Best Tube PreAmp under $500???
Geez @WLDock stop tempting all of us
FWIW, I love my Rogue Audio Triton phono pre-amp, and would not hesitate to purchase more Rogue gear.
Of course I'm still trying to sell my Don Sachs tube pre-amp
Ive seen the Schitt Freya and saw in a review a microphonics issue. If you tap on the base of the unit it transfers to the speakers. Now is this due to sub standard tubes? Or a design flaw? I have 2 nice pair of 6SN7.
Yes, it looks like there were improvements with the Freya+Ive seen the Schitt Freya and saw in a review a microphonics issue. If you tap on the base of the unit it transfers to the speakers. Now is this due to sub standard tubes? Or a design flaw? I have 2 nice pair of 6SN7.
https://www.head-fi.org/threads/sold-schiit-freya.931427/
https://fairhedon.com/2019/10/08/listening-to-the-schiit-freya-preamplifier/#:~:text=The differences are significant.,state has also been redesigned.2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
Looks like someone's gotta take a Schit out of the closet.
https://seattle.craigslist.org/sno/ele/d/edmonds-schiit-saga/7212170894.htmlGustard X26 Pro DAC
Here's a good deal.
https://seattle.craigslist.org/see/ele/d/seattle-modwright-instruments-swl90/7211689670.htmlGustard X26 Pro DAC
Nice! One of those brands I would own.
That ModWright would be nice.
But price wise, I may keep an eye out for a used Schiit Freya Plus. But that Chi-Fi looks very interesting. -
Are there any stereo tube preamps under $500 that have a plethora of input options to possible include Bluetooth under $500?
What constitutes a plethora of inputs? I've got one of these in my storage...
Hales System Two Signatures / Bryston 7B STs / McCormack RLD-1 / Innersound Phono / Bluesound Node 130 /Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts -
Do tell more. Remote??? -
I think I'd be ok with 3 rca inputs and a remote. I forgot to mention a remote might be a deal breaker.
One line level input -- and a switchbox.
Tube rectifier and tube regulation what more do you want.
I dont know what any of that means.
Pretty lights....
The sound of tube goodness. -
NO...... really.... i don't know what that means.
That means no remote.Gustard X26 Pro DAC
My requirement when I was searching for that current, affordable(ish) tube pre was XLR inputs and remote. Which is FAR more limiting than your requirements. Stick to your guns. If that's important then keep looking. Something will come around. Plus you may have more money by the time something ideal comes around. I'm under the philosophy that if it's something that you get lots of enjoyment out of, don't use budget as your primary limitation. There's some really nice stuff out there in the $800- $1,500 range and if you explain it properly to your mate, they will understand.
Of the two I posted I think the Belles and Modwright would be leaps and bounds ahead of what you have. Also I think Joules and Rogue should be added to that list basically because they are can be had in that range, built in the USA and don't have a bazillion tubes to have to deal with maintaining.
Just my 2 cents worthGustard X26 Pro DAC
Of the two I posted I think the Belles and Modwright would be leaps and bounds ahead of what you have. Also I think Joules and Rogue should be added to that list basically because they are all can be had in that range, built in the USA and don't have a bazillion tubes to have to deal with maintaining.
Agreed. -
The rectifier tube changes AC power to DC power and is smoother sounding than solid state diodes. The regulator tubes keep the voltage constant at a predetermined level, plus they are gas filled so you get a nice colorful glow out of voltage regulator tubes. You can also tube roll rectifier tubes, I've found them to make a difference in sound, even in a preamp. -
Agreed -
Thanks man. That I did not know. -
The Marantz UD7007 should be here soon and the pre amp is next.
Taking my Hafler to a vintage repair guy for a check-up and adjustment. Turns out the DC offset is a little higher according to my new meter.
Maybe I can manage to get these Infinity crossovers done in time to put it all together. -
OOH! Here's another one you should consider. Nice thing about eBag is you can pay for it with a credit card, hide the cash from the boss (wife) and get airline miles to boot!
https://www.ebay.com/itm/VTL-2-5-Line-Stage-Preamplifier/264670054975?hash=item3d9f908a3f:g:jNoAAOSwVoJecAEK
This beauty was my first real foray into tubes, and it was such a profound improvement it hooked me on the tube pre/SS power amp combo! IIRC the Polkie price I got for that baby was way less. Ya never know what will pop up in the FS thread!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
If you were local, I’d let you borrow my arc 40 so you could try it.
Tube pres are awesome
Good luck on your searchMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
It means that the power supply uses a vacuum tube rectifier ("rectumfryer", in the tube patois) for HV power and vacuum tube regulators to control the P/S voltages.
Opinions differ (imagine that?!) on the relative merits of ss vs. vacuum tube rectification, stiff vs. somewhat squishy power supplies, choke/capacitor vs. all capacitor filtering. A well designed vacuum tube P/S (regulated or not) will work just fine. -
I also find that rectifier rolling can make a difference in sound, and it doesn't have anything to do with voltage sag, try rolling a solid state rectifier.
https://youtu.be/Sk9XYQMRiLY
