HB-3/Receiving_Tubes_Part_2/6SN7-GTA.PDF
The 6SL7 is "like" a 6SN7 but with a 300 mA 6.3V filament and a mu of 70 (each triode section).
http://www.tubebooks.org/tubedata/HB-3/Receiving_Tubes_Part_2/6SL7-GT.PDF
The precise operating points of all of these tubes are "similar" but not identical. In many cases they can substitute for each other, but just dropping, say, a 12AT7 into a preamp tube socket designed to use a 12AX7 will not be optimum.
So -- can you do it (swap twin triodes willy-nilly?). In some, even many, cases, yes (and, obviously, depending upon the base configuration of the tubes in question --yeah, you can get "adaptors"). Is it a good idea? Usually, no.
But, of course: all generalizations are false.
Including this one.
Read all about the history of the 6SN7 at
http://vinylsavor.blogspot.com/2014/02/tube-of-month-6sn7.html
I like 6SN7s and 6SL7s for hifi (FWIW).
Using a (borrowed) preamp right this minute that uses 56 and 6J5 triodes (both 6SN7 precursors). It sounds very good, but those 56s are crazy microphonic.
DSC_0121 (2) by Mark Hardy, on Flickr
Stick with what it was designed around the 6922/6DJ8. They are not too pricey and there are plenty out there in all price ranges. Trust me I understand as I too have a ton of 6sn7 from my buffer. In the last 6mo. I fell off the tube wagon and have had to invest in all different tubes 12at7, 5ar4, 5z4g, 12au7, 12ax7, 6bq5 and many of the equivalents for my last two pre-amps.
stick a fork in me I'm tube done.......famous last words -
mhardy6647 wrote: »These are pretty nice and not too expensive. I was fairly impressed with one I had here for a day, courtesy of a local enthusiast.
https://forum.polkaudio.com/discussion/192050/don-sachs-model-2-tube-preamp#latestmhardy6647 wrote: »Read all about the history of the 6SN7 at
http://vinylsavor.blogspot.com/2014/02/tube-of-month-6sn7.html"This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
The article didn't mention the CV181 because thomas knows they are not drop in replacements, but some preamps that use 6sn7 tubes have a transformer that can handle them. -
Never looked into other types of tubes but the OM states:
"The Pre2L comes with four tubes, as follows: LV1 & V1, LV2 & V2) 6922 tubes may be replaced with a matched set of ECC88/6DJ8s or E188CC/7308s with no circuit modification. These tubes were chosen for their reliability and extremely low noise. The amplifier topology used in the Pre 2L delivers exceptional performance using the 6922 tube. The tubes’ low noise heightens dynamics and provides a natural tonal balance."
The board has gain switches, too:
@CH46E, I noticed the PDF OM I sent you was scanned and is cut off on the left margin. I looked on-line and can't find a clean copy. I have the original printed manual for you. Hit up Chris @ Parts Connexion and he'll give you the skinny on what's possible. I believe there was/is an "SE" upgraded version of this pre?➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
Good info jaycee. I just noticed this preamp has a cathode follower, should be able to even use pretty long cable runs. Lot of preamp for the money.
If money was no object I'd probably have the PS Audio Regenerater. But....$$$$ is an object for now.
You’re not missing much, tried it. Meh.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
Respectfully disagree, for my system. Recently purchased the P15 and it's made a significant improvement.
I’m sure some of it depends on the power you’re getting in the first place. I compared the ps audio regenerator I had before to something like a torus rm15, the PS product sounded thin and harsh by comparison, likely unable to keep up with instantaneous power delivery. Just my experience. But I’ll never go back to a regenerator.
There’s much more to the sound than just a “cleaner” sound.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
Agree, cleaner doesn't always equate to better and the improvement I experience is in depth (front to back), improved bass and clearer/realistic vocals. The depth of soundstage was an eyeopener. Wouldn't call it "clean" or "sterile". Definitely more immersive. From my research, the current generators are a nice improvement over what they replaced.
Just curious. Did you use it with the Boulder or another amp? Which version PSA? I'd assume anything less than the P20 wouldn't do the Boulder justice and probably deserves a dedicated 20 amp line.
I'm not one to part with that much coin without return on investment. Unfortunately, for my wallet, the 30 day round trip didn't happen. Honestly, I'd hoped it wouldn't work out. LOL.➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
I wouldn't run an amp off a regenerator, especially one that has a bigger power supply than even a p20.
I never run the amps through the conditioners or regenerators. Just an easy load aka source components. Preamp I don’t either.
I tried just last night, the boulder into the Torus. With the Boulder on, the Torus makes a hum. With it off, there is no hum within the unit of the Torus.
Listened. Cleaner but also I lost sense of forward soundstage.
Sad. Even the torus can’t handle the boulder.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
Absolutely agree w/the last part of your sentence. I wouldn't consider anything not up to task if I were exploring power solutions for the 2060.
Looking at the Bolder specs I'd say it is quite capable of demanding power w/volume and combination of speaker:
Peak Power, 4 Ω 1200 W
Peak Power, 2 Ω 2400 W
Transients, even more-so.
I've compared my amp with and without the P15, to include combination of source components. "Never" will state my experience is someone else's but I've learned never to say never. The PSA regenerator's are said to be designed w/amps in mind. Can't speak to other brands (ie. Torus) I haven't tried.
I've proven myself wrong on many assumptions in the past and the power conditioning realm has been a leap of faith because I didn't see a need, just wanted to prove/disprove the ability of such in my system.
My bottom line is, especially w/return policies that allow a trial period, I may only be out a shipping cost. Wife and I ordered Thai takeout last night. Sixty-five dollars later and I have nothing to show except a reason to workout. Skip takeout and try stereo equipment. LOL. I totally trust your and Joey's experience with your own gear but would caution other folks looking....to not take our collective experiences as gospel.
P.S. @CH46E, sorry for derailing your thread. We actually have a few good threads this would be more appropriate.➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
I don't think the p20, ps audio's biggest regenerator doesn't have a transformer as big as the boulder 2060. I would want the transformer to be way bigger in the regenerator than the one in the amp.
The p20 has a 2000 va transformer, my amp has a 5000 va transformer.
Krell ?[/quote]
Correct -
Skip take out
Try audio equipment
Yes sir. I agree!Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
Hahah you guys are good! I enjoy the reading. And for the most part the thread accomplished its goal. So please continue the discussion, im enjoying it.
I feel like im driving a VW in a Ferrari and Lamborghini car parade.
You guys have some nice gear! -
I can relate to that.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables.
I believe most of the guys on this forum have been at this for a long time and aquired their gear over many years, just stick with it and you will get there too. -
I could never afford some of my gear new, but it becomes more affordable used.
I bought everything for my 2 channel used, apogee duetta 2 speakers, a krell ksa 300s amp a space tech tube preamp with separate power supply. The only thing I bought new was a bluesound node 2. -
A Krell Class A is at the top of my list!
Just make sure you use a tube preamp or a really expensive solid state pre. They sound really bright with a subpart solid state preamp. -
Not that a class A Krell is going to be anytime soon, but I did just pick up @JayCee Anthem Pre2L tube pre with mundorf Supreme caps.
And I think i should move to a colder climate than FL.
